Internal Audit finding leading to 'Punishment' (Disciplinary Action) - Your Thoughts?
Weiner Dog
Med Device Consultant
#61
Re: Internal Audit finding leading to 'Punishment' (Disciplinary Action) - Your Thoug
Just from the title- the top or mid management does not get quality. The system not people is broken. Fix the system not punish the people.
When auditing the department I found that one supervisor did not performe the requested checks and the person who should check the supervisors had not seen this.
When reporting this the department manager he doesn't take the planned correction for non-compliances identified.
When reporting this to the general manager ....
When reporting this to the company manager ....
I think that we have to go home and doing something of better than fight against windmills
:truce:
bobdoering
Stop X-bar/R Madness!!
#62
The problem is as follows: last month we had a rather serious complaint from one of our customers. The cause of this was a human error (operator mistake) and his supervisor did not check the operators work as agreed.
Because of this some additional check’s have been added by the responsible management and the supervisors are told that ‘forgetting’ a check will have serious consequences. Also there is someone within the company appointed to check the supervisors.
Hey, look! They reinvented the Layered Audit process from the automotive realm!
When auditing there is some trust between auditor and auditee. When using audit results for punishment this trust is violated. Management does not agree with this and insists on using audit results for this purpose.
To a degree, fear will have the auditees clam up and hide things. On the other hand, if objective evidence is found that someone did not follow the system, then there needs to be an appropriate 'corrective action.' Saying it is an audit of the system and not of the people can be a cop out. There are certain responsibilities for people within a system - or it would be a 100% poke-a-yoke automated 'lights out' system (as in no people). If they willingly go against the system, then you can not always blame the system.
Wes Bucey
#63
Not a cop out!
Root cause first:
WHY did employee not do job?
  • Understanding?
  • Physically or mentally incapable?
  • Poorly trained?
  • Too rushed?
  • Wrong tools?
  • Sabotage? (WHY?)
  • etc. etc.
Ultimately, Deming had it right - it's up to management to put SYSTEMS in motion to eliminate or ameliorate causes of variation or nonconformance.
Perhaps the system to hire such nonconforming employees was faulty? Whose fault was that?
Even Harry Truman had it right: "The buck stops here!" [at the top]
#64
Not a cop out!
Root cause first:
  • Understanding?
  • Poorly trained?
  • Too rushed?
  • Wrong tools?
  • Sabotage? (WHY?)
  • etc. etc.
It's trivially true that the system is the leading cause of errors, but it's just as trivially true (to those who think about it rather than regurgitating--and/or misunderstanding--their guru's aphorisms) that people make innocent mistakes that are not assignable to the system.
As I said nearly four years ago, further up the thread,
Just as with machines, there are patterns of human behavior that can serve to indicate when a point beyond the control limits is just "noise" (an unavoidable error) or when it's part of a trend that requires management intervention. This should in no way be interpreted as dehumanization; the simple fact is that nature (even human nature) exhibits predictable patterns, and managers need to know when a pattern requires intervention and when to leave well enough alone.
Jen Kirley
Quality and Auditing Expert
#66
Inevitably we will eventually find someone who is not working on a task that is suitable to their abilities and/or temperament.
The temperament - even a psychological issue like a personality disorder - could be at the root of choosing to not adhere to process. However, my long and storied experience with kids, animals and adults has left me convinced that disciplinary responses to discovering the "failure" in whatever way don't reliably change temperament. If a person is unsuitable because of lacking sufficient intrinsic motivation, we have HR to address that personnel issue. I approached this subject a little in my When Employees Don't Follow Procedures paper.
The audit should only be a portal for discovery of an issue. If the issue is more widespread than a once-or-twice occurrence, the audit is followed up by a discovery process. From there the human issues are separated out from material, machine and culture factors. No internal audit finding should be the reason for disciplinary action. I do not think this is a copout, I just think a more pragmatic approach is needed for deciding on need for discipline.
bobdoering
#67
It can be.
Root cause first:
  • Understanding?
  • Poorly trained?
  • Too rushed?
  • Wrong tools?
  • Sabotage? (WHY?)
  • etc. etc.
Maybe they were not nonconforming when they were hired, but became that way. Should we chart their behavior so we can predict when they are going to become nonconforming? We may find a measureable...(Deming would love that.) Maybe it was an issue outside of the firm that was the root cause. Maybe the boss cut them off in the parking lot - or the employee thought he did. Is that the system's fault? Must the system have so many redundant systems and measures to trap every human misdeed prior to it being made? The "system" does not generate and maintain automatons or marionettes. Sure, the system can be the cause and, sure, it should be the first place to look. But, it is not the only root cause. I am not buying it - no matter what Deming says. I think even he would assign a probability to it.
Bill Pflanz
#68
I think Jennifer is correct. More than likely if there is a need for discipline it has more behind it then one isolated finding during an audit. As an auditor I would not like to see management use it as a replacement for their own responsibiblity for identifying and correcting problems that need a disciplinary review. I have had managers whose first response for corrective action implied disciplining the person and I immediately counseled them on the need for review of the process rather than blaming an individual.
Bill Pflanz
Jen Kirley
#69
It can be.
Your focus appears to assign a physical meaning to the term system. I think what Deming was trying to say is that managers shouldn't be off the hook with personnel problems, just as with process malfunctions. If poison people impact the motivation or performance of others, there should be an effective system to deal with that, and it should be used so the caring workers can get to the business of doing their work well.
A good management system should include the human performance management element by removing constraints to good performance in whichever appropriate way: technical, material or emotional. So yes, in that context it is a system problem.
bobdoering
#70
I don't have a problem using the term 'system' that globally! But, that would make the mantra: "It is an audit of the system. People are a part of the system." That I would by very readily! That would cover those 'constraints' of the various human 'defects' that can occur...as special causes, one would hope - not common ones!
S GM/VP softgrading internal audit finding - need feedback from an audit guru! General Auditing Discussions 11
A Writing an Internal Audit Report Finding for Employee Awareness of QMS Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Internal Audit finding versus External Audit finding General Auditing Discussions 2
L Internal Re-audit after Major Finding during ISO 9001 Re-Certification Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K ISO 13485 Audit Finding on Regulatory Issues - Internal Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
S Internal Audit Finding relating to Superseded Documentation Document Control Systems, Procedures, Forms and Templates 36
P Internal Audit Finding - Root Cause Analysis: Auditor or an Auditee Responsibility? Internal Auditing 24
6 Management Review does not highlight Internal Audit Finding - Root Cause Analysis General Auditing Discussions 11
G Is this an internal audit finding or not Internal Auditing 8
C How to analyse the internal audit finding in term of discrepancy Internal Auditing 4
J Internal Audit Findings - Major vs. Minor Finding - Defining the differences Internal Auditing 14
S Failure to Close Out an Internal Audit Finding Internal Auditing 20
A Definition Major vs. Minor Nonconformance (Finding) - Internal Audit - Definition & Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 38
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
T Internal Audit Schedule when Hiring Out Internal Auditing 7
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
M Internal audit consultant ISO 13485 (English speaker) Consultants and Consulting 3
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
F Internal Audit - Procedure example Internal Auditing 5
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
