Instrument Calibration Laboratory setup for API Pharmaceutical Company
Santosh1981
Dear Colleagues ,
We are a green field project and setting up a new API pharmaceutical plant in KSA.
I need your help for the following:
a) I need help to setup documentation system for calibration of critical
and technical isntruments.
b) In addition to this please advise we have all instrument delivered with
EN 10204 3.1 calibration certifcates , do we need to re calibrate them
again on site as they will be insterfaced with Plant DCS for controlling and monitoring.?
c) We have the normally used pressure and temperature instruments
installed for critical instruments. Please help in setting up the basic lab
setup and recommend calibration equipment.
Your help will be highly appreciated,
Santosh
v9991
and technical instruments.
your query is little generic...you will find scattered references...on documentation(including here in Elsmar)...viz.,
How to do Equipment Validation - Establishing our ISO 13485 QMS procedures
Also see:
http://www.fda.gov/ScienceResearch/FieldScience/LaboratoryManual/ucm171882.htm
http://www.fda.gov/ScienceResearch/FieldScience/LaboratoryManual/ucm171880.htm
http://www.fda.gov/ScienceResearch/FieldScience/LaboratoryManual/ucm171878.htm
http://www.fda.gov/ScienceResearch/FieldScience/LaboratoryManual/ucm171883.htm
whole lot of doc from FDAs QMS-lab-manual for compliance to 17025
http://www.fda.gov/ScienceResearch/FieldScience/LaboratoryManual/ucm171610.htm
anothre set from WHOs...
http://whqlibdoc.who.int/trs/WHO_TRS_957_eng.pdf#page=144
http://www.who.int/vaccines-documents/DocsPDF/www9666.pdf
Refer Pg.95 of following doc (Annex-I) and sec.12
http://whqlibdoc.who.int/trs/WHO_TRS_957_eng.pdf#page=95
YES except for the ones which are to be used as master-calibrator(references..., the ones which are calibrated with traceability references to NIST etc)
it also makes sense to establish the compliance before(at the time of) use; moreover its your responsibility to establish the suitability of equipment. (ensuring it stands the shipment, re-assembling or integration into DCS etc)
+ this also depends on the way details are outlined in your validation master plan.
c) We have the normally used pressure and temperature instruments installed for critical instruments. Please help in setting up the basic lab setup and recommend calibration equipment.
this actually depends on AMC from manufacturer himself (he might cover the periodic calibration/maintenance of these instruments) or external agencies (contract) to support calibrations. ... these option again depend on the frequency and load of things which require calibration at your end...
hope this helps.
V Calibration Laboratory Environment and Instrument Tolerances General Measurement Device and Calibration Topics 15
F Weighing Instrument Calibration Laboratory - Difficulties in Implementing a QMS? General Measurement Device and Calibration Topics 9
G Is it common to do a repeatability check during calibration of an instrument? General Measurement Device and Calibration Topics 5
chris1price Calibration of Instrument before being Discarded General Measurement Device and Calibration Topics 9
D AMS 2750E - Digital Instrument Calibration Accuracy Requirements General Measurement Device and Calibration Topics 1
S Can Calibration of an instrument substitute for Validation (IQ, OQ,PQ)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A How to read an analog instrument during calibration Measurement Uncertainty (MU) 2
WEAVER Calibration of Measuring Instrument by Adjustment of its Scales IATF 16949 - Automotive Quality Systems Standard 2
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
B AMS 2750 Furnace Instrument Calibration Operating Range AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
K Pyrometry Question - Furnace and Oven Instrument Calibration IAW AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R Does Humidity affect Electronic Instrument Calibration? General Measurement Device and Calibration Topics 16
P Instrument Handling & Calibration Training Material General Measurement Device and Calibration Topics 3
S What to do with Prior Analysis after instrument was Out Of Calibration (OOC)? Calibration Frequency (Interval) 14
E Maintenance Instrument Calibration Requirements General Measurement Device and Calibration Topics 6
R Calibration of Noise Source Instrument General Measurement Device and Calibration Topics 4
H Calibration of Measuring instrument, MRP gauges in machining General Measurement Device and Calibration Topics 2
D Personnel Training - Per Calibration Procedure or Type of Instrument? General Measurement Device and Calibration Topics 3
M Instrument Calibration Requirements - Determining what affects quality General Measurement Device and Calibration Topics 1
WEAVER Can you determine exact date an instrument went out of tolerance? General Measurement Device and Calibration Topics 10
R Suggest modern equipment/instrument for plastic bottle inspection? Quality Tools, Improvement and Analysis 1
H California Instrument AC Load - 222 Error Message Manufacturing and Related Processes 0
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
D Surgical Instrument Tray Classification EU Medical Device Regulations 7
J IVD instrument as an accessory EU Medical Device Regulations 3
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
F What is 'floor' in an instrument's specs Measurement Uncertainty (MU) 5
B Bioburden monitoring for surgical instrument provided non-sterile EU Medical Device Regulations 3
M Informational Is my device a Reusable Surgical Instrument under the EU MDR(2017/745)? Medical Device and FDA Regulations and Standards News 0
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J IEC 60601-2-2 - EMC Requirements - Surgical instrument manufacturer IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
S Cannot create Rejects for TMV on a medical instrument with an LCD Other Medical Device and Orthopedic Related Topics 10
Q AMS 2750E Sensitivity Requirements Field Test Instrument AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Guidance regarding Legally Refurbishing a Non-RoHS Instrument in the EU REACH and RoHS Conversations 1
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Kaye Instrument 373 RTD Monitor Resistance Curve General Measurement Device and Calibration Topics 2
S GR&R for an "R" value instrument installed on my 10K Horizontal Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G 2 Unacceptable GR&Rs - What instrument to use? General Measurement Device and Calibration Topics 15
B For a measuring instrument, should MSA be done first or the Capability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Total Resolution of an Measurement Instrument Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Leakage Current Measuring Instrument - IEC 60601-1 Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Is instrument ID required in the in-process inspection report per AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
S Protocol of water activity measurement and suitable instrument Food Safety - ISO 22000, HACCP (21 CFR 120) 1
D Records Requirement - Daily Instrument Verification IATF 16949 - Automotive Quality Systems Standard 5
L Tapes and Multimeters - Identification on Instrument General Measurement Device and Calibration Topics 4
H Continuous Monitoring Instrument Data Validation and how to calculate Outliers Quality Tools, Improvement and Analysis 1
R MDR Reporting for event with RUO instrument 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
1 Reprocessing of Surgical Instrument Sets Other Medical Device and Orthopedic Related Topics 4
