Inspection Level Interpretation - ANSI Z1.4-2008
P
Petemxa
I have a question about how to interpret the "Inspection Level" as described in ANSI Z1.4-2008.
ANSI Z1.4-2008 describes General Inspection II as the standard inspection level, however you can use special inspections S-1 though S-4 when larger sampling risk can or must be tolerated.
Is there anyway to quantify this risk? How much more risk am I taking by choosing an S-2 instead of S-4 or S-2 instead of G-II?
Thanks,
Peter
howste
Thaumaturge
Take a look at the OC curves. They will show you the probability of accepting a lot with a given % nonconforming product.
K
kabus - 2011
I apologize for bursting into your conversation, but I am also working with a sampling plan using special level S-3.
I compared the OC curves and, correct me if I'm wrong, but the comparison showed that for an AQL of 0.65% lot sieze of 22,000 units...using S-3 inspection level a lot with 0.256 non-conforming units could be accepted 95% of the time while using the inspection level II this probability increases to 0.830 with an increase in the sample size as well from N=20 to N=315. Is this correct?
I am having trouble interpreting the tables. Could you please explain the relationship between the Pa (99.0, 95.0, 90.0 percentages on the left) and the nonconforming percentages in the center of the table under each AQL. Are the nonconforming percentages equal to the consumer risk? Also, what information do tables XII provide (these are the ones that reference Pa as 5% and 10%)?
Pardon my ignorance but I am trying to learn about sampling plans since this task was recently assigned to me. Anything will be helpful!!!
K
kabus - 2011
Following the same line, that is development of sampling plans, I am supposed to determine a sampling plan for a gel product filled in tubes. There are some tests that are destructive; therefore I decided to go with an AQL of 0.65% and S-3 level of inspection for defects related to the product such as apperance, contamination and leakage. The lot size could be anywhere between 22,000 to 30,000 tubes. We want to keep the sample size small. Is this approach correct?
What factors shall be considered when determining the inspection level? The norm is level II but can a special level be used for in-process checks?
Is there a rule of thumb to develop sampling plans? or shall each be customized?
Thanks in advance for your help...reading the threads have helped me a lot...but I am still a roookie
P
Petemxa
Howste,
Can you help me understand how to interpret the OC curves so I can get a quantifiable assessment of the risk I am adding to my inspection process from shifting my Inspection Level from a General II to a Special Inspection S-2.
The OC curve gives me the probability of incorrectly dispositioning a recieved lot for a defined Lot Size letter code using General Inspection II. I don't see how I can connect the probability they show for General Inspection II to the probability for that same lot size for Special Inspection II.
So for a Lot Size of 151-280 I get a Letter code of G which calls for a sample size of 32 pieces. Looking at the OC curve for Letter Code G, with an expected lot acceptance level of 99% and an AQL of 4.0, I get a 2.67% probability that I will incorrectly disposition the lot. This is using an Inspection Level II.
Now, if I want to use and inspection level S-2 for the same Lot Size of 151-280 I get a letter code of B, using AQL 4.0, which calls for a lot size of 3 pieces. How do I quantify the risk. If I look at the OC curve for letter code B and using the same 99% lot acceptance level and AQL of 4.0. I get a 0.33% probability that I will incorrectly disposition the lot. Now obviously this is incorrect. I can't improve my confidence by decreasing my sample size.
The OC curves are there to be used in reference to the normal Inspection Level II. Is there a way I can connect these OC curves to an inspection level S-1 through S-4?
Can I take the probability of letter code B of 0.33% and multiply it by 280/15? '280' being the max lot size for letter code G and '15' being the max lot size of letter code B. So I basically can I say: "If I have a .33% probability with a lot size of 15 I have a 6.16% probability with a lot size of 280, because I am not increasing the sampling size but the lot size increased by a factor of 18.667." That seems too simplified, but is it a good estimate?
Thanks,
Petemxa
N Visible particles inspection in powders for injections. Approaches to AQL level Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A Level 1 vs. Level 2 vs. Level 3 Inspection Requirements - AS9100 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q AQL - How do I determine Acceptable Quality Level (AQL) for In-Process Inspection? AQL - Acceptable Quality Level 2
B Customer Inspection Frequency and Rejection Level Criteria - Sample Lot Size AQL - Acceptable Quality Level 6
B Choosing Inspection Level and AQL AQL - Acceptable Quality Level 1
M AQL and the impact of increasing Batch Size, or changing Inspection Level AQL - Acceptable Quality Level 2
H Need help with AQL (Acceptable Quality Level) for a QC inspection AQL - Acceptable Quality Level 8
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
S AQL .65 Level III - Take a particular component off 100% Inspection AQL - Acceptable Quality Level 4
T Special Inspection Level 3 (S-3) per ANSI Z 1.4 & its relationship with ISO 2859-1 AQL - Acceptable Quality Level 1
D Confidence Level II or Inspection Level? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Difficult Inspection Level/AQL - Verifying it is the correct part AQL - Acceptable Quality Level 5
R Identifying Inspection Level for Critical Components - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 5
W How to choose the correct General Inspection Level & AQL level...? AQL - Acceptable Quality Level 5
D What Inspection Level for Small Lot Size and Special Levels (S1-S4)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
T What is AQL, Inspection Level, and Type of Inspection AQL - Acceptable Quality Level 16
J Testing Potential New Hires for a Low Level Part Inspection Position Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Using AQL to get true random sampling using General Inspection Level II AQL - Acceptable Quality Level 4
R What is the 95 x 95 Inspection Level? Either an attribute or variables type plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
S. Moore Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M 3rd Party Sorting and Inspection Company Certification Service Industry Specific Topics 4
