Internal Audits performed by another local business
howste
Thaumaturge
#21
Why don't we just include the whole definition here for those who don't have a copy or don't feel like looking it up themselves:
ISO 9000:2015 said:
3.13.1
audit
systematic, independent and documented process (3.4.1) for obtaining objective evidence (3.8.3) and evaluating it objectively to determine the extent to which the audit criteria (3.13.7) are fulfilled
Note 1 to entry: The fundamental elements of an audit include the determination (3.11.1) of the conformity (3.6.11) of an object (3.6.1) according to a procedure (3.4.5) carried out by personnel not being responsible for the object audited.
Note 2 to entry: An audit can be an internal audit (first party), or an external audit (second party or third party), and it can be a combined audit (3.13.2) or a joint audit (3.13.3).
Note 3 to entry: Internal audits, sometimes called first-party audits, are conducted by, or on behalf of, the organization (3.2.1) itself for management (3.3.3) review (3.11.2) and other internal purposes, and can form the basis for an organization’s declaration of conformity. Independence can be demonstrated by the freedom from responsibility for the activity being audited.
Note 4 to entry: External audits include those generally called second and third-party audits. Second party audits are conducted by parties having an interest in the organization, such as customers (3.2.4), or by other persons on their behalf. Third-party audits are conducted by external, independent auditing organizations such as those providing certification/registration of conformity or governmental agencies.
Note 5 to entry: This constitutes one of the common terms and core definitions for ISO management system standards given in Annex SL of the Consolidated ISO Supplement to the ISO/IEC Directives, Part 1. The original definition and Notes to entry have been modified to remove effect of circularity between audit criteria and audit evidence term entries, and Notes 3 and 4 to entry have been added.
So, independence is still required in the standard, and audits must be carried out by personnel not responsible for the object/activity being audited.
The answer to the OP's question about using another company's auditors? Yes it's allowed. As others have mentioned there are pros and cons to doing it.
Randy
#23
Well we've gone full circle again with the primary problem being what is "independent"....
"So, independence is still required in the standard, and audits must be carried out by personnel not responsible for the object/activity being audited." That's not what is said, the statement is "can be demonstrated" not must or shall and not even should, but can and can is a voluntary decision.
In the case of audit "independence" the wording is such as to point out that the process needs to be free from improper influence and/or guidance to allow an honest objective look. Either that or there's literally a couple thousand people out there that have been taught totally wrong.
Earlier versions of 9001 specifically required that "auditors shall not audit their own work" and we all know that, but the wording was removed. Why? Because it was unnecessary BS when it can be demonstrated that the process was done in an objective, impartial manner, especially for the smaller mom & pops.
This mindset of "independence" being totally separate and outside and nothing to do with is a pile of rubbish because in no way can it guarantee impartiality and objectivity...Absolutely no way!
howste
Thaumaturge
#24
But that is what it says:
ISO 9000:2015 said:
Note 1 to entry: The fundamental elements of an audit include... carried out by personnel not being responsible for the object audited.
There is no can, might, or may in this text. The "can" is in note 3, to describe how conformity to the requirement "can" be demonstrated.
Sidney Vianna
Post Responsibly
#25
Because of compromises having to be reached due to the High Level Structure approach for Management System Standards. One more reason to pay EVEN CLOSER attention to normative references in the different standards. ISO 14001:2015, for example, lists no normative reference. ISO 9001:2015, on the other hand, does. It does matter a lot for the sake of management system standardization.
Sidney Vianna
Post Responsibly
#27
The "Notes" within the standard are references only and are not auditable against.
In requirements standards such as ISO 9001, notes are supposed to be clarifications; they are still "auditable", but are not supposed to be understood as firm requirements.
In standards such as ISO 9000, a principles and vocabulary document, notes are expansions of the definitions and provide valuable insight on the intent of the terms. As in the example that Howste provide for the definition of audits in the context of ISO 9001.
S Corrective Action from Internal Audits not performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M Program of Internal Audits aren?t performed fully - Is it nonconformance? General Auditing Discussions 20
E First external audit coming up, do I need to have performed Internal Audits already? Internal Auditing 15
A Internal Audits - What if performed by consultant Internal Auditing 9
S Internal Audits not performed - Useful data from internal audit schedule Internal Auditing 31
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
M ISO13485:2016, MDSAP and Internal Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
S Would this be a second site for the purposes of internal and third party audits? General Auditing Discussions 4
J ISMS - Internal Audits Internal Auditing 3
D CB and customer audits considered as internal audits? General Auditing Discussions 9
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
M Major vs. Minor for Internal Audits? Internal Auditing 10
C Internal Audits in a tiny Dx Company Internal Auditing 33
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
O Informational Scaling back internal audits due to corona virus while avoiding a NC Internal Auditing 7
G Internal Audits and Employee engagement Internal Auditing 16
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
qualprod Internal Audits - Categories of non conformances Internal Auditing 12
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
K A way to monitor our Internal Audits as a KPI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
A External Auditor issue with Internal Audits Internal Auditing 7
W Internal Auditing carried out by a 3rd party - Review of previous audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
E Informational Internal Audits - Wear multiple hats what can and can't I audit (so I'm not auditing my own work) Internal Auditing 149
Gman2 Quality Record Retention (Internal Audits, CA's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T Informational What is the purpose of Internal Audits? Internal Auditing 27
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
Pmarszal ISO 19011:2018 - Risk Based Approach for planning, conducting and reporting of internal audits Internal Auditing 8
R ISO 13485:2016 Registration - NC on full cycle of internal audits ISO 13485:2016 - Medical Device Quality Management Systems 7
J Internal Audit clarification - How to perform the audits IATF 16949 - Automotive Quality Systems Standard 6
W FAA Advisory Circular (AC) Requirements (FAA AC 00-56) - Internal Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B Going into IATF 16949 transition without Internal Audits IATF 16949 - Automotive Quality Systems Standard 4
K No Internal Audits For Upcoming IATF Trans Audit IATF 16949 - Automotive Quality Systems Standard 5
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
K AS9100 Rev. D Transition - Internal Audits & Gap Analysis Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J Internal Audits - Closing Audit Deficiency Reports (ISO 13485) Internal Auditing 4
S Is Audit Plan / Agenda required for Internal Audits? Internal Auditing 2
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
F What is your favorite software for ISO 9001:2015 Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
J Dinged on Internal Audits for supervising an auditor I was training Internal Auditing 10
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
M Are auditing checklists required for Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
D Using consultants for Internal Audits Internal Auditing 24
O New Job 1 Month from Recertification Audit - Missing Documents, no Internal Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
R How do I conduct my API Q1, ISO compliant internal audits? Internal Auditing 1
