Dear all,
Is there anyone could help me whether the below statement is correct or not:
Average shrinkage = 0.26%
Standard Deviation (σ)of shrinkage = 0.024%
Dimension of molded part = 21.03mm
Considering of only changes of molded shrinkage caused by material,
and if we think it’s within the control (it means Cpk1.33(±4σ)
the changes of dimension should be within the figure as follows:
21.03X8X0.024 = 0.04mm
It means that even if the dimension changes according to the changes ±4σ of molded shrinkage caused by material itself, the changes of dimension should be within the tolerance of ±0.05mm
Could you please share with me of why it is correct or incorrect.
Thank you very much
Thank you very much
