Internal and external auditor competency to CSR's
joekirk
#11
A better way for the auditor to ask this question may be "When a customer updates a CSR, how are these changes communicated to your internal auditors?"
Many organizations document when a CSR is changed and forwards these changes or the new CSR to applicable process owners AND internal auditors for review and keep a record of it.
Many CB's actually do request what your customers are and CSR's you have (revision) as part of the inputs for audit planning.
Golfman25
#12
See, to me that is the problem. Sure when a CSR is changed, you review and update your process as needed. However, to "train" your auditors may just be a waste of time. As long as the auditors incorporate the current version of the CSRs into their audit, I think you should be good. The auditor should pick up any changes in the pre-audit review, as opposed to "remembering" them from 8 months ago.
malasuerte
#13
joekirk
#14
I guess I have a different take: CSRs are located at: Customer Specific Requirements – International Automotive Task Force Part of our auditor training is the 'competency' to audit for any of these requirements. We show that the auditors understand any CSRs ad what to look for in the areas.
Correct. Auditors should be aware of where to find the latest copy of the applicable CSR's and audit records should show that CSR requirements were reviewed during the internal audit process. Key word to it all is competency and your ability to show auditors (internal in this case) are competent to the latest CSR's.
John C. Abnet
Teacher, sensei, kennari
#16
None of this attests that the internal auditors are competent in assessing CSR's.
@Sidney Vianna is correct.
Consider it in the example of a football match....
The team watches film and trains in the preseason and prior to the match. They are indeed trained. They lose the match 12-0 . They did not demonstrate competence.
Another...
A potential driver takes a class and test and is awarded a driver's license. She/he is trained and has a license to prove it. She/he has one wreck a week for the next five weeks. She/he did not demonstrate competence.
Think of "competence" as actual performance results (output), NOT the training (input).
Hope this helps.
Be well.
joekirk
#17
If an auditor is aware of the CSR's and it can be shown that they have audited to the CSR's, how can you say that this does not demonstrate competency?
They only way that I would right up a finding against internal auditor competency related to CSR's would be if I found something like:
- Internal audit records could not demonstrate that CSR's were audited.
- Internal auditors reviewed did not have a clue as to what a CSR was.
- No CSR matrix / table indicating where within the organization's quality management system their customer-specific requirements are addressed.
Competency can be demonstrated through formal training, informal training, records of work, etc... You don't have to possess a certificate to show competency.
joekirk
#19
I can read a book about brain surgery. I can operate on a brain. That does not make me a competent brain surgeon.
But that would make your more competent than someone who has not read a book...
Bottomline regarding competency is that the auditee needs to show the auditor how you determine or demonstrate your employee is competent. The standard(s) do not define how you do it.
Sidney Vianna
Post Responsibly
#20
Not really.
There is a NORMATIVE definition of competence: ability to apply knowledge and skills to achieve intended results. If you put a document control clerk, with zero knowledge of engineering principles to perform an internal audit of a highly technical process, chances are, that audit will be a fiasco. The process to determine competence, what, by the way, is a variable and not an attribute, has to take into account knowledge and skills. It is NOT whatever do what you say, say what you do.
A External Auditor issue with Internal Audits Internal Auditing 7
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Can An External Auditor Also Write The Same Non-Conformance As An Internal Auditor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Can I join External or Online Internal Auditor Courses Apart from my Company...? Training - Internal, External, Online and Distance Learning 4
S External Auditor Findings when an Internal Audit found a Nonconformance Yesterday Document Control Systems, Procedures, Forms and Templates 11
P External Contract Auditor for Internal Quality Audit Internal Auditing 18
W External Consultant as Internal Auditor - Can NC be issued by TS Auditor? Internal Auditing 18
B Internal Auditor Training - Shadowing external auditor? Internal Auditing 18
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
D Necessity of external watchdog next to internal watchdog ISO 14971 - Medical Device Risk Management 1
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
T Relevant internal and external communication - ISO 9001:2015 section 7.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Examples of the external and internal issues and their risks and opportunities IATF 16949 - Automotive Quality Systems Standard 2
Y ISO 9001:2015 Cl. 4.1 Note 1 - External and Internal issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
qualprod External/internal issues removed as well? ISO 9001:2015 Cl. 4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V PPM - Internal PPM / External PPM Quality Manager and Management Related Issues 4
M How to Document Internal & External Communications - Suggestions/examples pls IATF 16949 - Automotive Quality Systems Standard 3
Q Managing Internal/External RNC and Complaints in same Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Metric/Way to show how Internal DPPM and External DPPM relate to each other Nonconformance and Corrective Action 1
P Is Internal and external audit of Account Department applicable to any ISO standard Internal Auditing 5
M Internal Audit finding versus External Audit finding General Auditing Discussions 2
G Scope of External & Internal Audits General Auditing Discussions 10
D Combining Internal & External Corrective Action Requests Nonconformance and Corrective Action 5
K Free from any Undue Internal and External Pressures - 4.1.5b clarification General Measurement Device and Calibration Topics 2
Z Predicting External PPM Capability from Internal PPM Capability, Accuracy and Stability - Processes, Machines, etc. 1
T ISO 17025 - 4.1.5b Internal/External commercial, financial, and other pressures ISO 17025 related Discussions 3
G Internal vs. External PFMEA Severity Rankings FMEA and Control Plans 12
V Most Common Internal/External Audit Observations on Risk Management ISO 14971 - Medical Device Risk Management 4
S Internal and External Audit Programme Implementation Internal Auditing 6
S How to quantify the Benefits of Internal and External OHS audits? Occupational Health & Safety Management Standards 4
M Internal and External Customer Survey Procedure and Form examples wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Critical Action Limits (CAL) for All Internal and External Audit Findings General Auditing Discussions 17
D External Parties performing Internal Audits? TS 16949 Clause 8.2.2 IATF 16949 - Automotive Quality Systems Standard 15
S External or Internal Design Change and Responsibilities Document Control Systems, Procedures, Forms and Templates 3
R ISO 9001 Internal Quality Audit by Consultants (External agency) Internal Auditing 5
D Internal or External PPM form or template wanted Document Control Systems, Procedures, Forms and Templates 5
P Can External Audits by Customer be treated As Internal Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
P 7.6.3 Internal or External Laboratory? Measuring instruments used in production IATF 16949 - Automotive Quality Systems Standard 9
E First external audit coming up, do I need to have performed Internal Audits already? Internal Auditing 15
C Document Control for External and Internal Projects (overseas projects) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Audit Database that captures internal, external audits - Prime Part 21 manufacturer Quality Assurance and Compliance Software Tools and Solutions 12
P Internal vs. external audit training course differences? Internal Auditing 18
H Internal / External Auditors from the same Field / Section / Group? Internal Auditing 2
R ISO 9001 Internal & External Communication Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P How do you decide what is an acceptable Internal and External PPM number? IATF 16949 - Automotive Quality Systems Standard 17
N Handling External Audits with Internal Vacations General Auditing Discussions 101
A External Audit CAR when Internal Audit CAR is in process? General Auditing Discussions 34
F The difference between External Records vs. Internal Records Records and Data - Quality, Legal and Other Evidence 11
N "For Reference Only" - Internal and External Documents Document Control Systems, Procedures, Forms and Templates 14
B Internal Audits save you from Non-Conformances on external audits? General Auditing Discussions 16
