Intergrating multiple forms (i.e. RMA,CAPA)
maxwell
Greetings Everyone:
I work for a medical device manufacturer, My boss wants to intergrate the return material authorization & corrective and preventive action & Failure Analysis form into one form. I have always used the forms as standalone. I would appreciate any feedback the group can give.
Thank You
Jerrylee1
Helmut Jilling
Auditor / Consultant
Greetings Everyone:
Thank You
Jerrylee1
That is certainly possible. It would have to address the requirements of a CA/PA situation, and still contain the fields you need for RMA. It can even address CA's for internal audits, if you want.
A simple way to approach would be to lay the two side by side and look for the similarities. If that makes sense to you, then just begin to build it together.
When you are done, use the draft a few times to tweak and adjust it until you hav ewhat you need. It is also a good idea to add a few check boxes at the top to make it clear if you are using it as an RMA, a CA or a PA.
C Logan
I am currently looking at combining the CAPA, Audit Nonconforming together. My last company had them all combined and when I cam on board this new company they have a different form for everything. Driving me crazy, lots of work to track & control because they also have seperate control systems for each one. I like your idea of including the RMA in as well. Thanks for the idea. I will do that to.:thanx: I would appreciate any examples other folks have as well.
Randy
Welcome.:bigwave:
We have a great deal of information for the novice user for Cove stuff. Just check the title page out.
To help you out here go to top of this page, left side, green tab "Post Attachments List", you'll probably find dozens. Also try the "Search" tool to help you.
Good luck
C Logan
Randy I have a really dumb question.
Where is the title page?
I also do not see a Green tab labeled "Post Attachments List"
Randy
Not a problem....The 1st page that comes up when you log in, or the front page that lists all the areas of discussion is essentially a title page
There is a green little rectangle labeled "POST ATTACHMENTS LIST" at the upper left hand corner in between the picture of the lighthouse and the lightning strike....click it! You will get a lsiting of over 1000 attachments that are free for you to use. What you are searching for will be in there...trust me.
Daryl
I am flip flopping on this topic - I used to try to integrate the CA activity onto other forms, but I have found that it becomes hard to track all of the actions starting from these forms (i.e. a CA section on a NCR form , a CA section on a customer complaint form....).
I now find it easier to close off these forms by referring to a CA (noting the reference number) and track only the CAs.
Daryl
SteelMaiden
We also start with a "CAR" and include the other stuff (RMA) in it. Except we do not even call them a CAR. They are an issue, each assigned a number. We have a problem description, list of material within the issue, root cause analysis, actions to be taken (if required), material return authorization and our own internal return documentation, credit or debit memo authorization and information.
E Intergrating TS16949 with ISO 14001 Management Systems ISO 14001:2015 Specific Discussions 8
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
C Multiple owners for one listed device Medical Device and FDA Regulations and Standards News 1
A CE-IVD Technical File with Multiple IFUs EU Medical Device Regulations 4
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
K Multiple function device products EU Medical Device Regulations 0
O Are power distribution units Multiple Socket Outlets (MSOs)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
C Contract Review with Multiple Line items ISO 13485:2016 - Medical Device Quality Management Systems 7
I Cannot Export multiple sections from Excel to PDF without losing pagination Excel .xls Spreadsheet Templates and Tools 23
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B QMS question in regards to multiple medical devices/products and N/A activities Other Medical Device Related Standards 12
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
D Reduction of software class based on multiple external risk controls IEC 62304 - Medical Device Software Life Cycle Processes 5
S Samples for GR&R - Can we get the 10 samples from multiple models Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
C FDA Registration Requirements for Multiple Sites 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
C Can a manufacturer (in South of Korea) have multiple Brazil Registration Holder (BRH) for same brend name? Other Medical Device Regulations World-Wide 1
S Multiple Authorized Reps in the EU for the same device? EU Medical Device Regulations 3
S Providing IFU (Instructions for Use) in multiple languages EU Medical Device Regulations 0
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
B AS9100 Multiple Distributor warehousing locations under same Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 3
E Informational Internal Audits - Wear multiple hats what can and can't I audit (so I'm not auditing my own work) Internal Auditing 149
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 2
L Control Plan - Multiple Process Steps FMEA and Control Plans 8
K Internal Auditing - Umbrella QMS and Multiple Standards Oil and Gas Industry Standards and Regulations 4
M Multiple missed POs grounds for SCAR? ISO 13485:2016 - Medical Device Quality Management Systems 32
G Single DFU for multiple medical devices in one box Other Medical Device Regulations World-Wide 0
J Brazil GMP license work with multiple BRH? Other Medical Device Regulations World-Wide 3
E Multiple socket-outlets - Medical Device Electrical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
F Marketing a single medical device with multiple indications Other US Medical Device Regulations 4
M IATF 16949 - Multiple Locations - 3rd party audit scope IATF 16949 - Automotive Quality Systems Standard 1
Q IATF 16949 Scope - Producing multiple products IATF 16949 - Automotive Quality Systems Standard 5
S Language of procedures when operating in multiple countries ISO 13485:2016 - Medical Device Quality Management Systems 4
A Working for multiple CB's (Certification Bodies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
K IEC 60601-1 Testing for Multiple Socket Outlet (MSO) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
H CE Marking on Multiple-Components Medical Products EU Medical Device Regulations 8
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D Implementing 5S for Multiple Shop Floor Layout Workstations Lean in Manufacturing and Service Industries 2
P Multiple Certifications - Is there an order of precedence? Other ISO and International Standards and European Regulations 3
M FDA UDI with Multiple Packaging Configurations Other US Medical Device Regulations 3
G Gage R&R Across Multiple Sites in a Company Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
3 Egypt: Multiple Registrations of the Same Product Other Medical Device Regulations World-Wide 2
3 Multiple registrations / authorized representatives in Iran Other Medical Device Regulations World-Wide 4
R Excel Dashboard for Health Safety and Environmental KPI's for Multiple Sites Occupational Health & Safety Management Standards 4
