Internal Audit Findings and Issuance Problem
Muhd Firdaus
Dear All,
i have conducted internal audit for QA Department and want to issue NCR
for them due to the followings:
1)One Corrective Action Request has not been closed after the due date,
7 days from the date of issuance
2)One Corrective action Request has been replied by the process owner.
However,thre is no indication to show that the contermeasure given
has been verified for its effectiveness by QA Department as to close the CAR.
3) One Corrective Action Request already replied and closed. However ,the status of the report not updated into CAR REGISTER.
i am not sure which clause in ISO9001:2008 that i can use to issue my findings to QA Department. Kindly assist
insect warfare
QA=Question Authority
Why do you want to cite an ISO 9001 requirement (other than your system has not matured enough to the point that you can simply rely on your QMS procedures as requirements)? A better suggestion would be to cite the actual requirement from your corrective action procedure - there should be supplemental controls already documented for closing CAR's and such. If no such controls are present there, then the problem would lie in the corrective action procedure itself, and (just to bake your noodle even further) the resulting NCR may not even end up the responsibility of QA, but rather the person in charge of managing the corrective action process (which may or may not be QA depending on your system in place).
I would also check what you have in place for control of records, and training/evaluation to see if there are any glaring omissions or gaps in those processes as well. If your system has matured enough, your QMS procedures should act as the primary source of your requirements, with ISO requirements being only secondary in nature, otherwise you are only operating in the spirit of "conformance" and not "continual improvement".
Brian :rolleyes:
SuperGirl
I second this.
I am not sure I would issue against the standard.
1) The late CAR. Where did the "due date" come from? Since that came from your own documentation, I would use that as the requirement/standard. If you have to write to the standard, you would be looking at 8.2.2 "The management responsible for the area being audited shall ensure that any necessary corrections and corrective actions are taken without undue delay..."
2) The CAR countermeasure not being verified. This one is a little stronger to the standard, also in 8.2.2 "Follow-up activities shall include the verification of the actions taken... " However, it could be argued that the internal audit was the follow-up activity. Again your local documentation may be more specific on closing out CARs
3) The CAR register not being updated. ISO 9001 does not mandate a CAR register. Again, somewhere in your local documentation it should mandate the register and look there for the requirement for updating it. If you have to go back to the standard, I would look at 4.2.4
I always recommend writing to the lowest possible documentation level. I also highly recommend quoting the actual "shall" that is being violated.
Hope that helps.
Dear All,
Why do you have to cite an ISO clause? Will it make any difference to the finding? Will it matter to anyone else?
A Internal Audit - Findings - Recent Internet Audit (Prior to Certification) IEC 27001 - Information Security Management Systems (ISMS) 7
dubrizo Are you documenting Internal Audit findings as NCRs? Internal Auditing 18
dubrizo Audit Findings: Writing against Internal an ISO Clause Internal Auditing 10
M Do all findings (nonconformities) in an internal audit require a corrective action? Quality Management System (QMS) Manuals 55
S Internal Audit Findings Summary Rewrite by an Auditee ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Help with Internal Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Types of Internal Audit findings based on ISO 9001 Clause 8.2.2 Quality Manager and Management Related Issues 10
D Management Review Analysis of Internal Audit Findings Quality Manager and Management Related Issues 8
A How to Address Internal Quality Audit Findings Internal Auditing 8
B Critical Action Limits (CAL) for All Internal and External Audit Findings General Auditing Discussions 17
X ISO 9001:2008 Internal Audit - Classification of Audit Findings Internal Auditing 5
S External Auditor Findings when an Internal Audit found a Nonconformance Yesterday Document Control Systems, Procedures, Forms and Templates 11
L Categorizing Internal Audit Findings Internal Auditing 10
Michael Malis For Internal Audit findings, would you open a CAPA for every observation? Internal Auditing 31
E Internal Audits - Presenting Audit Findings to Upper Management General Auditing Discussions 19
V Documenting the Root Causes for Internal Audit Non-Conformance Findings Problem Solving, Root Cause Fault and Failure Analysis 5
C Internal Audit Findings - Do I need to raise NC for amendments/revisions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
eternal_atlas Review on Internal Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
eternal_atlas Internal Audit Findings in C&M works (HVAC, Firefighting, etc.) - Your Comments? General Auditing Discussions 6
R When and when not to write up minor internal audit findings? Internal Auditing 23
A Format for Reporting Internal Audit Findings General Auditing Discussions 17
J Nonconformance reports written only through internal audit findings? Nonconformance and Corrective Action 8
S How to Present Action Plans in Response to Internal Audit Findings? Preventive Action and Continuous Improvement 18
J Internal Audit Findings - Major vs. Minor Finding - Defining the differences Internal Auditing 14
Marc Internal Audit Findings and the Registrar Internal Auditing 5
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
