Internal Audit for Project Management Team - Construction Industry
E
Elynn
Need help here... anyone has the template for project management, in particular, in the construction industry? I know this should be customised to the PM practices, and so I am request if anyone can share for my reference?
Stijloor
Any construction industry experts who can help?
Thank you!!
Stijloor.
Pancho
wikineer
The PM BOK Guide is a good resource that describes Project Management using the process approach.
Here is what we use for our PM process. It is based on the PM BOK Guide:
Description of the Project Management Process
  1. Objective: Plan, execute, monitor, control and close all internal and external projects.
  2. Scope: Applies to all projects, including those for delivery to clients as well as those for improvement.
  3. Owner or Manager: Projects Director
  4. Participants: Project Manager, Engineering Director, CFO, EVP, CEO, Project Engineer, Job administrator, Site Consultant.
  5. Inputs: Signed Contract (for external projects), Project Charter (for internal projects)
  6. Outputs:
    1. Correspondence with client. See [WI: Project Correspondence]
    2. External wiki. See [DR: Projects wiki]
      1. Deliverables by engineering, production, quality and logistics
      2. External Schedule
      3. Invoices and shipping documents
    3. Internal wiki. See [DR: Projects wiki]
      1. ToDo
      2. Internal Schedule
      3. Budget and Forecasts
      4. Drafts of Correspondence
      5. Installation reports
      6. Project KPIs
  7. Clients
    1. Project Client (external or internal)
    2. Delivery Processes
      1. [DP: Engineering]
      2. [DP: Purchasing]
      3. [DP: Production]
      4. [DP: Installation]
    3. [DP: Finance]
  8. Performance Indicators (KPIs) See [WI: KPIs Projects]
  9. Description - Geometrica's Project Management process is based on the "PMBOK Guide" of the Project Management Institute. For external projects, the Contract is the authoritative reference for the project's scope and conditions. For internal projects, the Project Charter provides this authority. These documents are filed in project's external wiki (see [DR: Projects wiki]). The following documents describe the major procedures to manage projects.
    1. [GP: Initiating Project]
    2. [GP: Project Planning]
    3. [GP: Project Execution]
    4. [GP: Project Monitoring and Control]
    5. [WI: Project Closure]
John Broomfield
Elynn,
You will find a basis for your checklist in an ASQ eBook called ISO 9001:2008 Interpretive Guide for the Design and Construction Project Team.
It interprets the standard from the client's viewpoint and from the designer and contractor's points of view.
It includes the full text of the standard and is cheaper than the standard.
It was written by the ASQ's Design and Construction Division but all the errors belong to me!
Publication E1364.
John
E
Elynn
I am not trained on construction industry and how a project is being managed in this aspect. However, reading the manual, it is broken down to 5 main processes :
1. Project feasibility Process (formulation, site acquisition, appointing proj manager)
2. Project Organisation Process (appoint consultants, finalise team, scope of service)
3. Concept Plan process (develop concept & cost plan, execute plan)
4. Design Development process (schematic design, tender documentation, submission, tender evaluation & award)
5. Construction and completion process (Safety Enforcement, Cost control, Defects, final project Report)
Can the IA template be created based on the processess?
John Broomfield
Elynn,
This rather depends on your audit objectives and the completion status of the project. If phase 4 is finished (except for change control) then you will be sampling rather more deeply in construction to determine whether design was well managed in terms of feasibility and constructability.
That said, yes, these processes would probably be a sound basis for your checklists.
Invest 50% of the audit investigation duration on planning your audit including the preparation of your checklists.
Make your checklist preparation part of the audit (documentation review) so your time with the auditee quickly and efficiently finishes the investigation because you are clear on:
  • What process controls/resources you are sampling
  • What evidence you seek
  • Why you are seeking that evidence
A thru C are column headings and the fourth column is for your notes.
You have not told us the objective of your audit but if it is to determine 1 and 2 below:
  1. Conformity of the project management system to ISO 9001
  2. Effectiveness of the project management system in fufilling its objectives
...ensure that your checklist samples enough evidence of conformity and effectiveness to fulfill the objective.
For achieving audit objective 1, use a sampling matrix showing the clauses from the standard against the names of the key players on the project so you can make sure that you are sampling all applicable parts of the system's conformity to the standard.
Remember that ISO 9001 does not require all procedures to be documented nor does it require people to conform to their procedures (it does however require process monitoring/measurement by the users of the PMS - 8.2.3).
If users of the PMS have found a more effective way to fulfill the process/project objectives without updating their procedures this may mean the system is not well maintained or that the improvement action is still being tried and tested before updating the system's documents.
Leave space between the rows of your checklist to infill supplementary lines of investigation and to record the evidence of conformity/effectiveness.
Do not provide the checklist to the auditees before the audit because this sets expectations and can inhibit your necessary but unscripted supplementary investigations (thereby undermining trust).
Focus not on seeking nonconformity. Instead engage the users on showing you how well the PMS (as documented and undocumented) is helping the project team to determine and fulfill requirements.
Make your notes openly so the providers of evidence can see what you are writing and trust you to provide more evidence especially where the system could be improved.
You could ask why they waited for the auditor before suggesting improvements to their system and this may lead to some interesting supplementary lines of investigation with the people who should have been monitoring/measuring their processes.
Be prepared and your diligence will serve you well,
John
E
Elynn
Big Thanks to John... I may be able to craft out something along your advice... The objective is very much similar to any audit for ISO 9001 but covering the "service" related to the PM for construction projects. The end product (or PM service) is normally a long period instead of most products and services which can be delivered over months. Hence, I am seeking to fulfill 2 - Effectiveness of the project management system in fufilling its objectives yet conform to the firm's ISO 9001 documentation system.
John Broomfield
Elynn,
You're welcome.
I see the product of effective project management as the completed project delivered on-time, to spec and within budget.
These three types of requirement comprise quality in the mind of the project's client. To spec should mean in accordance with the needs of the customer and other interested parties but rarely does the budget cover that!
Therefore these three types of requirement are reconciled with the client and the PM ensures milestones are agreed early in the project before breaking down the work so everyone has clear criteria for the work and for monitoring the progress of the work instead of discovering the nonconforming services at the end of the project.
In other words take a look at the work breakdown and each milestone to see if the criteria for managing the project enable preventive action or at least timely correction.
John
W
William01
Project management is a very important business concept; it is very useful for business and helps in the smooth flow of the project. It is better and safer to take the help of professional project management service. It will help in the smooth flow of the project and also helps one to keep a track on things going on.
F Airport Internal Audit Checklist (Cleaning, Project Process, Maintenance, etc) Internal Auditing 3
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
T Internal Audit Schedule when Hiring Out Internal Auditing 7
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
M Internal audit consultant ISO 13485 (English speaker) Consultants and Consulting 3
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
F Internal Audit - Procedure example Internal Auditing 5
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
M Internal Audit Plan in Retail Internal Auditing 10
D Management of NC after internal system audit IATF 16949 - Automotive Quality Systems Standard 7
A Purchasing - Internal Audit Questions Internal Auditing 8
N Comprehensive Compliance Matrix for Internal Audit Checklist Other Medical Device Regulations World-Wide 1
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
D Internal audit forms or checklists for a medical/veterinary laboratory General Auditing Discussions 5
E Informational Internal Audits - Wear multiple hats what can and can't I audit (so I'm not auditing my own work) Internal Auditing 149
E ISO 9001:2015 - Internal Audit Plan Clauses General Auditing Discussions 8
S Internal Audit Checklist for Application/Software development IEC 27001 - Information Security Management Systems (ISMS) 1
S Internal Audit - Risk and Opportunity (ISO 9001:2015 ) Internal Auditing 1
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
Ashland78 IATF 16949 Internal Audit Checklist Manufacturing and Related Processes 11
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
