Interesting Nonconformance During Upgrade Audit to ISO 9001:2008
  • Thread starter Jason PCSwitches
  • Start date
amanbhai
#22
Re: Interesting NC During Upgrade To ISO-2008
One of the CB audit aspect is to check the use of mark, having provided guidance on how to use the mark after certification. Am I correct ?
OUr accreditation body is very unhappy with us for not using the accreditation body mark for our testing labs.
Paul Simpson
#23
I think most of this has been covered now ... but hey, :2cents:
[FONT=&quot]2 weeks ago I assisted an organization with their upgrade audit to the ISO 9001:2008 standard.
Note: They are/have been certified to the ISO-2000/AS9100-B standard for many years. Interestingly they had a re-cert audit last year (same time of year) & received re-cert to AS9100-B. For some reason the CB did not include the ISO upgrade in the scope of the audit; thus forcing the organization to spend more $$ this time around for requirements that were literally just assessed.?.?.?[/FONT]
A lot of CBs do this. Despite the fact that ISO says no further assessment work is required the CB takes advantage of a deadline to add a day or two. Brinksmanship often leading to profiteering.
[FONT=&quot]The audit itself went well and the upgrade will happen. They/we actually had only 2 NC's noted; one of which I find very questionable and I would like to get the thoughts of other professionals as to the validity of the NC.[/FONT]
[FONT=&quot]Note: I did tactfully discuss the NC with the CB auditor but he was sticking to his guns and it is a very, very, easy fix. That being said I didn't and do not want to start (as we say in the south) a pissing contest and make a mountain over a molehill. Keep in mind that while I understand the angle of proper disposition, you need to pick & choose your battles; sometimes it's better to just let sleeping dogs lie (clique).[/FONT]
Your choice. I understand the ‘sleeping dogs lie’ approach but personally find it often leads to problems down the road as the auditor feels they can lay their own particular law down.
Here is the NC as recorded on the report:
"The quality manual has not been updated to ISO 9001:2008"
"The organization shall establish and maintain a quality manual that
includes
the scope of the quality management system, including details of and justification for any exclusions (see 1.2)"
The changes to the 2008 edition were minor without any significant changes to the requirements for the quality manual so my question would be - what updates are required? All the QM requirements are listed in 4.2.2. If there is anything listed that you don’t meet then there is an NC. If everything is met then at best you have an OFI based on an auditor’s opinion.
[FONT=&quot]Here's the thing, I understand that the QM should reflect 2008, however, in my opinion & understanding, an organization cannot publish any form of media stating conformity to a standard that they have not yet been "officially" granted certification to. Actually per this particular CB’s procedure, the only allowable form of certification publication must reflect what is on the certificate, exactly.
[/FONT] [FONT=&quot]So, is the NC valid? I feel it could/should have been handled differently. Should an organization change and circulate (externally) documentation stating certification to a standard that they have not yet been certified to?[/FONT] I don't think so.
As has been mentioned elsewhere you can claim compliance with any standard before you are certified but you might be in breach of trading standards law (here in the UK) if you make a claim that is found not to be true (generally only challenged when you have breached another contract with a customer).
[FONT=&quot]While I understand the angle that the QM should be conformant to the standard, it must be kept in mind that this document, the organizations QM, is circulated weekly as need be. This is dangerous ground in my view and if CB's write NC's in this regard it could lead us down a path we didn't anticipate.[/FONT]
It literally took me 5 minutes to correct this and define the root cause, which was fun to concoct.
Please share your thoughts....
Exactly. The ‘5 minutes’ is the tip of the iceberg. Designing your system to meet an auditor’s opinion is a slippery slope.
CB at my last job made us put the rev year.
didn't write an NC though. Noted it in the pre-audit QM review and we had it fixed before he showed up.
I'm thinking the auditor in the OP's post didn't do a pre-audit quality manual review.
Another ‘finding’ that is incorrect. Taking a silly example (I hope ): If you have a manual that refers to ISO 9002: 1987 :) the auditor might ask why it hasn’t been changed but the QM is your statement and you might want to address this obsolete edition - your choice. If you have forgotten to update the reference then an auditor may raise a finding if s / he thinks you might need a further reminder.
If, on the other hand, you make reference to the standard number on its own (without the year) again there is no nonconformity. Any assessment of your system is by agreement and / or contract against the edition you choose - normally the latest edition. But, as my post above addresses sometimes you are working to an old edition as you make a transition or by choice.
Paul Simpson
#24
Many certification and accreditation bodies want you to advertise their services and also believe your use of their logo will help to tie you in because of the hassle of changing stationery etc.
dv8shane
#25
Or, you could remove altogether the reference to the revision level and simply state: "...complies with ISO 9001..." or "...complies with the current version of ISO 9001...".
Simple, no? ;)
I actually state in my manual that where ISO9001 ISO 17025 and AS9100 are mentioned they are referring to the latest versions to which the organizations QMS is registered to so I do not have to go changing the revision of the QM every time they revise the standard, an example is the my upcoming switch to AS9100C. I would have had to revise every part of my quality manual where the standard is mentioned if I did not do this. It saves a lot of editing and revising time.
ChrissieO
#26
Yes indeed. How trivial and petty.
Totally agree with you Jane, what a waste of time and effort.
If it could be fixed in 5 seconds, then why not fix during the audit and then the auditor mention it as an observation in the closing. This relates to the other topic discussion we were having about trivial non value added NCs.
On the point of compliance, I feel that if the auditor wanted to be very picky they could raise it, but if I was the auditor I wouldn't of wasted my breath. Perhaps He/She are targeted onhow many NCs the raise;) or is trying to justify his/her existance:lmao:.
Chrissie
JaneB
#27
Exactly.
IF they needed to make a point of it, as you say, a very pragmatic solution is to mention it only. And if a client was smart enough to fix it during the audit, then the auditor need only verify it and note that in the report.
It's all so damned trivial! With so many, many other important issues to focus on, I just loathe seeing time, effort and money wasted on such trivia.
And so easy to avoid, in any case.
JaneB
#28
Very, very slippery. And there's no fun to be had, let alone value, in adopting such a course.
M Informational Interesting read for risk managers – The Psychology of Prediction Medical Device and FDA Regulations and Standards News 1
Ronen E Interesting Discussion Interesting view of EU Authorised Representative under MDR EU Medical Device Regulations 3
Sidney Vianna Interesting Discussion Interesting article form the UNIDO Magazine - CSR: a wolf in sheep’s clothing? Sustainability, Green Initiatives and Ecology 16
Sidney Vianna Interesting Discussion ISO 9001 audits from the perspective of registrants' customers - an interesting paper Registrars and Notified Bodies 0
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
M Medical Device News EU interesting developments – embracing MDSAP and UDI alignment Medical Device and FDA Regulations and Standards News 0
J ASQ Chicago Training Institute - If any of you are interesting in teaching ASQ Certification preparation ASQ - American Society for Quality 1
N Dream Log - Occasionally I have some interesting Dreams Coffee Break and Water Cooler Discussions 27
H Interesting Article:Weak Supplier Relations Costing Big 3 Automakers, Nissan Billions World News 4
S Interesting Medical Device Database Site (666,413 items listed) Other Medical Device and Orthopedic Related Topics 1
B Share ideas to make Management Review more interesting Management Review Meetings and related Processes 4
N Interesting Purchase Order for its Terms and Conditions Quality Manager and Management Related Issues 82
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
V Medical Device Conference - May 2014 - Interesting topics and presentations Book, Video, Blog and Web Site Reviews and Recommendations 1
A Interesting article - Economics of Environmentalism Coffee Break and Water Cooler Discussions 0
Hershal Interesting Israel Holiday Coffee Break and Water Cooler Discussions 6
Randy Interesting lady I met today Coffee Break and Water Cooler Discussions 5
S Interesting ITAR related question from our Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R AS9100C vs. AS9101D 7.6 c.) - Interesting how meanings change AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
M Interesting article - Analysis of Risk: Are Current Methods Theoretically Sound? ISO 14971 - Medical Device Risk Management 7
GStough Verisys Registrars - Interesting Statements on Their Web Site Registrars and Notified Bodies 2
RoxaneB My train ride with the world's most interesting person... Coffee Break and Water Cooler Discussions 29
J Interesting humor cartoons and videos for quality awareness training Training - Internal, External, Online and Distance Learning 4
D Interesting graphic of BCS (college football coaches' ballots) Poll Coffee Break and Water Cooler Discussions 5
V Interesting quiz, case studies or exercises for AS9120 needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Steve Prevette An interesting paper on Lean Lean in Manufacturing and Service Industries 13
Q How can I make the QMS (Quality Management System) interesting to employees? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
Jim Wynne An interesting antivirus experience - A "dynamic" test After Work and Weekend Discussion Topics 14
Claes Gefvenberg Interesting Cove signatures Coffee Break and Water Cooler Discussions 65
F CAPA Training - Tips on making CAPA training topics interesting! Nonconformance and Corrective Action 3
K Management Buy In - Management has presented some interesting challenges IATF 16949 - Automotive Quality Systems Standard 11
Jim Wynne Interesting Signs - Possible new OSHA requirement? Funny Stuff - Jokes and Humour 7
V Interesting presentation about QUALITY Coffee Break and Water Cooler Discussions 8
A Need help with creating useful, interesting and good internal web site about QMS!!! After Work and Weekend Discussion Topics 5
J Some interesting information for those who are interested in ISO/TS 16949:2002 IATF 16949 - Automotive Quality Systems Standard 3
Claes Gefvenberg An interesting audit coming up - First combined ISO 9001 / 14001 surveillance audit General Auditing Discussions 6
E Some Interesting Sites Unrelated to Quality Coffee Break and Water Cooler Discussions 11
A Interesting audit request - Full reaudit when separating R&D from division General Auditing Discussions 6
W FPS (Ford production system) - Does anybody have any interesting comments? Customer and Company Specific Requirements 8
Marc An Interesting Failure Analysis - Ejection Seat Failure Nonconformance and Corrective Action 8
A Firestone Articles (Other Interesting Articles) World News 35
B Keeping the induction group awake - Interesting training exercises to share? Training - Internal, External, Online and Distance Learning 14
D Interesting Web Sites, Boards & other resources on Stats Statistical Analysis Tools, Techniques and SPC 4
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
E When to generate a nonconformance report ISO 13485:2016 - Medical Device Quality Management Systems 6
