Integrating MBNQA to the Quality Manual
G
Grace M. Llorca
We are on a PQA journey, our local version of MBNQA. We are trying to integrate its criteria and requirements to our Quality Manual. As a requirement, the top mgt came up with the Vision, Mission, and Values (VMV)while still having the Quality Policy as its summarized version. Then from the VMV, the CEO came up with the Long and short term goals, which supposedly a version of the Quality Objectives. Coming from those goals, the Executive Committee created the Corporate Balanced Scorecard (CBS), a version of the Plans for Quality Objectives to be able to deploy down the line. Now, having those goals already deployed, #1 may I know if it is okey to consider using them as the goal statements of the Quality Policy, Quality Objectives, and Plans for QO instead? #2 is it true that ISO9001 Standards is more on the "quality" aspects only of the business unlike MBNQA, which has both the "business and quality" results? Would appreciate your inputs as I'm confused :confused: :frust: as to how to integrate both because I know that ISO9001 standards & MBNQA criteria are the same and do compliment each other.
:thanx:
RoxaneB
Change Agent and Data Storyteller
First off, Grace, congratulations on your first post! I see you've been a member of the Cove since 2002 and have bravely decided to step out of the shadows! :D
I am by no means an expert on the BSC or MBNQA/PQA requirements, but I do know from my own experience that your Business Management System should be standardized in a such a manner that it honestly reflects the flow and interaction of how you operate.
It would be a drain on resources and confusing to your people (and...okay...just plain silly :) ), if you deveoped two parallel systems with one meeting the requirements of ISO 9001 and another for PQA.
If the two tools compliment each other, then you have an ideal setting to develop your true system which meets the requirements of both.
For what it is worth, my organization has followed a similar structure as yours. Although, our Quality, Environmental and Safety Policies are the output from our Vision, Mission and Values....we have taken the approach of the VMV being our foundation. The VMV is core to who we are. From there, the Q/E/S Policies were developed and along with supporting objectives and goals and targets.
Our Q/E/S Policies are generic - we do not state numerical goals in them or provide time frames. We do not wish to have Policies that change every year or so. Our goals and targets might change on an annual basis, but the Policies - which lead us down the path to our goals and targets - should remain stable (at least in our opinion).
Hopefully that answers (at least partially), your first question. :eek:
ISO 9001 does focus more on "quality" and the meeting of Customer requirements. My company, while registered to ISO 9001, likes to place more emphasis on being compliant with ISO 9004 which focuses on the Stakeholders. Our own Business Management System is centred on keeping our Stakeholders satisfied - Customer, Community, Employee, Supplier, Shareholder.
It is totally possible to have an ISO 9001 system that has been expanded to go beyond the meeting only the requirements of the Customer. :D
So if the requirements compliment each other, here's a few pieces of advice:
  • Develop or locate a matrix that shows exactly where the links/similarities are between the two.
    • List all clauses of ISO 9001 along one axis and all the clauses of PQA along the other.
    • Using a code to describe the links - D = direct, S = support, N = not applicable - or something like that
  • Develop a manual that works and flows for your organization.
  • Develop a table that shows where each clause from ISO 9001 and PQA can be found in your manual (i.e., in other words, your manual does not need to look like a mirror image of either ISO 9001 or PQA).
  • Once you see the overlaps and common requirements, standardizing the rest of your process should be a piece of cake.
Added later - Wow! This is post #1,200 for me. It's so long, maybe it should be 1,200 and 1,201. :D :rolleyes:
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Informational Draft ANSM’S GUIDELINE Cybersecurity of medical devices integrating software during their life cycle Medical Device and FDA Regulations and Standards News 0
B Integrating ISO 9001/27001 External Audits - Audit Time Reduced? Discounts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Integrating a Contract Manufacturer's documentation into our Quality System ISO 13485:2016 - Medical Device Quality Management Systems 3
A Integrating API Spec Q1 with ISO 9001:2015 Oil and Gas Industry Standards and Regulations 18
S Integrating ISO 20000 and ISO 31000 with ISO 9001 IT (Information Technology) Service Management 2
P Experience / advice for integrating API Q1 9th with a WCM program Oil and Gas Industry Standards and Regulations 5
C Integrating ISO 9001, 14001 & OSHAS 18001 - Do you need a Manual & Procedures? Document Control Systems, Procedures, Forms and Templates 5
K Integrating acquired existing product into Quality Management System Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Integrating Multiple HSEQ Systems into a Single Harmonised Global System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Integrating a Multi-Management System - What documents & records must we have? Various Other Specifications, Standards, and related Requirements 6
B Integrating other standards into ISO9001 QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
GStough Integrating 3 System Standards - ISO 9001, ISO 14001, OHSAS 18001 Other ISO and International Standards and European Regulations 20
V Integrating ISO 14001 and EPA Responsible Recycling (R2) ISO 14001:2015 Specific Discussions 4
M Integrating ISO 22000 and ISO 9001 - Food Safety Presentation for ISO Conference Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Integrating ISO 9001, TS16949, ISO 14001 & NOSA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Integrating Third-Party Software into Software we Provide ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Integrating a Project Model in a Process Based Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Integrating Multiple Company Policies such Quality and an Environmental Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Integrating Quality, Environment and Safety documents - Risk Assessment Misc. Quality Assurance and Business Systems Related Topics 4
V Pros and Cons of integrating ISO 14001 and ISO 9001? ISO 14001:2015 Specific Discussions 4
V Integrating the FMEA process with problem investigation/RCA process and PFMEA FMEA and Control Plans 11
M Integrating a Distributive Control System (DCS) into an existing 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Integrating ISO 14001 & 9001 into OHSAS 18001 Occupational Health & Safety Management Standards 65
J A First Course in Quality Engineering: Integrating Statistical and Management Methods Book, Video, Blog and Web Site Reviews and Recommendations 1
I Integrating EN ISO 9001 with JAA Regulations, QS, CAMO & MRO (Aviation Regulations). AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S Integrating both ISO 13485 and TS 16949 into the same quality manual Quality Management System (QMS) Manuals 7
B Integrating corporate's quality SOPs into our facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Integrating EFQM (European Foundation for Quality Management) Concepts within TS16949 IATF 16949 - Automotive Quality Systems Standard 9
A Integrating Continuous Improvement and Standardization - "The Toyota Way" Philosophy, Gurus, Innovation and Evolution 28
Sidney Vianna Integrating Q, E & S Management Systems - who is doing it? Various Other Specifications, Standards, and related Requirements 28
C Integrating offshore development into our QMS? Software Development Software Quality Assurance 1
R Integrating Customs-Trade Partnership Against Terrorism into ISO 9001 Various Other Specifications, Standards, and related Requirements 6
M Integrating ISO 13485:1996 with ISO 9001:1994 ISO 13485:2016 - Medical Device Quality Management Systems 6
D Integrating the FMEA Process to address identification of Aspects and Impacts Miscellaneous Environmental Standards and EMS Related Discussions 5
B Integrating Environment / H&S / Quality / Energy Miscellaneous Environmental Standards and EMS Related Discussions 12
xfngrs Integrating ISO 14001 with QS-9000 for a 'single' system Miscellaneous Environmental Standards and EMS Related Discussions 4
L Integrating ISO 14001 into QS-9000 w T/E or ISO 9001 ISO 14001:2015 Specific Discussions 15
B Integrating EMS and QMS Audits - Is it worth it? Miscellaneous Environmental Standards and EMS Related Discussions 2
B Integrating Audits - Is it worth it? General Auditing Discussions 1
D European Model for Quality Excellence vs. ISO Guide 62 vs. MBNQA (Baldrige) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Sidney Vianna Interesting Discussion Accreditation Matters: Our Role in The Quality Infrastructure ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q What are Quality Requirements for Design? Quality Management System (QMS) Manuals 8
R Quality System Software AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Is there any value in monthly quality reporting? Manufacturing and Related Processes 8
R Authorities of Quality Manager IATF 16949 - Automotive Quality Systems Standard 2
GStough Audit Nonconformances (?) for Suppliers Not Registered to ISO and No Supplier Quality Agreement Exists General Auditing Discussions 24
C Supplier Audit - Looking for a quality audit checklist General Auditing Discussions 3
A How would a candidate for Quality Systems Manager role answer questions in a med device manufacturing org ISO 13485:2016 - Medical Device Quality Management Systems 11
