Internal Auditor lack of Competence
Corsair
How you approach your Q.A manager and tell him that the Internal Auditor is not competent not only to the relevant Standard but with the overall knowledge for the aerospace industry.
We think that may be a comfort zone build up between the two.
Anybody experience the same situation?
:thanx:
qusys
Re: Internal Auditor lack of Competece.
Good point,
in this case this issue could come from an audit ( third party or second party).
Anothere suggestion could be to implement an internal survey to monitor the customer satisfaction of the process ( in this specific case, the internal audit process). So internal customer could express this consideration for you if they respond to the question you set in the questionnarie.
Hope this helps:bigwave:
Is the internal audit process itself being audited?
jerry_Malaysia
frankly speaking, over the pass 10 years i worked, i only managed to meet a few auditors whose are really professional
i have seen so many 2nd party and even 3rd party auditors whose were not qualified at all. they qualified as the auditors simply because they attended some training and obtained some certs. but some of them do not even understand what is ca and what is pa.
so, what is the expectation we should have for internal auditors?
dknox4
:thanx:
If the auditor is incompetent I would think that audit findings, reports...etc. would expose the shortcomings. I would use these and approach the QA manager, suggesting training my be needed.
Jen Kirley
Quality and Auditing Expert
I am auditing a semiconductor plant to TS16949 though my background is in metals fabrication and shipboard controlled system repairs.
So I often do not understand technical details, but can still ask questions like "If you cited reliability problems in your FMEA's Potential Effects of Failure column, why did you assign that Potential Failure Mode a severity of 1 or 3?" I would be able to do the same in an aerospace supplier because I audit systems more than technical details.
But I need to have some competence to do that, and I have been required to gain education via passing a Lead Auditor class, certifying ASQ CQA, etc.
If this subject organization does not have any requirements like that, or if the auditor has completed the requirements but still exhibits inability to perform, in my view there's a bigger problem than just being chummy with someone.
Two points: first, I agree that before accusing anyone of being incompetent (or otherwise undesirable), you'd better have evidence, and strong evidence. The other thing to consider is that the QA manager already knows that the person is incompetent, which he should know if the evidence is strong enough to make the accusation. The QA manager might know it and might have chosen for his own reasons not to do anything about it, or she might be incompetent herself and not be able to recognize incompetence in an auditor.
Former Ohio State football coach Woody Hayes, when asked why his offensive scheme didn't feature more passing, famously replied, "There are only three things that can happen when you throw a pass, and two of them are bad." In similar fashion, there are only a few things that can result from notifying a manager that someone who works for him is incompetent, and only one of them is good.
:thanx:
Competency is an objective evaluation of the demonstrated ability to apply skills and knowledge. If the auditor in question isn't able to do this, it should be readily obvious. I'm not sure your statements are accurate - internal auditors aren't necessarily required to be fully conversant with, for example AS9100 (if that's what you mean by 'relevant Standard') or 'overall aerospace industry'. It's possibly more appropriate that they be very conversant with your business and customers requirements!
Corsair
Re: Internal Auditor lack of Competence.
Gentleman, there are to many threads about this issue of competence.
But to be more specific,suppose that this person is schedule to audit clause 7.3 Design & Development and this department have problems with the design itself (bad data) in reverse engineering the part, and the preliminary report tells you that a hole pattern is off location by .003" .Don't everybody be in agreement that an internal auditor should be competent in mechanical drawings readings for example and see that the " true position" of the part in question is off tolerance and raise questions about the design itself.
As we all know, position toleracing is one of the most difficult features to inspect.
These and others issues with the D&D department were not challenge at all in that particular audit.
Somehow the Q.A manager seems to be O.K with that.
Jen Kirley
I rarely audit technical procedural aspects or data, usually I am auditing the system. I like to think someone besides myself is taking a role in helping to ensure the right things are happening, as I come around once a year at the most and my sample is limited as compared to what's gone on in that year.
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
J Your opinion on the better training org for IATF16949 Internal auditor and Lead Auditor IATF 16949 - Automotive Quality Systems Standard 3
Q Internal Auditor Training requirements for ISO 14001:2015 ISO 14001:2015 Specific Discussions 5
E Informational I would like to get some Internal Auditor Training Internal Auditing 31
J IATF 16949 CAR - Internal Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 15
A ISO 13485 - Internal Auditor Independence and Process Owners ISO 13485:2016 - Medical Device Quality Management Systems 3
Q AS 9100D internal auditor training requirements Internal Auditing 16
A Other Discussion Boards - Internal Auditor Coffee Break and Water Cooler Discussions 5
E Online training for an internal auditor to AS9120B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Internal Auditor Trainer's Requirement Internal Auditing 4
D IATF 16949 - Internal Auditor Training/Certification Requirements Training - Internal, External, Online and Distance Learning 2
R Internal Auditor vs. Public Accountant - Accounting Student Needing Help Career and Occupation Discussions 4
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
R Internal Auditor auditing Internal Audit Procedure (AS9100) Internal Auditing 18
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 10
H ISO/IATF Internal Auditor Recommendations For Manufacturer In California, USA Internal Auditing 3
Casana 2nd Party and Internal Auditor Qualifications & Training IATF 16949 - Automotive Quality Systems Standard 13
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
B Competency of Trainer for Internal Auditor Training (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 11
C ISO 13485:2016 - Internal Auditor Training vs. Lead Auditor Training Training - Internal, External, Online and Distance Learning 4
J Dinged on Internal Audits for supervising an auditor I was training Internal Auditing 10
M Internal Auditor --> Licence needed? Internal Auditing 6
V Internal Auditor Training Documents and PPT Document Control Systems, Procedures, Forms and Templates 5
V Internal Auditor Training Documents and PPT Internal Auditing 3
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
D Can the Plant Manager be our ISO Representative and an Internal Auditor? Internal Auditing 26
M ISO 13485 Audit Questions - Internal Auditor Training and other Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
M Questions about AS9100 Internal Auditor Training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
P Internal Auditor Training - Audit exercises Internal Auditing 5
D Training Material for Internal Auditor Requirements Training - Internal, External, Online and Distance Learning 4
U TS16949 Internal Auditor Training - Is On-line training OK? Training - Internal, External, Online and Distance Learning 1
F Internal Audit quiz - Auditor Qualifications and Requirements Internal Auditing 34
