Integrity of Flue gas analyzer?
amanbhai
I have issue of calibration of Flue gas analyzer issue & I don't know how to solve it since there is no capabiilty available in this country but if I send it abroad it usually take time & huge money. Can anyone guide me about it?:thanks:
amanbhai
Land com series III but the problem is I don't know where to get it calibrated? if I send it outside then how do I serve my clients? Correlation of results of different results is not available in this country.:thanks:
ScottBP
Flue gas analyzers are used to monitor emissions of furnaces, boilers, turbines, etc. They have sensors that detect the amount of oxygen, carbon monoxide, carbon dioxide, unburnt fuel, etc. going up the smokestack to determine the combustion efficiency of the burners; i.e. to see if they are burning too lean or too rich. Some also monitor sulfur dioxide and nitrogen oxides for air pollution regulations.
Just about any calibration company that handles gas detectors, leak sniffers, carbon monoxide monitors and confined space monitors can usually handle flue gas analyzers as well, as they fall in the same general category.
DsqrdDGD909
Measurement Specifications
Sensor Standard Range Max. Range# Accuracy Resolution
Oxygen, O2 0 to 25.0 % Vol. 0 to 30.0 % Vol. ±1 % ±0.1 % Vol.
Carbon Monoxide, CO (low) 0 to 2 000 ppm 0 to 10 000 ppm ±2 %* ±1 ppm
CO (H2) compensated 0 to 2 000 ppm 0 to 4 000 ppm ±2 %* ±1 ppm
Carbon Monoxide, CO (high) 0 to 4 % 0 to 10 % ±2 %* ±1 ppm
Sulphur Dioxide, SO2 0 to 2 000 ppm 0 to 5 000 ppm ±2 %* ±1 ppm
Nitric Oxide, NO 0 to 1 000 ppm 0 to 5 000 ppm ±2 %* ±1 ppm
Nitrogen Dioxide, NO2 0 to 100 ppm 0 to 1000 ppm ±2 %* ±1 ppm
Hydrogen Sulphide, H2S 0 to 200 ppm 0 to 1 000 ppm ±2 %* ±1 ppm
Carbon Dioxide, CO2 ** 0 to 25.0 % Vol. - ±0.5 % Vol ±0.1 % Vol.
Hydrocarbons 0 to 5.0 % Vol. (Application dependent)
Flue Gas/Ambient Temperature Measured
Draft ± 51 cm / 20 " Water Gauge ***
Flow (velocity) 1 to 50 m/s
Note: Special ranges are available
*Calibration per CTM034 or LAND factory procedure
http://www.epa.gov/ttn/emc/ctm/ctm-034.pdf
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R What is meant by Use of COMPONENTS WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT (clause no 4.9) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Integrity of electronic digital records - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
M Package Integrity Test ASTM F 2096 or ASTM 1929 Quality Assurance and Compliance Software Tools and Solutions 2
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
Sidney Vianna ISO 9001 News Tirelessly Improving the Brand Integrity of ISO 9001 - Working Group under ISO TC 176 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 42
I HEPA Filter Integrity test ISO class 9 room Qualification and Validation (including 21 CFR Part 11) 2
Q MHRA has released a new guidance document related to 'GXP' Data Integrity EU Medical Device Regulations 3
R Wet Signature Document Attachments in SAP - Risk on Data Integrity issue? Records and Data - Quality, Legal and Other Evidence 6
E Definition Integrity - The meaning of the word INTEGRITY in ISO 13485 Control of Records Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
V Data Quality and Data Integrity - Audit Trail - Part 11 - WHO - FDA - MHRA - PDA US Food and Drug Administration (FDA) 6
N Foil Package Integrity Testing ISO 4074 Other Medical Device Related Standards 1
D Integrity and Inspection of Concrete Blocks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
sagai Safety Integrity Requirement as per ISO/IEC 61508 Other ISO and International Standards and European Regulations 2
somashekar 5.4.2 b) Integrity of QMS in Change Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Package Integrity Testing Acceptance Criteria ISO 13485:2016 - Medical Device Quality Management Systems 3
S Suggested process to show compliance for this 820.120(a) for Label Integrity 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M How to validate a Dye Test method used to evaluate Package Integrity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
N High Integrity Components Definition according to clause 4.9 of IEC60601-1 3rd ED IEC 60601 - Medical Electrical Equipment Safety Standards Series 43
I SIL (Safety Integrity Level) calculation per IEC 61508. Reliability Analysis - Predictions, Testing and Standards 6
V ISO 26262 - How to handle OEM ASIL A (Automotive Software Integrity Requirements) Other ISO and International Standards and European Regulations 4
J Outline of Data Integrity Training or a Data Intergrity Agreement example wanted Quality Manager and Management Related Issues 2
S A question on Maintaining the Integrity of the QMS (5.4.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Surgical Sealant Package Integrity Test for Glass Vial Filled Product Other Medical Device Related Standards 3
W Oven Leak Test Method - Integrity of the chamber to hold gas Qualification and Validation (including 21 CFR Part 11) 3
J Container Closure Integrity & Sterility Test - The Dye Immersion Method Quality Assurance and Compliance Software Tools and Solutions 16
A Internal auditors independence & integrity Internal Auditing 9
bobdoering Determining a Good Variable for Small Scale Weld Integrity Capability Evaluation Capability, Accuracy and Stability - Processes, Machines, etc. 7
K Data Integrity Verification Tool Quality Assurance and Compliance Software Tools and Solutions 3
I How Must Safety Integrity Level (SIL) For Ball Valves Be Calculated? Reliability Analysis - Predictions, Testing and Standards 3
T Automotive Software Integrity Level (ASIL) - What are the Requirements & Details? Software Quality Assurance 2
A Import Data Integrity Software Quality Assurance 2
S Employer asking me to compromise on integrity Career and Occupation Discussions 46
R Meat Sample Integrity General Measurement Device and Calibration Topics 4
Q How to handle the integrity of electronic data in databases? Records and Data - Quality, Legal and Other Evidence 13
Y Label Integrity Validation - Instances of labels peeling off unexpectedly Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D cGMP and Batch Integrity of Bulk Storage Tanks US Food and Drug Administration (FDA) 8
D Industry Standard for Brazed Joint Integrity - Customer Specification Various Other Specifications, Standards, and related Requirements 1
apestate Integrity in reporting, and Poorly defined Tolerances and Requirements Records and Data - Quality, Legal and Other Evidence 4
CarolX Integrity lost? Conflict of Interest? ISO 9000 'Keepers' Profit from their books Philosophy, Gurus, Innovation and Evolution 42
Marc NIST 'High Integrity Software Systems Assurance' resource (site semi-abandoned) Software Quality Assurance 2
P Lot integrity - We have many paperwork problems - Wht can I do? QS-9000 - American Automotive Manufacturers Standard 2
P Lot Integrity - Process Steps where Identification is Lost (eg.: Quench) Misc. Quality Assurance and Business Systems Related Topics 6
N Voltage Doubler fail - can gas tubes be used? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
K Verifying gas tight glass syringe used for making standards General Measurement Device and Calibration Topics 4
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
