Inspection Form With Pass/Fail Formula
Z_Man
I need help setting up an inspection form with a pass/fail result column. I would like to be able to enter the actual dimension after measuring the part then have the pass/fail column turn green for with word "pass" or turn red for with the word "fail". I've included the tolerance used as well on the spreadsheet. Is there anyway this all can work together in a formula?
  • Inspection Form.xlsx
Attached is an example of what you can do.
  • Inspection Form V2.xlsx
Z_Man
Thank you so much for your help! Is there a way to show two places after the decimal point without having it error to "FAIL"? Also should I insert a text box to show any geometric symbols such as diameter, etc? Or is there another to trick the formula to allowing the use of words or symbols included with the number without having it error also?
Z_Man
Awesome work Miner! :thanx:
Few more questions.
Is it possible to be able to have two dimensions in the same column and get the formula to work?
Also is there a way to have a plus/minus tolerances together with this formula as well? Or will that require another formula and special formatting.
I've attached an examples within the spreadsheet to show what I'm asking.
Sorry for all the questions. We're updating our inspection process at work on our forms with excel. We've been using a basic excel format.
  • Inspection Form Examples.xlsx
Regarding two dimensions (i.e., 8.05/8.00 or +.127/-.0) in the same column, there is no way to use that in a formula. Excel will interpret that as text instead of numbers. If you create columns for the actual Maximum and Minimum specifications, you can run the formulas from those columns and put whatever you want in the Print Dimension and Tolerance columns
  • Inspection Form Examples V2.xlsx
Proud Liberal
No, you cannot put two values in ACTUAL column.
Taking a slightly different approach: adding F & G column (hidden in outline), the formulas for RESULT can be much simpler. Also, moving the header information to another tab permits you to size the report columns any way you want. I also put the print excerpts into the comments in column B. Columns F, G, and I all contains formulas that would need to be copied down when adding more rows.
Z_Man
I was wondering if there is a formula that will work with fractions on an inspection form? I have an older drawing from a customer that calls out some dimensions in fractions and others in decimals. :confused:
Certainly. See the attached file for an example. It's not the formulas, but the formatting and data entry. Format the cells as fractions, then enter the data as fractions. The answer will then display as a fraction.
  • Fractions.xlsx
S Max and Min form diameter inspection IATF 16949 - Automotive Quality Systems Standard 4
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
J Manufacturing CRL - Class 1 or Class 2 Inspection (FDA form 483) US Food and Drug Administration (FDA) 1
M Further Inspection Required Form Misc. Quality Assurance and Business Systems Related Topics 1
T Inspection Form Review And Approval - FDA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
H Is an empty inspection box on form OK? Suggestions? Manufacturing and Related Processes 16
M Help needed with brilliantly engineered FAI (First Article Inspection) form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I FAI (First Article Inspection) per AS9102A include gen. notes on form 3? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 35
K Incoming Receiving Inspection Form Document Control Systems, Procedures, Forms and Templates 6
B Anyone have an inspection form for multiple users? "Spot-Welding" department Document Control Systems, Procedures, Forms and Templates 3
B Product inspection specification sheet form - Examples needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Why do suppliers submit bad parts // Quality Incoming Inspection Supplier Quality Assurance and other Supplier Issues 12
U How should we build the FDA inspection preparedness team for FDA inspections at factories? General Auditing Discussions 0
K Equipment IQ/OQ/PQ required when you have 100% product inspection? ISO 13485:2016 - Medical Device Quality Management Systems 2
B IATF 7.1.5.1.1 Measurement system analysis (Visual Inspection) IATF 16949 - Automotive Quality Systems Standard 3
Q Failure modes for Inspection processes ISO 14971 - Medical Device Risk Management 15
J Crimp inspection and process verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Looking to make inspection faster for part with over 100 dimensions. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
U FDA foreign inspection and COVID19 US Medical Device Regulations 4
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 4
T Need advice on what inspection equipment to buy. General Measurement Device and Calibration Topics 2
optomist1 PCBA Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Inspection procedure for components Oil and Gas Industry Standards and Regulations 8
Bev D Acceptance Inspection Sampling Plan Calculators Misc. Quality Assurance and Business Systems Related Topics 0
J Justification for visual inspection ISO 13485:2016 - Medical Device Quality Management Systems 3
M Cameras and Visual Inspection Equipment General Measurement Device and Calibration Topics 3
John Broomfield Construction Inspection and Test Plan Misc. Quality Assurance and Business Systems Related Topics 5
F Self Evident Inspection Method ISO 13485:2016 - Medical Device Quality Management Systems 11
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
P 21 CFR 58 GLP Periodic Study Phase Inspection Report Other US Medical Device Regulations 0
C Inspection Operation in PFMEA FMEA and Control Plans 13
L Language of quality system in case of FDA inspection US Food and Drug Administration (FDA) 1
I In-Process Inspection Raw Data ISO 13485:2016 - Medical Device Quality Management Systems 3
B Inspection of polymer palletes - sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
C Discus Software for First Article Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Suggest modern equipment/instrument for plastic bottle inspection? Quality Tools, Improvement and Analysis 1
H Starting my own 3rd party inspection company Service Industry Specific Topics 6
N Quality Inspection Quality Tools, Improvement and Analysis 10
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
A Industry Standards for Cosmetic Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
A % of defects on the whole batch based on result from inspection under AQL Level II Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Looking for important points regarding First Piece Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
