Internal Auditor Competency KPI
Given that the documented process is mentioned in 7.2.3 Cl, it is necessary to define KPI(s) to measure the process. My question is what can be the best indicator that can include the requirements of this Cl?
AMIT BALLAL
There is a requirement to measure the performance of a process, not "documented process".
By "Documented process", it means a procedure. Documented process word is used to have flexibility in the approach of its documentation - such as a detailed procedure, flow chart, etc.
Howard Atkins
Forum Administrator
Just because the standard calls it a process does not mean that it is a process of the QMS
Please see
4.4 Quality management system and its processes
4.4.1 The organization shall establish, implement, maintain and continually improve a quality management system, including the processes needed and their interactions, in accordance with the requirements of this International Standard.
The organization shall determine the processes needed for the quality management system and their application throughout the organization, and shall:
also remember
after the si Standard interpretations English IATF 16949:2016 Sanctioned Interpretations (SIs) #20 – issued in December 2020 , effective January 2021
the standard reads
5.1.1.2 Process effectiveness and efficiency
Top management shall review the effectiveness and efficiency of the quality management system to evaluate and improve their the organization’s quality management system.
I think I did not express my meaning correctly. According to the point made to us by DQS, when the standard mentions "documented process", the inputs and outputs mentioned in that requirement must be mentioned in the turtle diagram of one (or more) of the organization's processes. (One of our auditors keeps repeating a sentence: You can mix the documented process but you should not miss it).
We are now asked to define indicators to monitor these cases.
I think what you mean is documented information, not the documented process.
John Broomfield
Where is the use of a “turtle diagram” specified?
How do you verify that your auditors do a good job of:
A. Planning and preparing
B. Sampling and investigating
C. Recording the facts
D. Reporting the results
These actions may already verify auditor competence.
Whether the auditing is fulfilling its objectives in a different subject. Do you have top management’s objectives for your internal audit program? That would be a good place to start.
According to your points, in my opinion, holding a periodic exam can prove the competence of the auditors and the result of the auditors in this exam can be considered as KPI. what is your opinion?
Sebastian
Yes, there shall be a process, but KPI might not be required. How?
When you combine sequence of "small" processes into one "bigger" process, let's call it "system process", you are not obliged to identify individual KPI for every "small" process. You identify KPI for "system process".
7.2.3 is about competence of internal auditors, but internal auditors are small part of organizational staff and we have to establish process, which has to ensure, that whole staff is competent and not only auditors. We have also trainers, product designers, FMEA team members, control plan team members, persons with authority to release product and delivery, process setup staff, staff involved in statistical process control. All of these groups have to have individual KPI? Only auditors because they have own clause 7.2.3? Answer is "No". Put them all in one sack and monitor KPI for process ensuring competence requirements are fulfilled and that's all.
Just press CTRL+F and search IATF 16949 for "documented process". I've counted 15. 3 of them could be merged in 1 process for human resources management, including competence of whole staff, competence of internal auditors and employee motivation. It's up to organization how system processes are established. Some combine them, some not, but all 15 have to be found somewhere there.
John Broomfield
A written examination may verify some knowledge.
But competence also includes natural abilities or attributes (per ISO 19011 perhaps) which you may already have used for recruiting volunteers to serve on the audit team.
...and let us not forget the necessary skills.
I had expected you to say that you used supervisory measures such as:
  • Reviewing the checklist for sufficiency per the audit objective.
  • Attending opening meetings or closing meetings
  • Follow up with auditee reps or the audit team leader
  • Reviewing audit reports
etc...
Until each auditor is verified as competent.
Thanks for this interesting and practical view.
I've counted 20. Because in some clause a few words are between documented and process.
B Internal Auditor Competency - Product Auditors Internal Auditing 9
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 10
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
B Competency of Trainer for Internal Auditor Training (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 11
M Internal Auditor Competency based upon Skill Sets based on ISO 19011 Internal Auditing 20
T Internal Auditor Competency Pre-test Training - Internal, External, Online and Distance Learning 16
D Internal auditor competence assessment Internal Auditing 12
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
P Looking to outsource Internal Audit - MDSAP competent auditor needed Other Medical Device Regulations World-Wide 9
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J IATF CB Auditor questions Internal Auditor Competence IATF 16949 - Automotive Quality Systems Standard 19
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 42
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
J Your opinion on the better training org for IATF16949 Internal auditor and Lead Auditor IATF 16949 - Automotive Quality Systems Standard 3
Q Internal Auditor Training requirements for ISO 14001:2015 ISO 14001:2015 Specific Discussions 5
E Informational I would like to get some Internal Auditor Training Internal Auditing 31
J IATF 16949 CAR - Internal Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 15
A ISO 13485 - Internal Auditor Independence and Process Owners ISO 13485:2016 - Medical Device Quality Management Systems 3
Q AS 9100D internal auditor training requirements Internal Auditing 16
A Other Discussion Boards - Internal Auditor Coffee Break and Water Cooler Discussions 5
E Online training for an internal auditor to AS9120B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Internal Auditor Trainer's Requirement Internal Auditing 4
D IATF 16949 - Internal Auditor Training/Certification Requirements Training - Internal, External, Online and Distance Learning 2
R Internal Auditor vs. Public Accountant - Accounting Student Needing Help Career and Occupation Discussions 4
R Internal Auditor auditing Internal Audit Procedure (AS9100) Internal Auditing 18
H ISO/IATF Internal Auditor Recommendations For Manufacturer In California, USA Internal Auditing 3
Casana 2nd Party and Internal Auditor Qualifications & Training IATF 16949 - Automotive Quality Systems Standard 13
C ISO 13485:2016 - Internal Auditor Training vs. Lead Auditor Training Training - Internal, External, Online and Distance Learning 9
J Dinged on Internal Audits for supervising an auditor I was training Internal Auditing 10
M Internal Auditor --> Licence needed? Internal Auditing 6
V Internal Auditor Training Documents and PPT Document Control Systems, Procedures, Forms and Templates 5
V Internal Auditor Training Documents and PPT Internal Auditing 3
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
D Can the Plant Manager be our ISO Representative and an Internal Auditor? Internal Auditing 26
M ISO 13485 Audit Questions - Internal Auditor Training and other Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
M Questions about AS9100 Internal Auditor Training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
