Instrument to check Internal Bottled Deep Bore Diameter
  • Thread starter SHIVAPRASAD N S
  • Start date
SHIVAPRASAD N S
Dear Friends,
I am in need of an instrument which can check deep bore diameter which is having a profile of bottled neck.
Please look in to attachment for schematic drawing of the part to be checked.
U
Umang Vidyarthi
Re: Need Instrument to check Internal Botteled Bore Diameter
You may use 'Translating caliper'. It is shaped like a scissor and the ID of the bore is translated at the outer end.
You may look up Robert Sorby's site to see the pictures. These are available from Indian manufacturers too. Just google for your area.
Hope this helps
Umang :D
SHIVAPRASAD N S
Dear Mr. umang Vidyarthi,:agree:
Thaks for your reply. The instrument you propse is for smaller length bores.
Pl go thorugh the attachment for the drawing (it is in my earlier post), I need to check at the depth of about 250mm & the length of bore is over 1950mm.
This instrument does not support my requirement.
U
Umang Vidyarthi
I have used 'Translating calipers' for much longer bores during boring operation on boring machines. You need to check only 250 mm, which means the fulcrum will be at 150mm max. I have suggested this as an economical option. Another (expensive) option is to use 'Telescopic dial bore gauge'.
Hope this helps.
Umang :D
SHIVAPRASAD N S
Re: Need Instrument to check Internal Bottled Bore Diameter
Dear Umang,
YOu have again mistaken. If you see the attachment where in I have posted a skimatic diagram of the component you will understand. It is not 250 mm that I have to check. My bottled bore starts from 250mm depth & the length of the bore is about 1950 mm.
I can not insert bore gauge because for the first 250 mm lenght bore diameter is less. I have to check higher bore diamenter after that. Tolerance is 0.4mm.
Have any solution?
Shiva :bonk:
Dear Umang,
Have any solution?
Shiva :bonk:
You're going to have a tough time measuring that unless you're willing to sacrifice some parts. One option might be to calculate the diameter based on the length and volume of the cylinder, but I don't know if that method will be precise enough.
True Position
A CMM with a disc shaped probe would work but is obviously not the most cost effective option. Also, if you could somehow make a probe that would first fit into the part an air gage would work depending on the surface finish.
U
Umang Vidyarthi
Dear Umang,
Have any solution?
Shiva :bonk:
Do not get frustrated Shiva. If there is a problem-there always is a solution. Have a second look with an open mind, and don't forget that 'Minds, like parachutes, work only when open'.
I reiterate at the cost of repitition, that 'Translating calipers' are the ideal and cheaper solutions. I have used them plenty of times, length of the bore not withstanding. For longer jobs you may make the caliper using alluminium alloy to make it light weight. If you need one meter to go inside the bore, you mae use only 1/2 or 1/4th Length above the fulcrum, outside the bore.
2. Have you tried using the second option of 'Telescopic dial gauge'? You may keep adding the rods to reach the desired depth.
3. You may also try contactless gauges (very expensive). The nozzles at both end expels air at high pressure which rebounds from the surface-to be- measured, impulses read by the instrument, which translate it into the exact measurement with accuracy in milli-inches! I have used these instruments long back in 'Indian Railways' around seventies. At that time these were imported from Japan, you may google for their availability in your area.
4. There are many more types of contactless measuring devices, using laser and other techniques. You may search google.
Umang :D
G Is it common to do a repeatability check during calibration of an instrument? General Measurement Device and Calibration Topics 5
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
D Surgical Instrument Tray Classification EU Medical Device Regulations 7
J IVD instrument as an accessory EU Medical Device Regulations 3
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
F What is 'floor' in an instrument's specs Measurement Uncertainty (MU) 5
B Bioburden monitoring for surgical instrument provided non-sterile EU Medical Device Regulations 3
M Informational Is my device a Reusable Surgical Instrument under the EU MDR(2017/745)? Medical Device and FDA Regulations and Standards News 0
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J IEC 60601-2-2 - EMC Requirements - Surgical instrument manufacturer IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
S Cannot create Rejects for TMV on a medical instrument with an LCD Other Medical Device and Orthopedic Related Topics 10
Q AMS 2750E Sensitivity Requirements Field Test Instrument AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Guidance regarding Legally Refurbishing a Non-RoHS Instrument in the EU REACH and RoHS Conversations 1
chris1price Calibration of Instrument before being Discarded General Measurement Device and Calibration Topics 9
D AMS 2750E - Digital Instrument Calibration Accuracy Requirements General Measurement Device and Calibration Topics 1
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Kaye Instrument 373 RTD Monitor Resistance Curve General Measurement Device and Calibration Topics 2
S GR&R for an "R" value instrument installed on my 10K Horizontal Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G 2 Unacceptable GR&Rs - What instrument to use? General Measurement Device and Calibration Topics 15
S Can Calibration of an instrument substitute for Validation (IQ, OQ,PQ)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B For a measuring instrument, should MSA be done first or the Capability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Total Resolution of an Measurement Instrument Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Leakage Current Measuring Instrument - IEC 60601-1 Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Is instrument ID required in the in-process inspection report per AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
S Protocol of water activity measurement and suitable instrument Food Safety - ISO 22000, HACCP (21 CFR 120) 1
A How to read an analog instrument during calibration Measurement Uncertainty (MU) 2
WEAVER Calibration of Measuring Instrument by Adjustment of its Scales IATF 16949 - Automotive Quality Systems Standard 2
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
D Records Requirement - Daily Instrument Verification IATF 16949 - Automotive Quality Systems Standard 5
L Tapes and Multimeters - Identification on Instrument General Measurement Device and Calibration Topics 4
H Continuous Monitoring Instrument Data Validation and how to calculate Outliers Quality Tools, Improvement and Analysis 1
R MDR Reporting for event with RUO instrument 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
1 Reprocessing of Surgical Instrument Sets Other Medical Device and Orthopedic Related Topics 4
S Instrument Calibration Laboratory setup for API Pharmaceutical Company General Measurement Device and Calibration Topics 1
C A better Instrument (Measurement Device) Identification System Misc. Quality Assurance and Business Systems Related Topics 7
C Reusable Instrument Sterilization Method Validations Other Medical Device and Orthopedic Related Topics 3
B Repeatability vs. Instrument Specifications Measurement Uncertainty (MU) 6
B AMS 2750 Furnace Instrument Calibration Operating Range AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Determining Instrument Purchase based on Accuracy (Micrometer) General Measurement Device and Calibration Topics 3
W Is a Non-Automatic Weighing Instrument a Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D RUO (Research Use Only - Laboratory Instrument) CE Marking Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Surgical Instrument Luminaries Standards - Single Use Disposable Surgical Instrument IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
L Stainless Steel Grades - Nomenclature for Surgical Instrument Stainless Steel ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements for Hardness of Metrology Instrument Parts General Measurement Device and Calibration Topics 3
V What is the difference between HMI & PLC based instrument controls? After Work and Weekend Discussion Topics 2
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
J Instrument for Inspection for Scratches on bearing RACE Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Pyrometry Field Test Instrument to perform TUS (Temperature Uniformity Surveys) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Can an IVD kit be used on RUO Instrument as per EU (and US) regulations? CE Marking (Conformité Européene) / CB Scheme 4
