Internal auditor collected incorrect evidence - CAR or No CAR?
Crusader
Tried a search but came up empty. One of my auditors audited ISO 9001:2000 clause 7.1 - this clause only. The auditor collected data that does not quite correlate with what should have been collected. Regardless of the clause or standard, the data collected does not support the clause that was audited. What would a Cover do? CAR or No CAR? :confused:
I have to go back and reassign the 7.1 audit for the June audit anyway. But should I not bother writing a CAR and handle discreetly...or just the opposite?
Stijloor
Aside from the fact that your Internal Auditor went outside the "scope" of 7.1, did the audit evidence demonstrate a nonconformity? Against what requirement? If so, I would still issue a CAR.
By the way, are you auditing "clauses" or processes? If you audit processes (the preferred approach), several clauses may apply to the process that's being audited.
Hope this helps.
Crusader
Basically the wrong data was collected. A process approach is used but I have to (forced is a better way to describe it) split up the audit team - hence this one auditor had this portion (7.1) of the audit.
Stijloor
I see. This could be an opportunity for learning for the Auditor.
I would give both the auditor (and the auditee) the benefit of the doubt. After all, I learned during the various Lead Assessor courses to be "flexible."
Crusader
Yeah, I was leaning that way. I've never experienced this type of situation before. Thanks for your opinion. :bigwave:
Randy
7.1? You audit the Product Realization clauses to show conformance to 7.1 you don't audit it specifically.
The only way to verify conformance to 7.1 would be to audit everything between 7.2 and 7.6. Clause 7.1 is a general clause that is broken down into greater and more specific detail in the clauses that follow it.
7.1 Planning of product realization
The organization shall plan and develop the processes needed for product realization. Planning of product realization shall be consistent with the requirements of the other processes of the quality management system (see 4.1).
In planning product realization, the organization shall determine the following, as appropriate:
a) quality objectives and requirements for the product;
b) the need to establish processes, documents, and provide resources specific to the product;
c) required verification, validation, monitoring, inspection and test activities specific to the product and the criteria for product acceptance;
d) records needed to provide evidence that the realization processes and resulting product meet requirements (see 4.2.4).
The output of this planning shall be in a form suitable for the organization's method of operations.
NOTE 1 A document specifying the processes of the quality management system (including the product realization processes)
and the resources to be applied to a specific product, project or contract, can be referred to as a quality plan.
NOTE 2 The organization may also apply the requirements given in 7.3 to the development of product realization processe
s.
Crusader!
To avoid the 'next time', because it could happen to another auditor, may I suggest that you sit down with each auditor before the audit, and review with them what they will take as 'samples' of 'evidence' during the audit??
When coaching internal auditors, I'm careful to ensure that each one gets a chance to 'tell their story' about how they are going to approach the audit. I got this technique from being a supervisor for a registrar, with a lot of newbie candidates to 'sign off'. It is potentially very serious to have an auditor 'go off' on you/the team, and I believe that it has benefits internally too.
I'm sure you'll deal with the current situation appropriately, but please try the above and let me know what happened..........
Cari Spears
http://elsmar.com/Forums/showpost.php?p=164786&postcount=11
The attachment in this post is the audit preparation worksheet we use. The auditors identify inputs, outputs, controls, checkpoints, acceptance criteria, performance indicators, etc. during review of the process prior to the audit thus identifying what evidence to gather.
More to your original question, I would not issue CARs. I'd reaudit the process and then re-evaluate the way auditor competence is determined. Maybe that one auditor needs a little more training or time with experienced auditors - maybe the process of determining auditor competency needs to be revised - maybe better auditing tools are necessary...
I think this is good advice. If you send your kid to the store to get a gallon of milk and a dozen eggs and he comes home with a loaf of bread and some Twinkies, something's not right. It could be that the kid doesn't know the difference, which isn't likely, or that that the kid just needs a list (or a good whuppin'). :D In any case, a CAR probably isn't the right weapon vehicle unless you think that a record of what took place might be helpful in the future.
Stijloor
Fellow Covers,
Crusader asked a very good question, something of concern.
I believe that the question has been appropriately answered.
Based on (some of) the later responses, it appears that a major (audit) violation has been committed. Is it necessary, or even helpful to make a mountain out of a mole hill?
Finally:
8.5.2 Corrective action
The organization shall take action to eliminate the cause of nonconformities in order to prevent recurrence.
Corrective actions shall be appropriate to the effects of the nonconformities encountered.
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
J Your opinion on the better training org for IATF16949 Internal auditor and Lead Auditor IATF 16949 - Automotive Quality Systems Standard 3
Q Internal Auditor Training requirements for ISO 14001:2015 ISO 14001:2015 Specific Discussions 5
E Informational I would like to get some Internal Auditor Training Internal Auditing 31
J IATF 16949 CAR - Internal Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 15
A ISO 13485 - Internal Auditor Independence and Process Owners ISO 13485:2016 - Medical Device Quality Management Systems 3
Q AS 9100D internal auditor training requirements Internal Auditing 16
A Other Discussion Boards - Internal Auditor Coffee Break and Water Cooler Discussions 5
E Online training for an internal auditor to AS9120B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Internal Auditor Trainer's Requirement Internal Auditing 4
D IATF 16949 - Internal Auditor Training/Certification Requirements Training - Internal, External, Online and Distance Learning 2
R Internal Auditor vs. Public Accountant - Accounting Student Needing Help Career and Occupation Discussions 4
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
R Internal Auditor auditing Internal Audit Procedure (AS9100) Internal Auditing 18
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 10
H ISO/IATF Internal Auditor Recommendations For Manufacturer In California, USA Internal Auditing 3
Casana 2nd Party and Internal Auditor Qualifications & Training IATF 16949 - Automotive Quality Systems Standard 13
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
B Competency of Trainer for Internal Auditor Training (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 11
C ISO 13485:2016 - Internal Auditor Training vs. Lead Auditor Training Training - Internal, External, Online and Distance Learning 4
J Dinged on Internal Audits for supervising an auditor I was training Internal Auditing 10
M Internal Auditor --> Licence needed? Internal Auditing 6
V Internal Auditor Training Documents and PPT Document Control Systems, Procedures, Forms and Templates 5
V Internal Auditor Training Documents and PPT Internal Auditing 3
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
D Can the Plant Manager be our ISO Representative and an Internal Auditor? Internal Auditing 26
M ISO 13485 Audit Questions - Internal Auditor Training and other Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
M Questions about AS9100 Internal Auditor Training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
P Internal Auditor Training - Audit exercises Internal Auditing 5
D Training Material for Internal Auditor Requirements Training - Internal, External, Online and Distance Learning 4
U TS16949 Internal Auditor Training - Is On-line training OK? Training - Internal, External, Online and Distance Learning 1
F Internal Audit quiz - Auditor Qualifications and Requirements Internal Auditing 34
