Internal Auditor lack of Competence
#11
Re: Internal Auditor lack of Competence.
Gentleman, there are to many threads about this issue of competence.
But to be more specific,suppose that this person is schedule to audit clause 7.3 Design & Development and this department have problems with the design itself (bad data) in reverse engineering the part, and the preliminary report tells you that a hole pattern is off location by .003" .Don't everybody be in agreement that an internal auditor should be competent in mechanical drawings readings for example and see that the " true position" of the part in question is off tolerance and raise questions about the design itself.
As we all know, position toleracing is one of the most difficult features to inspect.
These and others issues with the D&D department were not challenge at all in that particular audit.
Somehow the Q.A manager seems to be O.K with that.
How would the internal auditor know to look into this? If they are being told to audit to the ISO 9001 criteria and the expectation is for them to pick up on such a fine point, the expectation is way off, in my opinion!
Who chose this auditor to audit Design? Maybe that's where the problem lies, not with competency, but with audit program management!
It's often the case that auditors are chosen from another department which is a risky situation, because of the very reasons you describe! But it has nothing to do with competency, maybe they'd be perfectly fine auditing in a department they're familiar with.
SteelMaiden
#12
I know lots of people who are good auditors that wouldn't necessarily be able to look at a print and tell that the design was bad. Heck, my degree is in the engineering fields (not that I have used that knowledge in the past 20 years), and I wouldn't be able to tell you that.:notme:
Jason PCSwitches
#13
I agree with Andy, while I understand the intent of the 'auditing your own work' or 'objectivity and impartiality' requirement, it may not be the most practical and effective manner in which to conduct internal audits.
If an internal auditor is assigned an audit involving a process in which they have little or no knowledge of, IMHO, it is leaving the door open for an ineffective audit, and nonconformities can easily be missed. I have witnessed this on several occasions. It provides a false sense of confidence that can result in a shock when an experienced auditor reviews and audits that process & issues non-conformities that the organization is surprised about. The unfortunate casualties, and not necessarily rightfully so, are the internal auditors, whom get dinged for incompetence and ineffective auditing when it's actually a systematic issue.
That being said, to some degree, if a company's QMS is implemented and effective, a good auditor should be able to conduct a thorough audit with the information available. :2cents:
Richard Pike
#14
How you approach your Q.A manager and tell him that the Internal Auditor is not competent not only to the relevant Standard but with the overall knowledge for the aerospace industry.
We think that may be a comfort zone build up between the two.
Anybody experience the same situation?
:thanx:
Look at your Organizations documented requirements for Internal Auditors. It is quite acceptable (especially at Process Owner level) to diplomatically challenge if an Internal Auditor meets the requirements laid down by your own Organization.
If you think that your Organizations requirements may have become (stale) then nobody should get upset if you suggest a review.
P>S After the Audit, do you get the opportunity to review and report on the perceived effectiveness of the Audit? (from the Process Owners Viewpoint)
John Martinez
#15
Ok, so I can not audit design unless I'm an engineer. And, I can't audit Top Management unless I have an MBA, and I can't audit Monitoring and meansurement of the product unless I'm a Quality Engineer....P.L.E.A.S.E.
There are certain requirements of ISO 9001 that lends itiself well to taking out the standard and following the bouncing ball. Any qualified internal auditor can do that with respect to 7.3. Then take how the organization applied 7.3 in practicality and following the bouncing ball and you would be suprised how effective that can be.
I was on a third audit party audit team and found myself auditing R&D for the design and manufacature of uplink and download of satellite data.
I found a Major NC when the current lead auditor who had been auditing them for the past 6 years did not find. I took out the standard, followed the bouncing ball, applied that to what the R&D department was doing and BINGO! No Validation.
My background is metals and IT.
And while we are at it, it is my humble opinion that if an internal auditor has a good foundation of auditor skills, then the auditing of ANY additional standard is just a matter or education on that standard. Yes, including AS 9100.
I'd rather have an auditor with audting skills and can be trained in knowledge on the standard, than no skills but only knowledge ANYDAY, ANYWAY, ANYTIME.
I beleve in education; however, education without practical application (i.e only theory) this worthless.
JaneB
#16
:topic:
Gentleman, there are ...
The world is not comprised entirely of men - there are plenty of us women on the forum. It would be nice not to be deliberately excluded or ignored via a term like 'gentlemen'.
A more inclusive term to use to address everyone would be: 'people' or 'fellow Covers'.
JaneB
#17
Me too.:applause:
Richard Pike
#18
:topic:
Is that a non-conformance? especially if detection only occurred two weeks after the event? or is it a cultural issue that the Auditor should consider prior to evaluation?
The world is a multi-cultural society - and even tho some of us may not agree with some of those cultures - as consultants and auditors we are, never the less, bound to accept them and are also bound not to try and impose our own culture on others - regardless of our beliefs.
Richard Pike
#19
You can't effectively audit design unless you have an understanding of the design process!
You can't audit Top Management unless you have an understanding of business management
You can't audit Monitoring and Measurement (of product) unless you have knowledge of quality engineering principles.
I,d rather have an Auditor that is FULLY competent to audit MY processes. Sorry compromise is not acceptable - either way!
The theoretical knowledge enables the Auditor to understand my Process and what it is trying to achieve (don,t say ISO compliance is what im trying to achieve P.L.E.A.S.E.)
In my opinion Auditors who are incapable of understanding the Process cause -so much - damage. Auditors without Auditing Skills - well they just get asked to leave!
Practical application is so dangerous without theoretical knowledge: Pity Deming is still not around, it was one of his favorite quotes.
JoCam
#20
Re: Internal Auditor lack of Competece.
If the auditor is incompetent I would think that audit findings, reports...etc. would expose the shortcomings. I would use these and approach the QA manager, suggesting training my be needed.
Exactly, job done.:D
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
J Your opinion on the better training org for IATF16949 Internal auditor and Lead Auditor IATF 16949 - Automotive Quality Systems Standard 3
Q Internal Auditor Training requirements for ISO 14001:2015 ISO 14001:2015 Specific Discussions 5
E Informational I would like to get some Internal Auditor Training Internal Auditing 31
J IATF 16949 CAR - Internal Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 15
A ISO 13485 - Internal Auditor Independence and Process Owners ISO 13485:2016 - Medical Device Quality Management Systems 3
Q AS 9100D internal auditor training requirements Internal Auditing 16
A Other Discussion Boards - Internal Auditor Coffee Break and Water Cooler Discussions 5
E Online training for an internal auditor to AS9120B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Internal Auditor Trainer's Requirement Internal Auditing 4
D IATF 16949 - Internal Auditor Training/Certification Requirements Training - Internal, External, Online and Distance Learning 2
R Internal Auditor vs. Public Accountant - Accounting Student Needing Help Career and Occupation Discussions 4
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
R Internal Auditor auditing Internal Audit Procedure (AS9100) Internal Auditing 18
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 10
H ISO/IATF Internal Auditor Recommendations For Manufacturer In California, USA Internal Auditing 3
Casana 2nd Party and Internal Auditor Qualifications & Training IATF 16949 - Automotive Quality Systems Standard 13
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
B Competency of Trainer for Internal Auditor Training (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 11
C ISO 13485:2016 - Internal Auditor Training vs. Lead Auditor Training Training - Internal, External, Online and Distance Learning 4
J Dinged on Internal Audits for supervising an auditor I was training Internal Auditing 10
M Internal Auditor --> Licence needed? Internal Auditing 6
V Internal Auditor Training Documents and PPT Document Control Systems, Procedures, Forms and Templates 5
V Internal Auditor Training Documents and PPT Internal Auditing 3
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
D Can the Plant Manager be our ISO Representative and an Internal Auditor? Internal Auditing 26
M ISO 13485 Audit Questions - Internal Auditor Training and other Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
M Questions about AS9100 Internal Auditor Training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
P Internal Auditor Training - Audit exercises Internal Auditing 5
D Training Material for Internal Auditor Requirements Training - Internal, External, Online and Distance Learning 4
U TS16949 Internal Auditor Training - Is On-line training OK? Training - Internal, External, Online and Distance Learning 1
F Internal Audit quiz - Auditor Qualifications and Requirements Internal Auditing 34
