Internal Audit Process Flow Chart - Please Review Mine and Comment!
David Hartman
#21
Randy Stewart said:
Internal or External???
In-fact some of the "improvements" that we implement as a company should be for our own benefit as a business. Such improvements as those that effect profitability (eliminating waste, increased productivity, etc.), some of which MAY be passed on to the customer - but may in fact be used for additional resources, R&D, etc. :bigwave:
I
ISO Cheesy
#23
Randy Stewart said:
Here's a break down of the Turtle Diagram. Please note the requests for "DETAILED" descriptions. When identifying inputs and outputs you need to be fairly specific. A "good part" doesn't really tell anyone anything.
This is awesome Randy. I just received a complaint from the QA Inspection Supervisor yesterday about mfg not flowing all the required information on to final qa inspection. Talk about perfect timing. I set up a meeting w/ her and the mfg Lead to go over the required inputs into final. My plan is to start w/ the “hard” outputs and inputs. Then we can compare it to what is currently documented. Baby steps, I know, but it’s a start!
It’s such a simple concept, and I can’t wait to dig in to see the results….
MGreenaway:
"Hope this clarifies things a bit."
Yes it does, thank you so much for sharing.
WOW! I’m starting to like this quality stuff. :biglaugh:
mshell
#24
This is our current flowchart. I am considering revising it to include text instructions as well. Would you guys recommed that approach?
M Greenaway
#25
What you have done is flowcharted a text based document. It is still a procedure, and is not a process map.
We are on similar lines I think, I will post my process map nomenclature from my quality manual tomorrow.
I believe the excercise of mapping adds great value to the organisation in understanding its processes fully. This greater understanding will have spin offs that the customer ultimately 'feels'.
Take for example my audit map posted earlier. If we look at that map we can see that their are no identified 'controls' governing audit reporting. Hence if I have a problem in this area of my process I could quickly identify the need for a 'control' which may be a procedure or work instruction for this process element. Simplistic example I know but hopefully you all get the idea.
I use MS Visio to create these maps, and publish them as HTML. Visio has much greater flexibility than standard MS Office applications - get it if you can (you can also do a whole host of other diagrams with it).
Marc
#27
Re: Internal Audit Flowcharts?
I was reading through some old discussions and thought this one would be good to review to see if anyone today has anything new to add or any changes since 2003.
Dr. IJ Arora
#28
Not as detailed as Martins, but here is our IA Turtle
I looked at your process and appreciate the different approach. However, since you have asked for inputs I have following suggestions. For one it is not a flow, what you have is more a checklist. Second the audit objective is an important input. So when you make it a flow please consider this in your process. Include a step to have an audit agreement which gives to the auditor the audit objective, scope and criteria enabling the auditor to determine the feasibility of the audit. You might argue that if you are part of the in-house/ internal audit team you have no choice but to audit. But that is not correct. Auditors determine the feasibility, and even if they are in-house they would at least convey it. There are other steps, but I think if you re-design and would like my inputs I will be happy to comment further.
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
V Process and Internal Audit Criteria matrix wanted Internal Auditing 8
E How do I create a FMEA for the Internal Audit process? Internal Auditing 11
R AS9100D Internal Audit Process Checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Internal Audit Matrix Process Query ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
N Internal Process Audits - 7.1 Planning - How do YOU audit it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W Internal Audit of the Internal Audit Process Internal Auditing 15
L Request APQP Process Internal Audit checklist APQP and PPAP 2
K Process Owners signing Internal Audit Reports Internal Auditing 6
R On Auditing Internal Audit Process - How Independence can be Established Internal Auditing 4
R Auditing a process outside the realm of the formal Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Can I skip Payment Process audit for TS16949 Internal Audit? IATF 16949 - Automotive Quality Systems Standard 4
C ISO 17025 Internal Audit of an "Internal Audit Process" ISO 17025 related Discussions 6
N Internal Audit Process for small Medical Device company Internal Auditing 9
M Auditing the Internal Audit Process - 8.2.2 General Auditing Discussions 2
J Auditing the Internal Auditing Process - Audit Nonconformance General Auditing Discussions 3
P Company Conducted Internal Audit Offsite using a Document Review Process Internal Auditing 65
F Airport Internal Audit Checklist (Cleaning, Project Process, Maintenance, etc) Internal Auditing 3
P Internal Audit Corrective Actions - Can a CB write an NC on an in-process CA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
B Can I use Internal Audit Checklist to do Process Audit? Process Audits and Layered Process Audits 9
K When is the best time to Audit the Internal Audit Process? Internal Auditing 25
R Process Internal Audit Checklist for Service Organizations wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Internal ISO 9001 Audit - Process Audit Checklist Internal Auditing 31
G Performing an Internal Audit on the Cost Estimating Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Internal Audit schedule & Process Audit Checklists Internal Auditing 3
T Internal Audit questions for Statistical Process Control and Process Control Internal Auditing 14
Casana How to document Internal Audits done via the "Process Audit" methodology Internal Auditing 9
P Problems with Internal Process Audit integration due to different CSR IATF 16949 - Automotive Quality Systems Standard 3
V Internal Audit - Process based vs. Procedure based AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
H Internal Audit Plan - Seperate audit plans for system, process, and for products IATF 16949 - Automotive Quality Systems Standard 4
M How to Internal Audit the Calibration Process Internal Auditing 12
tony s Let the Registrar audit the Internal Audit process Internal Auditing 45
A External Audit CAR when Internal Audit CAR is in process? General Auditing Discussions 34
T Internal audit checklists related to the software development process Internal Auditing 3
D Can Internal Auditors Audit the Internal Audit Process / System? How? General Auditing Discussions 12
M Showing the Effectiveness of the Internal Audit Process System - AS9100B Clause 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Need Example of Metrics for Internal Audit Process. Internal Auditing 6
K Defining Internal Audit Process Goals & Objectives Internal Auditing 49
C Audit Differences - Process, Product, Internal? (4 questions) - TS 16949 General Auditing Discussions 7
M Internal Auditing of our APQP Process - Who can audit APQP? IATF 16949 - Automotive Quality Systems Standard 5
T Process Internal Audit - Requirement on Monitoring Objectives & Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Process Effectiveness Metric for the process ?Internal Audit? Internal Auditing 25
J Internal Audit format - Idea of the process approach to the audit Internal Auditing 16
E Internal Process Audit Sampling using MIL-STD-105-E - 500 operators on 3 shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
I ISO 13485 Practical Internal Audit Checklist - Standard vs. Process Based Internal Auditing 26
Gman2 ISO 9001:2000 Internal Audit: Someone PLEASE find me the "Shall" on "Process Audits" Process Audits and Layered Process Audits 37
