Internal Audit Nonconformances - Your opinion?
L
LesPiles
Hello!
We?re conducting an internal audit and I have 2 cases.
1) A "guide" exists for assembling a serie of products. This guide has not be maintained. Replaced by pictures but has no approvals, no id, not being archived, etc.
2) A welder machine was replaced but the procedure describing how to use the equipment has not been written and the document for the old one no longer applies.
These are "non-conformities" but yet the business has been able to ride without.
Would you advocate the issuance of two CARs?
Thank you in advance!
LesPiles
John Broomfield
Hello!
LesPiles
LesPiles,
Are you saying the process and its undocumented procedure remain effective even though someone has yet to update the documented procedure?
...in both cases?
Since bringing these nonconformities to the attention of management have they corrected them?
Did they also correct the reason for the documented procedure(s) not being kept up to date?
Investing the removal of the root causes to stop recurrence may not be required but this rather depends on whether nonconformities of this nature are chronic.
John
Mikishots
Hello!
We’re conducting an internal audit and I have 2 cases.
LesPiles
If I was using a standard like ISO 9001:2008:
1. If the guide is defined in the process as being the instructions to be used to assemble the product, then I would argue that production is not being carried out under controlled conditions. Control of documents would also need to be investigated, due to the lack of approval or identification.
2. A procedure for using the new welding equipment would only be required if the organization requires it (it's not a requirement of the standard). Competency of personnel (in this case, welders) would indicate that if a person is approved by the organization to weld, they would have the skill necessary to read the manual if they had any concerns with operating the gear (in order to produce compliant product).
Both of these situations are dependent on the organization - does it require these items? If it does, it makes no difference what the standard says.
Hello!
LesPiles
In the first case - do the people need the guide? It sounds as if not. So, would a simple correction be to remove it? You might ask yourself why this even exists if people are aware of the need for formal "controlled" documents? What are your management and supervision thinking,? Did they know about it?
In the second case - almost the same thing. As welders, controls are pretty much the same, so a "procedure" isn't going to bring much value. It's a bit like a car handbook - you drive, but you don't need the handbook, really - and all cars basic controls are somewhat in the same place. Does it affect driving? No....
BTW - doesn't matter "what standard?" There's nothing much in there to help you!
I'd check at another audit to see how "aware" management and supervision are about the availability of these types of documents and the need for control...
Marcelo
From the guide:
The auditor should requests information on the auditee's operating processes and subsequently ask questions, record answers and observe staff at all levels (including administrative personnel, process owners and operators), to confirm that the actual working status conforms to the descriptions given.
Thereafter, the necessity for any documentation should be evaluated in the light of the observed need for consistency, and the role that any documentation could play in avoiding any significant, identified risks.
So, if the processes are consistently achieving their objectives without the documentation, probably the documentation is not needed.
If that?s the case for the OP, there would be no NCs in principle.
K
kgott
Hello!
LesPiles
If it was me, I would not care whether or not we are certified or not certified to a standard, I would write some opportunities for improvement on this because there are opportunities to strengthen the processes and documentation used for delivering products and or services.
For me ISO 9001 requirements do not come into it.
What's necessary to improve here? You're falling into the trap that lots of auditors do by assuming something needs improvement. I don't see anything other than a couple of documents need throwing in the trash. Hardly "improvement"...
TWA - not the airline
The similarity does smell a little bit...If I came across this in an audit, I'd check into the doc control and the change management process. If that does not reveal a systematic root cause then this is rather an individual mistake thing that does not need more than simple correction...
R Internal Audit Cancellation when Nonconformances are Found Quality Manager and Management Related Issues 13
P Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
C Is NCR compulsory for all Nonconformances found during Internal Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Internal Audits and Nonconformances - Clause 8.2.2 Internal Audit (paragraph 4) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Internal Audit Nonconformances must be Closed prior to Registration? Internal Auditing 28
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
T Internal Audit Schedule when Hiring Out Internal Auditing 7
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
M Internal audit consultant ISO 13485 (English speaker) Consultants and Consulting 3
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
F Internal Audit - Procedure example Internal Auditing 5
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
M Internal Audit Plan in Retail Internal Auditing 10
D Management of NC after internal system audit IATF 16949 - Automotive Quality Systems Standard 7
A Purchasing - Internal Audit Questions Internal Auditing 8
N Comprehensive Compliance Matrix for Internal Audit Checklist Other Medical Device Regulations World-Wide 1
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
D Internal audit forms or checklists for a medical/veterinary laboratory General Auditing Discussions 5
E Informational Internal Audits - Wear multiple hats what can and can't I audit (so I'm not auditing my own work) Internal Auditing 149
E ISO 9001:2015 - Internal Audit Plan Clauses General Auditing Discussions 8
S Internal Audit Checklist for Application/Software development IEC 27001 - Information Security Management Systems (ISMS) 1
