Interesting Nonconformance During Upgrade Audit to ISO 9001:2008
  • Thread starter Jason PCSwitches
  • Start date
Jason PCSwitches
[FONT=&quot]2 weeks ago I assisted an organization with their upgrade audit to the ISO 9001:2008 standard.
Note: They are/have been certified to the ISO-2000/AS9100-B standard for many years. Interestingly they had a re-cert audit last year (same time of year) & received re-cert to AS9100-B. For some reason the CB did not include the ISO upgrade in the scope of the audit; thus forcing the organization to spend more $$ this time around for requirements that were literally just assessed.?.?.?[/FONT]
[FONT=&quot]The audit itself went well and the upgrade will happen. They/we actually had only 2 NC's noted; one of which I find very questionable and I would like to get the thoughts of other professionals as to the validity of the NC.[/FONT]
[FONT=&quot]Note: I did tactfully discuss the NC with the CB auditor but he was sticking to his guns and it is a very, very, easy fix. That being said I didn't and do not want to start (as we say in the south) a pissing contest and make a mountain over a molehill. Keep in mind that while I understand the angle of proper disposition, you need to pick & choose your battles; sometimes it's better to just let sleeping dogs lie (clique).[/FONT]
Here is the NC as recorded on the report:
"The quality manual has not been updated to ISO 9001:2008"
"The organization shall establish and maintain a quality manual that
includes
the scope of the quality management system, including details of and justification for any exclusions (see 1.2)"
[FONT=&quot]Here's the thing, I understand that the QM should reflect 2008, however, in my opinion & understanding, an organization cannot publish any form of media stating conformity to a standard that they have not yet been "officially" granted certification to. Actually per this particular CB’s procedure, the only allowable form of certification publication must reflect what is on the certificate, exactly.
[/FONT] [FONT=&quot]So, is the NC valid? I feel it could/should have been handled differently. Should an organization change and circulate (externally) documentation stating certification to a standard that they have not yet been certified to?[/FONT] I don't think so.
[FONT=&quot]While I understand the angle that the QM should be conformant to the standard, it must be kept in mind that this document, the organizations QM, is circulated weekly as need be. This is dangerous ground in my view and if CB's write NC's in this regard it could lead us down a path we didn't anticipate.[/FONT]
It literally took me 5 minutes to correct this and define the root cause, which was fun to concoct.
Please share your thoughts....
somashekar
Re: Interesting NC During Upgrade To ISO-2008
A quality manual of an enterprise aligned to a standard and the certification of that enterprise to that standard are in no way connected.
I guess the NC is valid, but holds no weight.
" Did the quality manual before the NC was issued have the ISO 9001:2000 referred ... ??"
Chennaiite
Never-say-die
I have two ways of looking at your case. Number one, the auditor seems to have come with the pre-occupied mind of ending up the audit with 2 NCs and he has done exactly the same by making some observation that wouldn't add any value.
Number two, the fact that you are not certified yet wouldn't stop you from claiming conformity to the Standard in written. I would be surprised if such a rule does exist.
ScottK
Not out of the crisis
I say in in the QM that the QMS complies with ISO9001:2008.
I would not say in the QM that the QMS is registered to a standard. That's what the certificate is for.
I doubt I would have written an NC about it unless it was pervasive in other documents.
Any company can claim conformity to anything. They can't claim registration or certification.
ScottK
Or, you could remove altogether the reference to the revision level and simply state: "...complies with ISO 9001..." or "...complies with the current version of ISO 9001...".
Simple, no? ;)
CB at my last job made us put the rev year.
didn't write an NC though. Noted it in the pre-audit QM review and we had it fixed before he showed up.
I'm thinking the auditor in the OP's post didn't do a pre-audit quality manual review.
Jason PCSwitches
[FONT=&quot]This is a good point. I did provide him, as one should, with a copy of the QM prior to the audit so he could develop his plan.
Due to this perception, I have advised the marketing department to remove all references to certification from marketing literature and also advised so for internal documentation. The company’s certification should be enough when requests are made.
I've also noticed that most of the larger organizations are moving this way as well. It's a matter of cost. Every time you upgrade/re-cert they have a mountain of documentation to change and that is very expensive. IMHO, let the actual cert speak for itself when need be. After all, not all but most organizations are required to or are seeking/have certification to an appropriate standard, at least in this industry. It just makes good business sense.[/FONT]
mguilbert
Simple, no? ;)
That is what I had done. It was time consuming to find everywhere the rev. year was included but we wouldv'e had to do it any way and now we will not have to it next time.
Also we had no problem with the CB.
Jason PCSwitches
Simple, no? ;)
[FONT=&quot]While I agree that a reference to the specific applicable standard may not be required or overtime value added, note that the CB has strict requirements regarding "marketing" material. Technically, due to an organizations QM generally being circulated outside the organization it is considered marketing material as well as a QM.
That being said, we must follow the guidelines imposed by the CB and specifically list/reference certifications in the manner described. It may be possible to get an exception to this but I think it would be difficult as the CB's themselves have restrictions imposed in this regard.[/FONT]
ScottK
[FONT=&quot]Due to this perception, I have advised the marketing department to remove all references to certification from marketing literature and also advised so for internal documentation. The company’s certification should be enough when requests are made.
I don't know if I would have gone that far...
Registration to standards and directives and such is a marketing tool. That's usually half (if not more) of the reason to get to third party certificate.
If you have it, flaunt it...just make sure the marketing people stay current and update literature, web site, etc.
M Informational Interesting read for risk managers – The Psychology of Prediction Medical Device and FDA Regulations and Standards News 1
Ronen E Interesting Discussion Interesting view of EU Authorised Representative under MDR EU Medical Device Regulations 3
Sidney Vianna Interesting Discussion Interesting article form the UNIDO Magazine - CSR: a wolf in sheep’s clothing? Sustainability, Green Initiatives and Ecology 16
Sidney Vianna Interesting Discussion ISO 9001 audits from the perspective of registrants' customers - an interesting paper Registrars and Notified Bodies 0
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
M Medical Device News EU interesting developments – embracing MDSAP and UDI alignment Medical Device and FDA Regulations and Standards News 0
J ASQ Chicago Training Institute - If any of you are interesting in teaching ASQ Certification preparation ASQ - American Society for Quality 1
N Dream Log - Occasionally I have some interesting Dreams Coffee Break and Water Cooler Discussions 27
H Interesting Article:Weak Supplier Relations Costing Big 3 Automakers, Nissan Billions World News 4
SteveK Interesting Medical Device Database Site (666,413 items listed) Other Medical Device and Orthopedic Related Topics 1
B Share ideas to make Management Review more interesting Management Review Meetings and related Processes 4
N Interesting Purchase Order for its Terms and Conditions Quality Manager and Management Related Issues 82
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
V Medical Device Conference - May 2014 - Interesting topics and presentations Book, Video, Blog and Web Site Reviews and Recommendations 1
A Interesting article - Economics of Environmentalism Coffee Break and Water Cooler Discussions 0
Hershal Interesting Israel Holiday Coffee Break and Water Cooler Discussions 6
Randy Interesting lady I met today Coffee Break and Water Cooler Discussions 5
S Interesting ITAR related question from our Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R AS9100C vs. AS9101D 7.6 c.) - Interesting how meanings change AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
M Interesting article - Analysis of Risk: Are Current Methods Theoretically Sound? ISO 14971 - Medical Device Risk Management 7
GStough Verisys Registrars - Interesting Statements on Their Web Site Registrars and Notified Bodies 2
RoxaneB My train ride with the world's most interesting person... Coffee Break and Water Cooler Discussions 29
J Interesting humor cartoons and videos for quality awareness training Training - Internal, External, Online and Distance Learning 4
D Interesting graphic of BCS (college football coaches' ballots) Poll Coffee Break and Water Cooler Discussions 5
V Interesting quiz, case studies or exercises for AS9120 needed AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
Steve Prevette An interesting paper on Lean Lean in Manufacturing and Service Industries 13
Q How can I make the QMS (Quality Management System) interesting to employees? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
Jim Wynne An interesting antivirus experience - A "dynamic" test After Work and Weekend Discussion Topics 14
Claes Gefvenberg Interesting Cove signatures Coffee Break and Water Cooler Discussions 65
F CAPA Training - Tips on making CAPA training topics interesting! Nonconformance and Corrective Action 3
K Management Buy In - Management has presented some interesting challenges IATF 16949 - Automotive Quality Systems Standard 11
Jim Wynne Interesting Signs - Possible new OSHA requirement? Funny Stuff - Jokes and Humour 7
V Interesting presentation about QUALITY Coffee Break and Water Cooler Discussions 8
A Need help with creating useful, interesting and good internal web site about QMS!!! After Work and Weekend Discussion Topics 5
J Some interesting information for those who are interested in ISO/TS 16949:2002 IATF 16949 - Automotive Quality Systems Standard 3
Claes Gefvenberg An interesting audit coming up - First combined ISO 9001 / 14001 surveillance audit General Auditing Discussions 6
E Some Interesting Sites Unrelated to Quality Coffee Break and Water Cooler Discussions 11
A Interesting audit request - Full reaudit when separating R&D from division General Auditing Discussions 6
WALLACE FPS (Ford production system) - Does anybody have any interesting comments? Customer and Company Specific Requirements 8
Marc An Interesting Failure Analysis - Ejection Seat Failure Nonconformance and Corrective Action 8
A Firestone Articles (Other Interesting Articles) World News 35
B Keeping the induction group awake - Interesting training exercises to share? Training - Internal, External, Online and Distance Learning 14
D Interesting Web Sites, Boards & other resources on Stats Statistical Analysis Tools, Techniques and SPC 4
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
E When to generate a nonconformance report ISO 13485:2016 - Medical Device Quality Management Systems 6
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 25
Q When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
PhilM Nonconformance report, Customer complaint investigations and RMAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
