Internal Audit Training Material to Train Internal Auditors for ISO9001:2000
bbolden
I am looking for some good training material to train internal auditors for ISO9001:2000. Does anyone have a PowerPoint, training activites, or handouts that they have used in the past that has worked. Thanks for your help in advance.
Stijloor
Re: Internal Audit Training
Hello, and welcome to The Cove Forums. :bigwave: :bigwave:
You may begin by scrolling down this page and click on the links.
Then you do a search, and you'll find great materials for your training.
Some assembly is required.;)
Again, welcome and do come back often.
Stijloor.
Helmut Jilling
Auditor / Consultant
It can be done internally, but as a consultant, allow me to make a recommendation. If you are an experienced auditor, skillful in doing a process auditing approach, you can get good results internally. However, as a trainer, I would strongly recommend you retain a good trainer with a a good training program.
This will be an expensive few days of training, even if you do it internally. Further, the results of the internal audits can provide the company many thousands of dollars of value if done well. If not done well, the audits will just churn through time and produce much less results.
The cost should not be viewed as the cost of training, it should be viewed as the cost of missed improvements over time. That can be vastly more expensive than any training you contract. Good auditing is not easy, and training for it should be handled by very proficient trainers.
(Shameless Plug - I, and some others on this forum, provide good training programs for auditors. I have had very good success with my current "Auditing for Improvement" internal audit system training. I would give serious consideration to using (good) outside help. This is an area where saving money actually costs many times the perceived savings.)
Kales Veggie
People: The Vital Few
Internal audit should be a value-added process, finding opportunities for improvement, finding systemic problems in your processes, diving a little deeper than reviewing the turtle and metrics.
An experienced trainer (and auditor) will give you a wealth of information during these training days that goes beyond a standard 19011 training.
In my opinioin, it worth the investment.
DsqrdDGD909
Is this refresher or initial training? Have you assessed the objectivity, competency and impartiality of the internal auditors?
bbolden
It will be initial training for most. The other internal auditors have not conducted an audit for some time. The lead auditors in our company have been conducting all of the audits. I am wanting to expand the number of auditors so we can perform better audits that are focused more toward the process approach.
Helmut Jilling
Since "Auditing for Improvement" is not the focus of most audit training curriculums, it is designed for both new auditors and experienced auditors. It is a new approach using a proprietary system we put together, to lead auditors through an appropriate, thorough "process approach" audit.
I would say that is baked into the purpose of the training. To teach people to "Audit for Improvement" effectively, addresses objectivity and developing competence.
Impartiality would have to be controlled when auditors are assigned specific processes to audit.
The thing I am excited about, is after many iterations, we finally have developed a checksheet system that leads auditors down the right paths of all the process audit linkages and rabbit trails, which so easily get missed. We also teach some audit concepts that are nontraditional, and cause auditors to look for things they have not looked for before.
Essentially, I took the things a good third party auditor learns, and distlled it into a system that internal auditors with less experience can still master and follow. been getting good feedback. It is the right approach for companies to follow, whether they use my system, or develop their own. merely auditing for ISO compliance is a diminishing return on value.
Can I add a word of caution?
You say you want to expand the number of auditors to get better audits. In fact adding new auditors will not improve the results, since they will be somewhat inexperienced. I'd suggest getting someone (like Helmut) in to work with your current auditors to see what can be improved, before you spend money on more training. Too many cooks spoil the audit...........:lol:
Matt M - 2009
On the one hand I do agree with Andy about exspansion plans. However I ran into a similar problem here where the same auditors had been doing them so long that they fell into a bare minimum approach. The number of auditors had decreased so much that the few who were left would be doing too many to be done effectively. Expanding the program and having the new auditors work along side the experienced ones proved effective.
It is worth doing a search right here on this site, there was lots of useful material that I found posted by others that answered questions and filled in gaps.
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
M ISO 13485 Audit Questions - Internal Auditor Training and other Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
P Internal Auditor Training - Audit exercises Internal Auditing 5
N Internal Audit of the Training System - Corrective Action Necessary? Preventive Action and Continuous Improvement 16
J Copying pages of the standard for internal audit training classes IATF 16949 - Automotive Quality Systems Standard 11
I Internal Audit Training Material Resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Suggestions for Internal Audit Training Courses Training - Internal, External, Online and Distance Learning 10
B Value adding for Internal Quality Audit training General Auditing Discussions 18
D Internal Audit Training Material covering ISO 9001, ISO 14001 & OHSAS 18001 Training - Internal, External, Online and Distance Learning 1
P Internal vs. external audit training course differences? Internal Auditing 18
A Online Internal Audit Refresher Training - TS 16949 IATF 16949 - Automotive Quality Systems Standard 4
Stijloor Online Internal Audit Training for ISO/TS 16949:2002? Training - Internal, External, Online and Distance Learning 1
H Carrying out an internal audit on HR/ Training today Internal Auditing 6
eternal_atlas Internal Audit of Training Need Analysis - Compliance Audit General Auditing Discussions 4
Q Offsite ISO TS 16949 Internal Audit Training - Pacific Northwest including California Training - Internal, External, Online and Distance Learning 4
Q Objective Evidence - Internal Audit Training in a Cargo Company Training - Internal, External, Online and Distance Learning 2
I Audit Scenarios for Internal Auditor Training Training - Internal, External, Online and Distance Learning 3
B Internal Audit Training Materials needed - Preferably Powerpoint .ppt file Training - Internal, External, Online and Distance Learning 12
D Designing an ISO 9001 Internal Audit Training Course - Need Help Internal Auditing 6
T Internal Audit Training via Correspondence - Recommendations? Training - Internal, External, Online and Distance Learning 3
J Internal Audit question - Training failure of new employees Internal Auditing 30
S ISO 9001:2000 Internal Audit Training Providers Training - Internal, External, Online and Distance Learning 4
M Seeking template for Internal Audit Training Certificate Document Control Systems, Procedures, Forms and Templates 2
C Internal Audit Training Help - Audit Nonconformance Training - Internal, External, Online and Distance Learning 11
J Book Review: Internal Audit Training from Patton Press Book, Video, Blog and Web Site Reviews and Recommendations 10
I Seeking: Internal Audit Training Material - Practice Audits? Internal Auditing 14
Claes Gefvenberg Internal Audit Training - An Internal Audit Training Map Internal Auditing 9
D Heading an Internal Audit Program - What training is required? Internal Auditing 2
U QS 9000 Audit - Trainer of internal auditors not having formal training QS-9000 - American Automotive Manufacturers Standard 6
D 1st Internal Audit & Training Internal Auditing 8
J QS-9000 Internal Audit Training Requirements Internal Auditing 4
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
