Internal Nonconformance procedure thoughts (AS9100)
Techster
Our current non-conformity procedure is that any claims raised by a customer is going through 8D process unless the claim is denied.
But our internal procedure is a bit more fluffy.
If non-conformity is found by final inspection -> 8D report
If non-conformity is found when doing in process measurements we evaluate the need for doing more than just registration.
Is there anyway this is conflicting with the requirements in AS9100. I don't believe it is, but a consultant who helped us out in the beginning of the transition from ISO9001 to AS9100 thought it were crucial to have the actual root cause and prevent the the re-occurence. And I believe our auditor agrees it him.
Our primary evaluation criteria is based on cost of the actual failure, the cost of preventing the failure, the risk of not finding the failure and the risk for our customers.
We do the registration because then we can track the costs of certain kind of mistakes like is it always like bad setup up of machine or high pressure pumps failing.
This way we are available to at some point to look at our high pressure pumps and see if doing something with those with minimize the amount and costs of NCs'.
We do a lot of non-aviation parts and we do a lot of mass production, so things like a broken drill or early wear on an insert does happen a lot. There is between 0-5 internal NCs a day, so doing 8D reports on everything is just a waste of resources in my oppinion.
Please share your thoughts.
Cari Spears
We do not initiate root cause investigation for every occurrence of nonconforming product. Our process is very much as you've described - we log nonconformances and try to track common causes that we may decide to initiate a CAR for - and sometimes something happens only once, but we initiate a CAR because it cost a lot or impacted our ability to deliver on time. We do initiate a CAR for all customer complaints or quality escapes.
Mike S.
Happy to be Alive
Doing an 8D for every nonconformity is, IMO, like going to the doctor for every injury you ever have, no matter the severity. Sometimes it's just a paper cut or a stubbed toe or slight muscle strain that doesn't need a doctor.
However, if your procedure says you shall go to the doctor for every injury you ever have, no matter the severity, you had better either follow it or revise it. I'd suggest the latter.
Kronos147
...crucial to have the actual root cause and prevent the the re-occurence.
It's all about your system, and what you need to achieve your goals.
The standard says:
react to the nonconformity and, as applicable:
1. take action to control and correct it;
2. deal with the consequences;
evaluate the need for action to eliminate the cause(s) of the nonconformity, in order that it does not recur or occur elsewhere, by:
1. reviewing and analyzing the nonconformity;
2. determining the causes...
3. determining if similar nonconformities exist, or could potentially occur;
No where does it say do an 8D.
If you have a process where you already 'know' the production problem causes (pump squeaks louder and makes a high frequency sound = gasket installed backwards), then you know the cause and you don't have to determine it (again).
If there exists the need to take action to correct it, do that, else control it and deal with the consequences (rework, scrap).
I will add, if you don't log these events, you may never know how prevalent it is. Some organizations may institute a three strikes, it's a corrective action type of policy. Do what makes the process effective. You are right to push back if 8D's become the tail that wags the dog. It makes them less effective when you really need them.
As pointed out above, the standard requires that you "evaluate the need". It doesn't require root cause analysis for all cases. You get to determine when you need to go beyond correction and into corrective action.
When you always dig deep you will always be running behind and trying to catch up, and when in catch up mode you are likely to miss the critical things.
If there internal NCRs and not severe, keep them categorized as an NCR and stay away from recording them as a CAR. I'm sure there are several threads on the distinction. This will cause confusion on audits and customer calls reviewing your internal systems.
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
K Internal Auditing a previous Nonconformance? Internal Auditing 19
R Internal Audit Scope Requirements - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Raising a Major Nonconformance during an Internal Audit Internal Auditing 23
E "Internal" CAPA (Audit Nonconformance) Issuance to your own Department Nonconformance and Corrective Action 4
J Auditing the Internal Auditing Process - Audit Nonconformance General Auditing Discussions 3
R Internal Audit Report Nonconformance Follow Ups Internal Auditing 5
S Do you tie a Nonconformance (NC) into the last Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
E Internal Audit Nonconformance Classification Internal Auditing 18
M Program of Internal Audits aren?t performed fully - Is it nonconformance? General Auditing Discussions 20
S External Auditor Findings when an Internal Audit found a Nonconformance Yesterday Document Control Systems, Procedures, Forms and Templates 11
T Incorrect Data in Inventory List - Internal Audit Nonconformance Nonconformance and Corrective Action 33
P Lack of 3rd Shift Internal Audit - Major or Minor NC (Nonconformance)? Internal Auditing 17
P Internal Audit NC (Nonconformance) is not closed - Is it a nonconformity? IATF 16949 - Automotive Quality Systems Standard 11
C SA 8000 Internal Audit - Anyone knows what a nonconformance in 9.7/9.7a be like? Other ISO and International Standards and European Regulations 14
C Alternate Terms for NonConformance, Internal Audits, Corrective and Preventative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
S TS 16949 Clause 8.5.2 Audit Nonconformance for not issuing internal CARs IATF 16949 - Automotive Quality Systems Standard 14
Antonio Vieira The importance of some processes... Internal Audit, Management Review, Nonconformance Management Review Meetings and related Processes 3
C Internal Audit Training Help - Audit Nonconformance Training - Internal, External, Online and Distance Learning 11
J Nonconformance reports written only through internal audit findings? Nonconformance and Corrective Action 8
C Internal Audit - Is This A Nonconformance? Internal Auditing 31
A Definition Major vs. Minor Nonconformance (Finding) - Internal Audit - Definition & Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 38
C ISO 14001 Internal Audit - Opportunity for Improvement ISO 14001:2015 Specific Discussions 2
T Ford CSR for Internal Auditors 2021 Internal Auditing 4
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
P Looking to outsource Internal Audit - MDSAP competent auditor needed Other Medical Device Regulations World-Wide 9
D INTERNAL LABORATORY IATF 16949 - Automotive Quality Systems Standard 4
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J IATF CB Auditor questions Internal Auditor Competence IATF 16949 - Automotive Quality Systems Standard 19
J Outsourced Internal Audit requirements for Aerospace Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
D Number of people to be interviewed during an internal audit? Internal Auditing 6
cgaro62 Using internal audits as part of document reviews Document Control Systems, Procedures, Forms and Templates 21
S Is it required to complete Internal Audits within one year? ISO 13485:2016 - Medical Device Quality Management Systems 29
C First Round of QMS Internal Audits - Ethical Dilemma Internal Auditing 7
T How to conduct combined internal audits (9001 and 13485) Internal Auditing 1
Q Easy CARs for Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
C API Q1 internal audit report Internal Auditing 3
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 6
M Must a company be 17025 accredited to perform internal calibrations? ISO 17025 related Discussions 7
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 2
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
J Internal audit random sampling methodology Internal Auditing 2
G Organizing internal audit program for an Integrated QHSE Management System Internal Auditing 13
W How do you phrase your internal audit questions? Internal Auditing 3
M IATF - Internal Audit 3 year span Internal Auditing 4
Thee Bouyyy Internal NCR - API Q1 5.4.2b - API 16C Clause 4.1.3 Internal Auditing 9
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
