Internal Auditing of Area with Active Change Control
Michele B
Good morning,
I will be conducting an internal process audit in our Distribution Center. Management has an active "approved" change request for a function within this area. The change request has not been closed as document revisions and training are not complete. If I observe the proposed changes in place, is this a nonconformance? I'm not sure if having a change control in place protects the department from a nonconformance. Any guidance is greatly appreciated.
Regards,
Michele
Jen Kirley
Quality and Auditing Expert
Re: Auditing area with active change control
Michele B, welcome to the Cove! :bigwave:
Unless the change involves regulatory requirements or requires customer approval to implement, I would generally not assign a nonconformance because the process document has not yet been approved - unless I found written evidence or was was given a verbal description of the changes having been made quite a lot before the process document had been updated - by "quite a lot" I mean months.
Please understand though, that receiving more detail about just what was being done might have prompted my giving a different answer.
Good morning,
Regards,
Michele
Is this not covered by your company's documented requirements? If it is, you have your answer--if the requirement isn't met, it's a nonconformity. On the other hand, if the situation you describe isn't addressed, you will be performing a useful function by documenting the disconnection. You shouldn't necessarily be thinking in terms of black and white--conformity or nonconformity. Internal auditors should always be on the lookout for things that need to be improved.
Michele B
Hi Jennifer,
Thank you for your quick response. The change control was approved on 10/17/11. The change is minor and impacts 3 different distribution centers. The distribution centers are still editing the written work instructions as they have not come to a final agreement. I have received word that employees are already following the "new" procedure. My concern is how can a new procedure roll out without a finalized document for employees to train on?
K
Ka Pilo
Hi Jennifer,
Actual practice should reflect current/approved document and they should be accurate. The fact that it does not, the document should be approved/updated and employees should be retrained.
Randy
There are 2 basic questions
1) What is supposed to be happening?
2) Is it happening as planned?
From the answers to those questions you'll make your decision.
Don't try to make it any more difficult than that
Hi Jennifer,
Because training isn't always necessary! You have to look at the nature of the change, which from what you've said doesn't appear too significant. Not all changes need 'training'.
For example, when I arrived in the USA I could drive (on the other side of the road) and we had to change 'procedure' (to drive in the USA, things are often different) but, it's not a requirement to go to training - just take a test (only in some states, as well). If you or your QMS says you need training for documentary changes, this should be reviewed for need...
Michele B
Hi Randy,
Thank you. It is not happening as documented/planned. It would be a nonconformance. I was over thinking this one :)
Regards,
Michele
Hi Randy,
Regards,
Michele
Another thing you should think about, perhaps, is whether it's prudent to forestall a process improvement while waiting for the documentation to catch up. If your system forces things like this, you might be correct in citing a nonconformity, but maybe the root cause is a system that's not flexible enough to allow for improvement to take precedence over the document review process.
C RC14001 Internal Auditing Class in the Columbus area Miscellaneous Environmental Standards and EMS Related Discussions 0
A Information on Process-based Internal Auditing Needed Internal Auditing 6
S Risk based internal auditing Internal Auditing 6
F AS9100D Internal auditing requirements Internal Auditing 11
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
W Internal Auditing carried out by a 3rd party - Review of previous audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
E Informational Internal Audits - Wear multiple hats what can and can't I audit (so I'm not auditing my own work) Internal Auditing 151
N Online Internal Auditing Course for ISO 13485 - Suggestions ISO 13485:2016 - Medical Device Quality Management Systems 8
U Internal auditing - Company employees or contract second party Internal Auditing 10
K Internal Auditing - Umbrella QMS and Multiple Standards Oil and Gas Industry Standards and Regulations 4
D Auditing Our Outsourced 2nd-3rd Party Internal Audit Company ISO 13485:2016 - Medical Device Quality Management Systems 6
G AS9101 Rev F - Worksheets for internal auditing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S ISO 13485:2016 and MDSAP internal auditing ISO 13485:2016 - Medical Device Quality Management Systems 6
S ISO 9001:2015 - Internal Auditing - Audit to the Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Internal Auditor auditing Internal Audit Procedure (AS9100) Internal Auditing 18
M Is Automated Internal Auditing Possible? Internal Auditing 13
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
L Auditing Design and Development in ISO 9001 (Internal Audit) Internal Auditing 1
sswaim Auditing Internal Laboratory Personnel for Competence General Auditing Discussions 4
K Internal Auditing a previous Nonconformance? Internal Auditing 19
P Recommended books on ISO 27001:2013 Implementation and Internal Auditing IEC 27001 - Information Security Management Systems (ISMS) 4
M Are auditing checklists required for Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
B PFMEA, Internal Auditing, Corrective Action Training In Native Language (China) Training - Internal, External, Online and Distance Learning 1
Gman2 Internal Auditing Requirements before ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Auditing TS 16949 Cl. 7.6.3.1 - Internal Calibration Laboratory Requirements IATF 16949 - Automotive Quality Systems Standard 8
T ISO 9001 Internal Auditing Auditor Training in Amsterdam Training - Internal, External, Online and Distance Learning 1
S In an internal auditing desert and I'm the only one here.... AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
G Internal Auditing in a Multi-Site Environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Internal Auditing of MDD and CMDR Requirements Other Medical Device Related Standards 5
O Internal Auditing in small Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Looking for a webinar on Internal Auditing General Auditing Discussions 3
R On Auditing Internal Audit Process - How Independence can be Established Internal Auditing 4
D Auditing Abroad - Internal Audits of our European Sister Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Auditing a process outside the realm of the formal Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G New to Internal Auditing - Best questions to ask? Internal Auditing 17
M Auditing the Internal Audit Process - 8.2.2 General Auditing Discussions 2
J Auditing the Internal Auditing Process - Audit Nonconformance General Auditing Discussions 3
S Internal Auditing related to RISK Internal Auditing 9
W Internal Auditing - Observational Checklist for a Behavior Based System Internal Auditing 3
R Internal Auditing Checklist - Major NCR because the Checklist was not Completed Internal Auditing 17
V Depth of Internal Auditing and Training aspects in Research & Development (R & D) Internal Auditing 4
N Good Internal Auditing Training Courses Training - Internal, External, Online and Distance Learning 13
L Internal Auditing Reports / Documents - Design and Content Document Control Systems, Procedures, Forms and Templates 1
N Recommend internal auditing training 101 please (Tucson or Phoenix, AZ) Training - Internal, External, Online and Distance Learning 1
