Interpretation of MDR 2017/745 Article 23 - CE Mark Requirements
fialor
Hello Everyone,
I am in the middle of an MDD audit and my NB has dropped a huge bombshell with regards to the upcoming MDR which I disagree with.
I would appreciate it if anyone could shed some light on what their interpretation or their NB's interpretation of article 23 is.
My NB has advised that Article 23 means that going forward for the MDR (come implementation in 2020) all device critical components and sub-assemblies must be CE marked. The NB has advised that we begin to get our components and sub-assembly suppliers to get CE marking for their devices, in readiness for compliance with MDR.
I disagree with interpretation ( and I was not shy about it! :nope: probably not done myself any favours) but my understanding of the article is that "anyone who seeks to provide a replacement component on the market for a device must ensure that it performs to the same level as the original component that it is intended to replace."
I have have read and re-read article 23 a few times but cannot see anywhere that it says/states/implies that CE marking of critical components is a must?!
Or even any wording that I can stretch to mean that.
Your feedback would be very appreciated.
Fialor
dgrainger
Article 23 applies to components placed on the market to replace " an identical or similar integral part or component of a device". It's only adding the spare part guidance in MEDDEV 2.1/1 I.1,1b to the regulation:
Spare parts supplied for replacement of existing components of a
device, the conformity of which has already been established, are not
medical devices. If spare parts, however, change significantly the
characteristics or performances of a device with regard to its already
established conformity, such spare parts are to be considered as
devices in their own right.
There is nothing new!
fialor
I agree but somehow I cannot seem to get this into my NB and it worries me that this is the interpretation that this is being used to also offer training to clients by this NB. "Me" thinks I shall change NBs.
Marcelo
Is this a formal position of your NB or a opinion from a NB auditor? Unfortunately, I'm seeing a lot of stupid remarks from NB auditors regarding the MDR (the last one I've seen was that instructions for use cannot be electronically anymore, which clearly means that the auditor has not read the MDR), but again I've always seen stupid remarks about the MDD also, so what I still suggest is is - you have to understand the requirements you have to comply with, not the NB :p
fialor
I agree MArcelo but in this instance it is most likely the same auditor who will run the NB CE review and this interpretation from the auditor only leads us down a path of incorrect NCs come the MDR audits. :confused:
Marcelo
You can always require a change of auditor, or complaint to the NB or complain to the EU Commission, or do all three together.
pkost
As a first step I would suggest asking the technical manager at the NB to have a polite word with the auditor to ensure no misinterpretation of the requirements occurs in the future
Failing that your competent authority should be able to provide an email/letter confirming your interpretation which should get the NB to back off
Yes, I also confuse what's the most interpretation for the article 23. what way can we comply with article 23? spare part procedure need to be established?
Article 23 Parts and components:
1.Any natural or legal person who makes available on the market an item specifically intended to replace an identical or similar integral part or component of a device that is defective or worn in order to maintain or restore the function of the device without changing its performance or safety characteristics or its intended purpose, shall ensure that the item does not adversely affect the safety and performance of the device. Supporting evidence shall be kept available for the competent authorities of the Member States.
2.An item that is intended specifically to replace a part or component of a device and that significantly changes the performance or safety characteristics or the intended purpose of the device shall be considered to be a device and shall meet the requirements laid down in this Regulation
chris1price
I read Article 23 as saying, if you supply a spare part that does not change the performance, safety characteristics or intended use, you must have evidence to back up that position. If the spare part does make a change, you must CE Mark the spare part.
It is nothing to do with critical components or suppliers. Talk to your scheme manager, the auditor has definitely got it wrong.
G EU MDR 2017/745 Rule 11 interpretation - Re-classification of a Software as Medical Device Other Medical Device Related Standards 0
U MDD Article 12/ MDr Article 22 interpretation EU Medical Device Regulations 2
R MDR, Annex I, 23.1 Interpretation - IFU on the website EU Medical Device Regulations 5
M MDR Article 22 Interpretation EU Medical Device Regulations 3
I Interpretation of the MDR GSPR 23.4 (u) EU Medical Device Regulations 2
P MDR Rule 10 interpretation - Active Device EU Medical Device Regulations 3
R MDR Software Rule 11 Formal Interpretation EU Medical Device Regulations 7
D EU MDR Corrigendum Interpretation EU Medical Device Regulations 3
L Interpretation of MDR Reportable Event - FDA guidance on Medical Device Reporting 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
Q Contingency plan - IATF Sanctioned Interpretation 17 IATF 16949 - Automotive Quality Systems Standard 2
D IATF16949 - Interpretation of Customer Requirements clauses Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
A OEM branding - My interpretation of the LVD Directive makes us a manufacturer CE Marking (Conformité Européene) / CB Scheme 3
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
B ISO 50001 Interpretation of section 3.3.9 (Outsourcing) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Interpretation of significant change - material change Canada Medical Device Regulations 3
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
G Medical Device "Immediate Container" Interpretation of Definition US Food and Drug Administration (FDA) 2
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
JoshuaFroud Interpretation of Clause 5.5.2 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod P x I = Value interpretation for residual risk? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T CSA Z299.3-85 Nuclear interpretation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D VDA Trigger Matrix in the VDA 6.2 Manual - Interpretation and Use VDA Standards - Germany's Automotive Standards 3
B Interpretation of Customer Specific Requirements of Continental - Records Retention Customer and Company Specific Requirements 6
S Interpretation or Definition of ‘Once Every 5 Days’ ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N What is the interpretation I-MR-R chart in this question? Statistical Analysis Tools, Techniques and SPC 1
E ME (Medical Equipment) Systems - IEC 60601-1 Clause 16.1 Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
P IATF 16949 Cl. 7.1.5.2.1 "Calibration/Verification Records" Interpretation IATF 16949 - Automotive Quality Systems Standard 12
B Clarification on interpretation of some EN ISO 14971:2012 & IEC 62304:2006 req's ISO 14971 - Medical Device Risk Management 46
M IATF 16949 - 7.1.3.1 Plant, Facility, and Equipment Planning - Interpretation IATF 16949 - Automotive Quality Systems Standard 8
R Location Interpretation on Drawing - Hole to Hole? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T TS 16949 Clause 7.4.1.2 and Sanctioned Interpretation IATF 16949 - Automotive Quality Systems Standard 12
D Interpretation of new IAQG ruling - Audit duration for nonconformance verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Interpretation of IEC 60601-1-2 Electromagnetic Compatibility – Requirements & tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
D Interpretation of DOE interaction plot Using Minitab Software 8
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L Interpretation of "Any or All"'? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
G Interpretation of phrase - "Direct Authority" EASA and JAA Aviation Standards and Requirements 5
pittmatj Brazil: Interpretation of RDC 185 Other Medical Device Regulations World-Wide 6
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
M Interpretation of Plus/Minus Draft - Injection Molded Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
E FDA Significant Change Interpretation - Guidance Document EU Medical Device Regulations 2
0 ISO 9001:2008 interpretation not the same per country? (Netherlands and France) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Multiple Standard Interpretation Queries Occupational Health & Safety Management Standards 4
