Internal Calibration or Verification - Personnel Requirements
P
--poy
We are having our re-certification Audit starting next week.
I would just like to clarify something concerning the competency of calibration personnel.
Calibration and verification are two different activities, right?
If so, would it mean that competency requirement will only be strict for calibration personnel?
We have equipments that are calibrated (with adjustments) internally by a competent technician and equipments verified by the other techs.
We only have 1 technician competent enough (with training and experience) to do calibration (verification + adjustment)
The others are not. What I did is just let the others do the verification of gages so that when it is out of acceptable standards, we will have the gage calibrated either externally (certified lab) or by our competent technician.
At least, in that way, the work load of our calibration tech becomes lighter.
Do you think this will work out with no call out during the TS audit?
Please advice.
Raffy
Hi:bigwave:
Welcome to the cove. Its good to see people from the Philippines.
With regard to Competency, in our end, we have our Calibration personnel trained and certified by the OEM then when they echo-trained this to other technician(s), they also do the same. Training + Examination (Written and Actual), there should be a standard percent what should be the passing score.
With regard to TS Audit, all I can is that it varies (call-out) of the auditor, sometimes when you already made the preparation they can still find one. When you say you do the verification of gages, are the other technicians trained and certified to do verification?
Best regards,
Raffy:cool:
P
--poy
Thanks sir Raffy.
Actually, we only have one trained (certified) Technician for the calibration of one gage.
Verification of the other gages are done internally by internally trained technicians.
What confuses me a bit is that if it is safe to differentiate gage verification by internally trained technicians from gage calibration by an externally (certified) trained technician.
Raffy
Hi poy,
In our end, we have defined Calibration as "Comparing, measuring and test equipment with measurement standards of known accuracy. The purpose of which is to detect and adjust deviations from the standards. This occurs at regularly scheduled intervals determining the basis of stability, purpose and usage. This means that we don't actually calibrate our equipment, we only verify if the said equipment meet's or exceeds the user's (other department, i.e. engineering, resaearch & development, maintenance, etc. ) requirement. In view of this, a verification procedure was used to issue calibration stickers in lieu of a calibration procedure when no adjustment of our measuring equipment is necessary.
Hope this helps.
Best regards,
Raffy
B IATF 16949 - 7.1.5.3.1 Internal calibration laboratory requirements IATF 16949 - Automotive Quality Systems Standard 9
C MU (Measurement Uncertainty) in an Internal Calibration Laboratory Measurement Uncertainty (MU) 1
I Calibration Void Seals on Internal Equipment General Measurement Device and Calibration Topics 3
AmandaMusser Internal Calibration Process Suggestions General Measurement Device and Calibration Topics 6
S Internal Calibration Laboratory Inspection/Approval General Measurement Device and Calibration Topics 3
S Auditing TS 16949 Cl. 7.6.3.1 - Internal Calibration Laboratory Requirements IATF 16949 - Automotive Quality Systems Standard 8
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
N Internal Calibration vs. Accredited Calibration for Balance - Differences Calibration Frequency (Interval) 3
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
N Scale with Internal Calibration - Do I need to calibrate? How to document this? Calibration Frequency (Interval) 8
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
2 TS 16949 Cl. 7.6.3.1 - Internal Calibration Procedure not Traceable to ASTM, EN etc. IATF 16949 - Automotive Quality Systems Standard 20
H "Internal Calibration" using other Calibrated Equipment Calibration Frequency (Interval) 13
K Internal laboratory - applies only to Calibration or also to other laboratories? IATF 16949 - Automotive Quality Systems Standard 6
R Standard Methods - Internal Calibration Laboratory - What if there is no standard? IATF 16949 - Automotive Quality Systems Standard 2
M Internal tool calibration program - Best source to become "knowledgeable"? General Measurement Device and Calibration Topics 5
V Internal Scale and Balance Calibration Method Tolerances and Limits General Measurement Device and Calibration Topics 4
D ISO/TS16949 Internal Calibration Lab need to include Production Equipments IATF 16949 - Automotive Quality Systems Standard 26
M How to Internal Audit the Calibration Process Internal Auditing 12
C Internal Diameter Measurement and Pin Gage Calibration General Measurement Device and Calibration Topics 6
K Internal Calibration - Testing Laboratory General Measurement Device and Calibration Topics 9
Q Internal Testing and Calibration Laboratories - MSA, Gage R&R and Control Plans IATF 16949 - Automotive Quality Systems Standard 2
M Company Internal Calibration - Is Internal Calibration a LABORATORY? TS16949 General Measurement Device and Calibration Topics 24
C Internal Audit of Internal Calibration Laboratory - Inspection sample size question Internal Auditing 2
D Internal Laboratory - Defining the Laboratory Scope - Inspection, Test, Calibration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
L Internal Calibration Laboratory Requirements - Ambient temperature, Humidity, Etc. Statistical Analysis Tools, Techniques and SPC 3
K Should QS/TS certified internal test/calibration labs be required to be ISO17025 ISO 17025 related Discussions 16
V Does an internal calibration laboratory need to be certified on ISO 17025? ISO 17025 related Discussions 3
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 2
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
A QMS Overhaul - Reorganizing and Renaming Documents - Internal References Document Control Systems, Procedures, Forms and Templates 18
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Internal PPM Manufacturing and Related Processes 1
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 15
S Risk based internal auditing Internal Auditing 6
O Informational Scaling back internal audits due to corona virus while avoiding a NC Internal Auditing 7
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Software for Supplier Charge back and internal PPM General Information Resources 2
G Internal Audits and Employee engagement Internal Auditing 16
I What direction do you provide your internal auditors on OFIs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 3
F AS9100D Internal auditing requirements Internal Auditing 3
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
