Interpretation of Plus/Minus Draft - Injection Molded Parts
MaryMalin
Hello All,
First let me apologize for my ignorance - I've not previously posted a question.
I need some help and clarification regarding inspection of injection molded parts. We have engineering drawings which state a dimension and either plus draft or minus draft. The question pertains to how the inspection dept is to provide (or report) results. For example, if a feature is called out a diameter with "minus draft", should the inspection report state the smallest or largest diameter measured?
NikkiQSM
I work for a medical plastics company, where we provide compounded plastic pellets.
Our pellet size has a deviation of "+/- X.XXX" Plus would be the maximum, and minus would be the minimum.
I would say your report should state the smallest diameter if it states "minus draft".
MaryMalin
Thank you. The other interesting aspect is that several of our Engineers are of the understanding that the physical placement of the dimension on the drawing dictates the direction of the draft. For example, if the dimension is placed on the left side of a feature and states minus draft - the understanding is that the farthest point of the feature (away from the dim) would be the smallest.
RSEGRIGGY
Are you measuring an outside diameter or an inside diameter?
An inside diameter that has a size 4.000 +-.035 plus draft I would interpret as the largest measurement to be less than 4.035. The additional draft adds more material, so the hole could be smaller than the tolerance as the draft increases and the hole closes up.
If you were measuring an outside diameter of 4.000 +-.035 plus draft, I would interpret the smallest measurement must be at least 3.965. Extra material on the exterior could increase the diameter beyond the tolerance.
Do you have any tolerance on draft? Degrees or additional material perhaps?
I'm not familiar with the physical placement of the dimension on the print having the connotation that you mention.
MaryMalin
We are measuring an outside diameter. Unfortunately, no draft angle or draft tolerance is stated on the drawing.
RSEGRIGGY
What does your call out say exactly? Does it reference a standard like Y14.5?
If you get an outside diameter requirement of "4.000 minus draft", it sounds like the intent is the outside has to be at least 4.000 no matter where you measure it. But how much draft is too much? If the part is 5.000 all around, is that acceptable?
Based on the given information, it sounds like you can make a statement of either "It meets the minimum" or "It does not exceed the maximum."
One way is to just state the range you measure. Report your results but do not interpret as to good or bad. Example: "OD is 3.590 to 4.015."
Q Contingency plan - IATF Sanctioned Interpretation 17 IATF 16949 - Automotive Quality Systems Standard 4
U MDD Article 12/ MDr Article 22 interpretation EU Medical Device Regulations 2
R MDR, Annex I, 23.1 Interpretation - IFU on the website EU Medical Device Regulations 5
M MDR Article 22 Interpretation EU Medical Device Regulations 3
I Interpretation of the MDR GSPR 23.4 (u) EU Medical Device Regulations 2
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P MDR Rule 10 interpretation - Active Device EU Medical Device Regulations 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
A OEM branding - My interpretation of the LVD Directive makes us a manufacturer CE Marking (Conformité Européene) / CB Scheme 3
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
B ISO 50001 Interpretation of section 3.3.9 (Outsourcing) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Interpretation of significant change - material change Canada Medical Device Regulations 3
R MDR Software Rule 11 Formal Interpretation EU Medical Device Regulations 7
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
F Interpretation of MDR 2017/745 Article 23 - CE Mark Requirements EU Medical Device Regulations 8
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
G Medical Device "Immediate Container" Interpretation of Definition US Food and Drug Administration (FDA) 2
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
D EU MDR Corrigendum Interpretation EU Medical Device Regulations 3
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
G EU MDR 2017/745 Rule 11 interpretation - Re-classification of a Software as Medical Device Other Medical Device Related Standards 0
JoshuaFroud Interpretation of Clause 5.5.2 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod P x I = Value interpretation for residual risk? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T CSA Z299.3-85 Nuclear interpretation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D VDA Trigger Matrix in the VDA 6.2 Manual - Interpretation and Use VDA Standards - Germany's Automotive Standards 3
B Interpretation of Customer Specific Requirements of Continental - Records Retention Customer and Company Specific Requirements 6
S Interpretation or Definition of ‘Once Every 5 Days’ ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N What is the interpretation I-MR-R chart in this question? Statistical Analysis Tools, Techniques and SPC 1
E ME (Medical Equipment) Systems - IEC 60601-1 Clause 16.1 Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
P IATF 16949 Cl. 7.1.5.2.1 "Calibration/Verification Records" Interpretation IATF 16949 - Automotive Quality Systems Standard 12
B Clarification on interpretation of some EN ISO 14971:2012 & IEC 62304:2006 req's ISO 14971 - Medical Device Risk Management 46
M IATF 16949 - 7.1.3.1 Plant, Facility, and Equipment Planning - Interpretation IATF 16949 - Automotive Quality Systems Standard 8
R Location Interpretation on Drawing - Hole to Hole? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T TS 16949 Clause 7.4.1.2 and Sanctioned Interpretation IATF 16949 - Automotive Quality Systems Standard 12
D Interpretation of new IAQG ruling - Audit duration for nonconformance verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Interpretation of IEC 60601-1-2 Electromagnetic Compatibility – Requirements & tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
D Interpretation of DOE interaction plot Using Minitab Software 8
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L Interpretation of "Any or All"'? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
G Interpretation of phrase - "Direct Authority" EASA and JAA Aviation Standards and Requirements 5
pittmatj Brazil: Interpretation of RDC 185 Other Medical Device Regulations World-Wide 6
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
E FDA Significant Change Interpretation - Guidance Document EU Medical Device Regulations 2
0 ISO 9001:2008 interpretation not the same per country? (Netherlands and France) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Multiple Standard Interpretation Queries Occupational Health & Safety Management Standards 4
A Need MSA %GRR Interpretation Advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
