Inspection & Verificaton of Incoming Material - How best one can accomplish
trainerbob
#11
Keep in mind that just like parts we make internally, we cannot inspect quality into the parts that we purchase from others - We tried it in the auto industry for years - It doesn't work.
samsung
#12
Exactly. This is my main concern - inspecting the quality into the parts is the most difficult thing and this is where one has to be dependent on visual or judgmental mode of conclusion and the deficiencies are detected only when the 'part' suffers a premature failure.
Thanks.
Jen Kirley
Quality and Auditing Expert
#13
Our tests were designed to assess the processed materials' ability to exhibit the ability to perform in the way it is designed to do. We duplicated the stresses and exaggerated them to see at what point the material would fail - fibers pull apart, adhered surfaces separate, combustibles burn, a sharp object penetrates fully.
We didn't test the raw goods, we tested fabricated samples after the processes rendered them in the state of customers' use.
Just what is your product?
samsung
#14
Our product is Cement, Ordinary Portland Cement (OPC) & Portland Pozzolana Cement (PPC). We have to do extensive testings of all the raw material, intermediate & finished products at each stage of manufacturing because we can't verify all the specified parameters by subsequent monitoring or measurement before the product is shipped or even before it's used by the end users and as such we need to validate the manufacturing process. Testing starts even before the principle raw material (limestone in this case) is mined out; i.e., when the blast holes are drilled.
Jen Kirley
#15
Cement. Ah. I was once a classmate of a woman whose job was to perform onsite testing of concrete structures. I can't reliably repeat what she told me, but I can direct you to the Department of Transportation's Concrete Testing Manual, which describes various tests and their purposes.
Also, ISO 29582-1 deals with cement testing.
ASTM also has standards for testing cement of various types.
Does that help?
samsung
#16
Does that help?
Thanks Jennifer for the link to 'Concrete Testing Manual' which can be a useful guide for our marketing guys who has to deal with onsite concrete related issues while dealing with the end users.
ASTM specifications are applicable in US and some South/Middle East Asian countries. In India, cement, in general, is produced conforming to IS specifications. However, if it's to be exported to the above said countries, it has to conform to ASTM/ BS12/ Euro standards.
Thanks.
Jen Kirley
#17
Very good, I am happy to have been of some use. I don't know everything, but I'm generally good for a Google search! :D
Terry
#20
What I want to convey is that it's always not possible to inspect and verify all the critical parameters unless the material is put to use and it's where the deficiencies become apparent which couldn't be detected during the physical inspection at the warehouse (prior to issue and use). By this time, the documents have already been cleared and payment released to the suppliers.
For example, the stores receive a supply of nut bolts requested by me. Now I'm asked to inspect the material. Quantity, make, dimensions, packaging etc. are OK and as such I have to sign off the 'Inspection Sheet' and accept the material since it meets the 'prescribed specifications'. Well, I use this material and after 2 weeks I happen to discover that the bolts have suffered a premature failure resulting in production loss for 4 hours. (Although the suppliers later on made a free replacement but the loss incurred by the company was many times higher than the original cost of the faulty material).
The reason (root cause) for the failure was poor quality/ craftsmanship which couldn't be inspected and verified by physical means. What one can and should do to prevent such failures.
Has anyone experienced similar problems? Please share how you succeeded in managing the issues.
yes, i have the same questions with you, now i don't also know how to deal with so problems. :(
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
