Inspection Software to Balloon Drawings and Create First Article Reports
JD84219
This question has been asked various times but not in the last couple of years.
We are investigating the purchase of inspection software to balloon drawings and create first article reports in various formats (AS9102, PPAP, customer specific forms, etc.)
- Are you using software that performs this function?
- Which software?
- What are its pros and cons?
- Do you recommend it?
- Have you compared other software packages recently (last 12 months)?
Previous threads (2011) mentioned: Inspection Xpert, VisualFair, DISCUS and NETinspect.
Are there others I should consider in 2014?
adamsjm
I will be interested in following this thread. The software should also support exporting the requirement data and "balloon" numbers to your PFMEA software as the requirements listing is the starting point for the PFMEA's Characteristic Matrix.
Chrisx
We currently use InspectionXpert for SolidWorks. I see no reason why it could not export these items to a PFMEA. It can export to any excel template once the template is configured. It comes with a tool to configure the template, which I found easy to use.
I'm not sure how it compares to other software out there. It does have some idiosyncracies. The bubbles sometime seem to be in an odd order. There is no way to change the order of bubbles. Sometimes it will miss a dimension or note and there is no way to manually add additional bubbles. Still it is much faster and less error prone than manually creating these documents.
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
QMMike Software to Record Detailed Final Audit / Inspection Data Software Quality Assurance 2
H FAI (First Article Inspection) Software Recommendations and Help Quality Tools, Improvement and Analysis 11
E Blade Inspection - Does anyone use blade scaning software for a CMM or laser scanner? Design and Development of Products and Processes 3
F Aged Inspection Equipment Software has no Audit Trail - Validation of Software Qualification and Validation (including 21 CFR Part 11) 5
C Specialized Software for Inspection Results Data Management Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D CMM Software ease of use and inspection of gears - Questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Software or template to manage first piece, in process and final inspection reports Software Quality Assurance 2
K Final Inspection for Software Product - Functional Test? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Software Code Review - Inspection Techniques Used Software Quality Assurance 2
M What Software is available for Receiving Inspection / Supplier Evaluation Quality Assurance and Compliance Software Tools and Solutions 4
J Looking for a good mechanical inspection software package Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Software that will enable our company to make Quality Inspection Sheets Quality Assurance and Compliance Software Tools and Solutions 16
D Quality Software - Multiple Use - CMM Data, Inspection Sheets, etc Quality Assurance and Compliance Software Tools and Solutions 4
O GRR (Gage R&R) Method for Camera Vision Inspection System Hardware and Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
A Industry Standards for Cosmetic Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
A % of defects on the whole batch based on result from inspection under AQL Level II Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Looking for important points regarding First Piece Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
S For Parts Manufacturer Approval (PMA) Is 100% Inspection Required? Federal Aviation Administration (FAA) Standards and Requirements 2
M Detection rank for sampling vs 100% inspection & 15x vs 400x magnification FMEA and Control Plans 4
S In process inspection Manufacturing and Related Processes 2
S Brexit 100% inspection during in process inspection Manufacturing and Related Processes 11
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Max and Min form diameter inspection IATF 16949 - Automotive Quality Systems Standard 4
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
