Inspection of PPAP samples
Andrews
One of our customers require 1000 nos. to be sent as PPAP sample.PPAP manual requires PPAP samples to be inspected but it does not say what is the sample size to be used in cases where customer asks for more than 30 nos. as PPAP sample. Should we check 100% of the samples sent to customer or can sampling plan be used.
Andrews,
Is your custome rrequiring 1000 readings for the initial process study or is it 1000 samples?
The PPAP requirements are;
- a minimum of 300 pieces, unless otherwise required or agreed to with the customer, from a production run,
- 25 subgroups with a minimum of 100 readings.
The number of pieces to be inspected 100% is determined by the customer. In my case the customer requires 6 pieces from the 300 to be inspected 100% with the balance to be inspected 100% for SC's only. Cpk is calculated on each SC.
I would suggest that you contact your customer and clarify their requirements.
Howard Atkins
Forum Administrator
There is in my mind no connection between the number of samples required as parts and the PPAP. You only have to provide dimensional results on one part, if multiple cavities , each cavity and provide PPk on 100 parts.
Some customers want 1 part others 1000. It depends on what they do with them.
One question- Who pays for 1000 parts, this is not a sample.
Andrews
Thanks for all your help.
Does that mean that wherever customer requires more than 100 nos as PPAP samples (though they have paid for it) we should agree with them about the no. of samples to be inspected.Can even one sample do.
Howard Atkins
Forum Administrator
I.2.2.7 Dimensional results
The supplier shall provide evidence that dimensional verifications required by the design record and the Control Plan
have been completed and results indicate compliance with specified requirements. The supplier shall have dimensional
results for each unique manufacturing process, e.g. cells or production lines and all cavities, molds, patterns or dies (see
I.2.2.13).
My emphasis
I.2.2.13
The supplier shall indicate the date of the design record, change level, and any authorized engineering change document
not yet incorporated in the design record to which the part was made.
The supplier shall identify one of the parts measured as the master sample (See I.2.2.17).
If production parts will be produced from more than one cavity, mold, tool, die, pattern, or production process, e.g. line
or cell, the supplier shall complete a dimensional evaluation (see I.2.2.7) on one part from each. The specific cavities,
molds, line, etc., shall then be identified in the “Mold/Cavity/Production Process” line on a PSW, or in a PSW attachment.
From PPAP handbook
My reading and experience is that you do not need to provide dimensional report for more than one part.
I hope this helps
Al Dyer
Rak,
Under your definition, what is the difference? The PPAP run is sent to the customer. The pilot run (waiting for your definition) sounds like a set-up process engaged before the production (PPAP) run.
In either instance, capability should be determined to get a picture of the possible or actual process.
I am bit confused. ls. Pls. correct me If I am wrong,
Per me, only one sample need to be sent as PPAP sample with measurements to the Customer. This PPAP sample should be drawn from a run of 300 parts or 1 hour of continuous run. For process capability studies minimum 25 subgroups consisting of 100 pieces should be used. Is my understanding right?
RAK,
"Per me, only one sample need to be sent as PPAP sample with measurements to the Customer."
Sample submission qty is determined by the customer. see 1.2.2.16. You are required to retain one master sample , see 1.2.2.17.
" This PPAP sample should be drawn from a run of 300 parts or 1 hour of continuous run."
The 300 parts must be a consecutive production run from 1 to 8 hours. see 1.2.1.
"For process capability studies minimum 25 subgroups consisting of 100 pieces should be used. Is my understanding right?"
Yes. That is addressed in 1.2.2.9.1.
Para references are to the PPAP manual 3rd ed.
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 7
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 16
A In-Process Inspection Results ALWAYS With PPAP? APQP and PPAP 8
B TS 16949 PPAP/ Layout Inspection Frequency Requirements APQP and PPAP 8
S PPAP documents list - Checksheet for inspection IATF 16949 - Automotive Quality Systems Standard 5
E What is the purpose of the AIAG's PPAP process? Elimination of customer inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Is PPAP the same process as a ISIR (Initial Sample inspection report)? APQP and PPAP 15
B IATF 7.1.5.1.1 Measurement system analysis (Visual Inspection) IATF 16949 - Automotive Quality Systems Standard 3
Q Failure modes for Inspection processes ISO 14971 - Medical Device Risk Management 15
J Crimp inspection and process verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Looking to make inspection faster for part with over 100 dimensions. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
U FDA foreign inspection and COVID19 US Medical Device Regulations 4
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 4
T Need advice on what inspection equipment to buy. General Measurement Device and Calibration Topics 2
optomist1 PCBA Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Inspection procedure for components Oil and Gas Industry Standards and Regulations 8
Bev D Acceptance Inspection Sampling Plan Calculators Misc. Quality Assurance and Business Systems Related Topics 0
J Justification for visual inspection ISO 13485:2016 - Medical Device Quality Management Systems 3
M Cameras and Visual Inspection Equipment General Measurement Device and Calibration Topics 3
John Broomfield Construction Inspection and Test Plan Misc. Quality Assurance and Business Systems Related Topics 5
F Self Evident Inspection Method ISO 13485:2016 - Medical Device Quality Management Systems 11
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
P 21 CFR 58 GLP Periodic Study Phase Inspection Report Other US Medical Device Regulations 0
C Inspection Operation in PFMEA FMEA and Control Plans 13
L Language of quality system in case of FDA inspection US Food and Drug Administration (FDA) 1
I In-Process Inspection Raw Data ISO 13485:2016 - Medical Device Quality Management Systems 3
B Inspection of polymer palletes - sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
C Discus Software for First Article Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Suggest modern equipment/instrument for plastic bottle inspection? Quality Tools, Improvement and Analysis 1
H Starting my own 3rd party inspection company Service Industry Specific Topics 6
N Quality Inspection Quality Tools, Improvement and Analysis 10
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
A Industry Standards for Cosmetic Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
A % of defects on the whole batch based on result from inspection under AQL Level II Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Looking for important points regarding First Piece Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
S For Parts Manufacturer Approval (PMA) Is 100% Inspection Required? Federal Aviation Administration (FAA) Standards and Requirements 2
M Detection rank for sampling vs 100% inspection & 15x vs 400x magnification FMEA and Control Plans 4
S In process inspection Manufacturing and Related Processes 2
S Brexit 100% inspection during in process inspection Manufacturing and Related Processes 11
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Max and Min form diameter inspection IATF 16949 - Automotive Quality Systems Standard 4
