Internal Audit Frequency - What does "at Planned Intervals" mean?
I could not find this topic so please forgive me. Our L2 Internal Audit Procedure says "A minimum of one audit should be completed annually to each defined QMS process to the requirements of AS9100."
The AS9101D says " at Planned intervals".
What does this mean exactly?
Doug:bigwave:
milind dhakad
Re: Internal Audit frequency?
It depend on the top Mangement attitude .But generally If you found that in yearly audit ,you have more Major NCR in the audit then you should have to increase the frequency . Also it depend on the attitude that how much importance is given for the implementation of ISO system in organization .
qusys
Doug:bigwave:
It is up to the organization to define the frequency of the internal audits.
The frequency could be increased in case of major problems in the organization ( major ncn, internal or external, complaints etc.):bigwave:
Doug:bigwave:
Donning my nit-picky auditor hat, there is a difference between "should be completed" and "must be completed."
SvanRaay
forgive me if i misunderstood, but what they are looking for is that you audit your QMS processes to a schedule. what they want to see is that you plan out audits ahead of time.
for instance, if your QMS has 4 core processes, then they would expect to see that each of these is audited at least once a year (per your procedure) and that you have the audits scheduled ahead of time. in this scenario, you would kinda expect to see audits done on a quarterly basis with the schedule identifying which core proscess is to be audited in which quarter. then they will want to see that audits are performed per that schedule.
somashekar
Doug:bigwave:
Changes are inevitable and continual improvement is desired in a management system. Business is dynamic and growth must be the order or business will be dynamic in the wrong direction. How do you assess all this within yourself.
As a part of the CHECK of the management system, you internal audit.
So your frequency must match the rate of change, continual improvement, growth such that management gets a timely feedback of the system performance. Where processes are found weak, more audits are planned to CHECK effectiveness of actions taken.
There is nothing annual about audit.
Yaaa, the CB come annually and if they find that you are not internally auditing anything between there two visits and they find you having deficiencies, you are gone >>>>
Now you decide what must be your planned interval.... :notme:
L
lyang
Your SOP defined planned interval to be one year (per approved audit schedule). You can change "planned interval" to mean daily, weekly, montly, quarterly, annually, etc... The selection of "planned interval" ultimately depends on your industry, resource and your last corrective action. A CAPA may cause a revisit in 6 months versus every 12 months.
Randy
Try this on for size...."Within a scheduled time-frame"
You define the time-frame (But be careful or you could wind up playing Russian Roulette with a single shot pistol in defining the time-frame)
I don't believe it's a matter of attitude! ISO 9000, 9001 and 9004 all make the point that management should use data!
We simply have to ensure two things - and there's a danger in taking one requirement/phrase of the standard and analyzing it in isolation of the others - because we have to consider:
Internal audits have to be performed at planned intervals and that an audit programme (a series of audits) has to be established taking into consideration etc...
It is not, despite conventional wisdom, necessary or even desirable to have a whole 12 month calendar of audits planned out, or that you commit to even doing an audit a month! You can decide on the prevailing business conditions if you need to do an audit a month for say the 'slow' period of the financial year, or increase them to weekly, when there's a push to get product shipped and invoiced at the end of the financial year, as examples.
You decide - but it had better be based on data...
R Internal Audit Frequency - Remote Site (a Design Center) IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 - Internal Audit Frequency Requirements Internal Auditing 2
F Changing the Frequency of Internal Audits - ISO/TS 16949 Internal Audit Requirements Internal Auditing 5
Q Reducing the Frequency of Audits - Internal Audit Programme 2012 Internal Auditing 13
P Advice about Internal Audit Frequency Internal Auditing 3
R Ideal Internal Audit Frequency and Scope - ISO 9001 Internal Auditing 6
B Internal audits 3 year plan? Internal audit frequency Internal Auditing 23
GStough Internal Audit Frequency Schedule: Monthly, Quarterly, or Bi-Annually? Internal Auditing 46
G Determining Internal Audit Frequency - ISO 9001 Clause 8.2.2.4 Internal Auditing 15
L Internal Audit Schedule - Frequency of internal audits Internal Auditing 9
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
T Internal Audit Schedule when Hiring Out Internal Auditing 7
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
M Internal audit consultant ISO 13485 (English speaker) Consultants and Consulting 3
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
F Internal Audit - Procedure example Internal Auditing 5
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
M Internal Audit Plan in Retail Internal Auditing 10
D Management of NC after internal system audit IATF 16949 - Automotive Quality Systems Standard 7
A Purchasing - Internal Audit Questions Internal Auditing 8
N Comprehensive Compliance Matrix for Internal Audit Checklist Other Medical Device Regulations World-Wide 1
