Internal Audit Questions
Hello everyone,
First of all, I would like to say how interesting and friendly this forum is. Usually I do not participate in forums given their aggressive nature most of the time but this one I found very different from what I have seen so far, people are very polite and helpful. So congrats keep up this culture!
I have searched past posts and did not find anything related to what I need, so apologies if there is something like this somewhere in the website.
I have been given the task of preparing my company documents for this year ISO audit, I never did this before so it has been a challenge.
I need to create 6-10 questions for our Internal Audit report for each of the following processes.
-Risks and Opportunities
-Quality Objectives
-Monitoring and Measuring Equipment
-Document Control and Records
-Control of External Products and Providers
-Product and Service Provision
-Nonconforming Product and Corrective Action
-Monitoring and Measuring Results
-Internal Audit
-Management Review
-Customer Requirements
Would you guys have some sort of example or list of questions from where I could learn from ?
RoxaneB
Hello everyone,
-Quality Objectives
-Internal Audit
-Management Review
Hello and welcome.
First things first, why do you NEED to create 6-10 questions? Where did this number come from? There typically is no min/max number of questions to be asked.
To Johnny's point, do you have documentation upon which to base your questions?
Or, is this a homework question where you have been asked to come up with some example questions to ask? In this case, the requirements (i.e., the 'shall' statements of the standard) give you the basis of your questions. Keep them open-ended (i.e., NOT questions that require a yes/no response) in an effort to prompt a more detailed response from the auditee.
It is just the number we agreed upon in our last meeting given that in the past auditors have complained that only 2-3 questions would not be enough to cover the process. I do not have experience like I said but from I have been reading in our Audit Reports from past years, seems to be a very subjective process. It is up to the person auditing to be picky or not. In the case mentioned before we did not get a minor or major NC but a Room for Impromevement.
If you don't mind Johnny I will answer you and Roxanne here, and the answer is that I do not know what you guys mean by this :cry:. I do have several QMF forms related to each of those processes as evidence of their conformance.
I would say in this case is more of a homework but I will be the one auditing, I am pretty much the lead on this project since everyone hates it. I do not have access to the standards and to be honest I don't think we have it anywhere in the company. We have been doing this for more than 10 years and at this point I think they just have their own internal manuals to pass the audit year after year but you gave me an idea and I did find a Procedures Manual which explains a bit of how a successful process should look like.
Johnny Quality
andrekmh,
I agree with Roxanne, 6-10 questions per process sounds arbitrary. I would struggle to perform an effective process audit if I could only answer 10 questions.
The "Procedures Manual" sounds like it could be promising. Your organization should have some sort of documentation that states how the organization functions and this manual could be it.
Do you have any experience internal auditing?
RoxaneB
No where in the standard does it state anything remotely close to "The internal auditor shall ask..." a certain number of questions. If your auditor - was this an external auditor? - complained, let him/her complain. Unless there is a documented requirement within your own organization's process that a certain number of questions will be asked, this is, in my opinion, a non-value add recommendation.
That said, your auditor is right that it is likely 2-3 questions in insufficient to truly see if the requirements of the standard as well as your own organizational requirements have been adequately and sufficiently met.
What we were asking was if you have documented processes (e.g., work instructions, procedures, training materials, meeting agenda, etc.) that help you understand what the organization says it does. Your questions can be influenced by this. For example, if your internal audit procedure says that internal audits are scheduled based on the importance of the activity and previous results, you could ask something like:
  1. How are internal audits scheduled?
  2. How is the "importance of the activity" determined?
  3. How do previous results influence the schedule?
If you don't have a copy of the standard, I highly recommend you obtain one. Why? Because the standard contains the requirements of the QMS - your external auditor is auditing to this and you do not have any ability to challenge or argue findings if you cant not say, with confidence, that there is no "shall' upon which the auditor can base his/her finding.
The standard is also what you compare your organizational processes to and it contains the requirements upon which your QMS is based.
Tagin
To echo what Roxanne said, 9.2 says
The organization shall conduct internal audits at planned intervals to provide information on
whether the quality management system:
a) conforms to:
1) the organization’s own requirements for its quality management system;
2) the requirements of this International Standard;
If you don't have the standard, then you can't audit your QMS to the standard.
It's not that expensive, and will make operating your QMS - including internal audits - much easier.
andrekmh,
Thanks for your help Johnny.
Thanks that helped greatly.
Mike S.
Happy to be Alive
The internal auditor needs to ask as many questions as it takes for him/her to determine if the process is conforming to the requirements. Longer, more complex processes will generally require more time and questions than shorter, simpler processes. My Management Review audit can easily be completed within 30 minutes and a few questions, the Production audit takes hours and dozens of questions.
W How do you phrase your internal audit questions? Internal Auditing 3
A Purchasing - Internal Audit Questions Internal Auditing 8
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
M ISO 13485 Audit Questions - Internal Auditor Training and other Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
T Questions about an Internal Audit Checklist for our QMS Internal Auditing 41
E TS16949 Internal Audit "What do I Do" questions Internal Auditing 6
K Sample Questions for Auditing Management Rep , Internal Audit and Reg. Compliance Internal Auditing 7
L Written Supervisory Procedures - Internal Audit Checklist Questions Internal Auditing 2
M Internal Audit questions on Technical Resources & Work Environment Internal Auditing 9
L Top Management - Internal Audit Questions to Ask Internal Auditing 17
M Internal Audit for ISO 14001 - Questions for Management Internal Auditing 12
Q APQP Compliance Internal Audit - Ideas, check lists or main questions to prepare APQP and PPAP 9
J Internal Audit Questions - Accounting - ISO 9001 Internal Auditing 24
C New to performing internal audits - Looking for audit questions Internal Auditing 5
T Internal Audit questions for Statistical Process Control and Process Control Internal Auditing 14
T Supplier Control in TS 16949 - How to spice up my Internal Audit questions IATF 16949 - Automotive Quality Systems Standard 13
S Need questions for Internal Audit of Financial departement? Internal Auditing 11
A Internal Quality Audit - Can I follow the Auditors and Ask Questions? Internal Auditing 11
Q Internal Audit Questions - Does anyone have sample questions for Management Internal Auditing 16
C Audit Differences - Process, Product, Internal? (4 questions) - TS 16949 General Auditing Discussions 7
N Simpified ISO 9001 Internal Audit Questions Internal Auditing 19
Q Easy CARs for Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
C API Q1 internal audit report Internal Auditing 3
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 1
J Internal audit random sampling methodology Internal Auditing 2
G Organizing internal audit program for an Integrated QHSE Management System Internal Auditing 13
M IATF - Internal Audit 3 year span Internal Auditing 4
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 15
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 8
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
