Internal Audit Finding - Root Cause Analysis: Auditor or an Auditee Responsibility?
P
Polly Pure Bread
Is it a good idea that an investigation to find root cause be part of itinerary of the auditor after discussing findings and deficiencies during closing meeting? Isn’t RCA the responsibility of auditee? The bottom line: prime responsibility is to present a true and fair review of the status of the management system.
Re: Root Cause Analysis: Responsibility of an Auditor or an Auditee?
What a great question!
I believe that there's a difference between the two points you make. It is the (internal) auditor's job to diagnose and report on the effectiveness of the management system, in a fair and true manner. Any findings should be a 'launching point' for management to be able to take action. It would be inappropriate for an auditor to be 'working on' RCA, during the audit.
JaneB
Yes, it is a good question.
Andy, I agree that an internal auditor (I assume that's what you mean by auditor, dqA? couldn't work on it during the audit, but the question was about after the closing meeting, ie, after the audit.
In which case I think an internal auditor might be part of such a group, and their presence might be useful. But only as an extra resource/other set of eyes: it is very definitely not their responsibility to find root cause. :nope:
I would beware any thing that might suggest that or blur the lines of what audit is and is not. Apart from other issues, you can and probably will get the department/team/area manager's nose seriously out of joint (not surprisingly) if an auditor not only comes in & audits and then reports on their findings but also thendiagnoses why the problems exist. It's the manager's job to investigate and rectify, not the auditor's. The auditor can't possibly know as much about it as the manager (or shouldn't!)
amanbhai
It is a misconception about the internal audits.
Management in many organizations believe that internal auditor is hired to audit and improve and it is therefore his resopnsibility to investigate the RCA and suggest the corrective actions accordingly. If he doesn't he is just wasting our time and money.
P
Polly Pure Bread
Thank you, Andy and Ms Jane. But how can an auditor get the truth without doing root cause analysis?
As for Ms Jane’s clarificatory question, yes I am referring to internal auditor.
Likes: db
anil123
Root cause analysis is the responsibility of the auditee not of auditor. Auditor is only disclose the fact against the written requirements.
I believe this is a different question to your original post. It is the job of an auditor to plan and prepare information before conducting the audit. This is why the use of canned, pre-prepared checklists are virtually useless.
Once prepared with details of process performance issues, knowledge of process, etc., then the auditor interviews, seeks objective evidence etc to verify the qms. It's an investigation into the implementation of the system and the results. That's where the skills of the auditor are paramount.
There is a difference in an auditor determining a relationship between process and performance and the process owner determining a cause.
One day - if I had my way - internal audits would be done to determine root cause instead of hanging on to old-fashioned externally based audit principles of 'independence' and such. In a new world order, internal auditors should operate as SSGBs!
Brunetta
I think you are asking
Does the auditor need to determine the "why" a problem is happening to really ascertain that there is a "true" nonconformity?
In our audit process...the auditors look at the requirements of the system, then observe the system (process in action, interviews, record reviews, etc.) and assess if it meets the requirements or not. If the auditor concludes that something does not meet the requirements this is noted in the standard manner i.e. requirement, failure noted, supporting evidence.
Then this is discussed either at the closing meeting or brought to the process owners attention during the audit. Sometimes additional evidence is presented at that time that clarifies if something does or does not comply to both parties. The important thing is that both parties (auditor and auditee) have a full understanding of what was found and agree there is a failure prior to the finding being finalized and placed into our reports.
We also have the option in our audit process to have the auditor assist as a consulting participant in the corrective action plan. However, if the auditor participates in this manner the auditor is then restricted from auditing the process with the issue for a year to ensure impartiality of the next audit.
I hope this helps to answer your question.
~Brunetta
Brunetta
Re: Internal Audit Finding - Root Cause Analysis: Auditor or an Auditee Responsibilit
Whoops, apparently AndyN is a faster typer than I am! :eek:
... But how can an auditor get the truth without doing root cause analysis?
Auditors deal with symptoms.... When a nonconformity is discovered, it is just a symptom of an underlying problem. The auditor's value is in showing how this symptom adversely affects the organization.
The auditor can assist in the root cause by explaining symptoms and effects, but it really has to be the process owner/ management to discover what the root cause is. The auditor then can assist is looking at corrective actions to ensure the action will be effective.
S GM/VP softgrading internal audit finding - need feedback from an audit guru! General Auditing Discussions 11
A Writing an Internal Audit Report Finding for Employee Awareness of QMS Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Internal Audit finding versus External Audit finding General Auditing Discussions 2
L Internal Re-audit after Major Finding during ISO 9001 Re-Certification Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K ISO 13485 Audit Finding on Regulatory Issues - Internal Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
S Internal Audit Finding relating to Superseded Documentation Document Control Systems, Procedures, Forms and Templates 36
6 Management Review does not highlight Internal Audit Finding - Root Cause Analysis General Auditing Discussions 11
G Is this an internal audit finding or not Internal Auditing 8
M Internal Audit finding leading to 'Punishment' (Disciplinary Action) - Your Thoughts? Internal Auditing 79
C How to analyse the internal audit finding in term of discrepancy Internal Auditing 4
J Internal Audit Findings - Major vs. Minor Finding - Defining the differences Internal Auditing 14
S Failure to Close Out an Internal Audit Finding Internal Auditing 20
A Definition Major vs. Minor Nonconformance (Finding) - Internal Audit - Definition & Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 38
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
T Internal Audit Schedule when Hiring Out Internal Auditing 7
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
M Internal audit consultant ISO 13485 (English speaker) Consultants and Consulting 3
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
F Internal Audit - Procedure example Internal Auditing 5
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
