Inspection method for T10 Hex driver
Jules31
Can anyone recommend inspection method for T10 Hex driver? We are trying to make a gage for it, however the manufacturer said that it will be tight, and we maybe rejecting good parts. Any recommendations?
Thank you in advanced.
Eredhel
Quality Manager
Even precision ground plug gages have specifications that allow for the minor diameter to be smaller to allow for tolerance stacking and such. I haven't dealt with hex but I'm betting there is something similar. You might ask the manufacturer what specification/standard they are going by when making them.
ScottK
Not out of the crisis
what are you inspecting?
the dimensions of the star?
The torque the driver puts out?
Please give more details.
Jules31
Yes we are measuring the star. We have a screw that should fit the T10 hex driver. However, we need to inspect the drivers to make sure our manufacturer can manufacture these consistently. We will eventually use the driver to inspect our screws as a mating part (not ideal)
ScottK
so you're going to check a driver that is going to be used to check a screw?
what kind of measuring instruments do you have? You could use an optical comparator and create an overlay with min/max dimensions.
does this all need to traceable to national standards?
Ninja
Looking for Reality
...don't know if you already have a CMM (Coordinate Measuring Machine) on site already...but it seems that it would be perfect for this.
MicroVu Vertex, OGP Flare or many others are readily accessible...(For <$40K)
If you have one on site already...it might even be a quicker way to check the bolts as well (though mating with the driver is quite more of an "in use" test to be sure)
Jules31
We do have an OGP, but it's old.
What is the model number that you would recommend to inspect a hex screwdriver that is about 15 in long to inspect the star on the hex?
Thank you.
Jules31
ScottK,
I would like it to be traceable to national standards, but for T10, it is very difficult, wouldn't it?
Ninja
Looking for Reality
Thank you.
15in long could be a problem...removable head?
The problem would be getting the 15" deep focal point.
If you stand the drive head (maybe you have to do the whole part), can your OGP focus on the tip?
All of my experience is with the Vertex...and pretty much any model would do as long as you can get the star in focus in the first place.
That said...you mentioned that it is really the screws you want to analyze:
"We will eventually use the driver to inspect our screws as a mating part"
Using the OGP to inspect the screw heads makes more sense to me than using a driver as a pass fail...and I assume the screws aren't 15" long...
Would that meet the need you are trying to meet?
ScottK
ScottK,
The inspection equipment, not the driver, would be traceable to national standards.
Are the drivers inexpensive? If so can you take a sample and cut them so that they will fit on the OGP? and then, as Ninja says, use the OGP for the screw heads?
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
A Quality Plan - Inspection method, equipment list for inspection of a Spur Gear Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R FAI (First Article Inspection) Report Number Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Ron Rompen Inspection Method for DW Brake Tube Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M .125-40 UNC-2B Thread requiring Inspection to Thread Gage "Method A" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
T Inspection Method and Control Method for Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
J Quality Control of High Tension Steel Cable Bolt - Inspection Method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Wire Harness Inspection Method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
hogheavenfarm What is the preferred Inspection Method of Stainless Steel for Cracks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Demonstrate Receiving Inspection Sampling Method is Statistically Adequate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Simpler Method of Recording In-Process Inspection Data - Machine Shop Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Battle of the Customer Approved Inspection Method - Root Cause of Nonconformance? Problem Solving, Root Cause Fault and Failure Analysis 11
P Is the first piece inspection method supposed to be in the Control Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
O GRR (Gage R&R) Method for Camera Vision Inspection System Hardware and Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
J Developing a method of inspection (other than visual) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Dimension Inspection - Results recorded on print - Seeking a better method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Method of Disposition on Damaged Inspection,Measuring Test Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
