Interpretation with regards to Ppk > Cpk
Good Day!
New member here
I am currently searching for interpretation with regards to Ppk > Cpk, and seems I found already with this forum, however it is way back 2007
Merely, I encountered this condition and here is my data. Could anyone assist me for the interpretation of the result
USL = 25
LSL = -25
6.70
7.27
-0.64
6.23
-5.76
10.65
6.00
5.51
-0.60
3.30
2.07
-5.46
1.06
-4.69
-0.70
-4.42
11.73
-1.07
3.24
0.34
-4.56
-5.74
6.87
2.02
-7.69
2.70
-1.94
6.14
2.04
2.94
Cp = 1.47 / CpU = 1.39 / CpL = 1.56 / Cpk = 1.39
Pp = 1.64 / PpU = 1.54 / PpL = 1.73 / Ppk = 1.39
Bill Levinson
Industrial Statistician and Trainer
I get what you get but Ppk, which includes long and short term variation, cannot exceed Cpk, which includes only short term variation. I could however envision the estimate of Cpk exceeding the Ppk because the short term variation estimate must come from a moving range and, noting especially -4.42 next to 11.73, the order of the measurements can result in different Cpks and possibly generate one less than Ppk which depends on the standard deviation of all the data regardless of their order.
There is by the way no obvious reason to suspect the process is not in a state of statistical control nor is there evidence of non-normality. (Charts are by Minitab.)
Bill Levinson
I wanted to randomize the order of your data to see whether I would get a different Cpk, and StatGraphics did this for me.
2.07
10.65
-0.64
2.04
11.73
6.87
-7.69
6.23
6.00
7.27
3.24
2.02
5.51
0.34
-5.46
-4.56
2.94
6.14
-0.70
-4.69
-4.42
-0.60
3.30
2.70
-1.94
-5.74
-1.07
-5.76
1.06
6.70
and now Cpk > Ppk but not by all that much. My belief is that, the first time around, we simply got lucky (or unlucky) and the order of the data was such that some of the moving ranges were large enough to make the short term variation estimate exceed the long term variation estimate.
Welshwizard
Hi Arnefer 1206,
To directly answer your questions;
If the data is gathered rationally and in time series order it appears reasonably homogenous and therefore we can say predictable.
I agree with Cpk,Cp and Pp but have a small discrepancy for Ppk.
Ppk = 2DNS/6s = 47/30.51 = 1.54 not the 1.39 shown.
If we make the assumption that the process is predictable and centred then all these indexes describe the same thing. The differences you see are due to the differences in the computation of the global standard deviation vs the within subgroup estimate of this, for example the within subgroup estimate of Sigma X is 5.673 whilst the global estimate of standard deviation is 5.086.
Of course, if Ppk is more than Cpk then it just means that the divisor for the Ppk is less than that for Cpk which in this case it is.
So, the differences are marginal here, it appears that the process is quite healthy.
Hope this helps.
toniriazor
There is always a confusion about Ppk and Cpk.
In some places I read Cpk is given to be a long-term indicator if the process is in statistical control. Then some weeks later I read Ppk is the long-term indicator about process in statistical control. Really this is so confusing for beginners.
Any good read explaining once and forever these two with clear examples ?
thank you.
Bill Levinson
Ppk is the long term indicator because it includes both short and long term variation sources, while Cpk accounts only for short term (within sample, or between successive individuals) variation.
John Predmore
On one level, the formula is the same, you have to understand where the estimate for standard deviation came from. Ppk uses the standard deviation of a sample compared to the tolerance range. Cpk uses the standard deviation calculated from SPC, such as R-bar divided by d2. The way SPC works is to separate short-term variation (within groups) from long-term (between groups), but it is not the calculation which does the magic, it is the fact the data are organized chronologically and there are "logical subgroups". If you took data from a year's production in random order and plotted an X-bar/R chart, your estimate of R-bar/d2 would include long-term variation. Ppk includes long-term variation only if the sample includes parts made over a long period of time. I have seen suppliers take a sample from a single batch and calculate "Ppk", but that calculation does not include batch-to-batch variation over time even though the calculation is the same.
What John said!
While there is a lot of confusion around these indices it mostly just boils down to what formula is used for the variation and the sampling scheme.
Using within subgroup variation to estimate the SD or using a small run (no lot to lot or setup to set up or operator to operator variation is short term capability. Using the total sample standard deviation across all components of variation is long term capability. The use of the letter Cpk or Ppk are not reliable or consistent indicators of short or long term.
Of course the bottom line is that the whole Ppk/Cpk thing is an abomination and should be eliminated from the quality profession...
H IEC 61010-1:2010/A1:2016 - Clause 10.5.3 - (b) - Interpretation CE Marking (Conformité Européene) / CB Scheme 6
M Rebuild interpretation Federal Aviation Administration (FAA) Standards and Requirements 3
O Article 120 - significant change interpretation EU Medical Device Regulations 7
Ashland78 9.3.2.1 Sanctioned Interpretation IATF 16949 - Automotive Quality Systems Standard 2
W 7.1.5.3.2. External laboratory Sanctioned Interpretation IATF 16949 - Automotive Quality Systems Standard 4
F Interpretation of 60601-1 Figure J.5 (Isolation, example 5) for a rechargeable, battery operated device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B Sanctioned interpretation #10 - ISO 17025 IATF 16949 - Automotive Quality Systems Standard 2
somashekar Interpretation of 6.3 Infrastructure in the context of new machines ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Contingency plan - IATF Sanctioned Interpretation 17 IATF 16949 - Automotive Quality Systems Standard 4
U MDD Article 12/ MDr Article 22 interpretation EU Medical Device Regulations 2
R MDR, Annex I, 23.1 Interpretation - IFU on the website EU Medical Device Regulations 5
M MDR Article 22 Interpretation EU Medical Device Regulations 3
I Interpretation of the MDR GSPR 23.4 (u) EU Medical Device Regulations 5
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P MDR Rule 10 interpretation - Active Device EU Medical Device Regulations 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
A OEM branding - My interpretation of the LVD Directive makes us a manufacturer CE Marking (Conformité Européene) / CB Scheme 3
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
B ISO 50001 Interpretation of section 3.3.9 (Outsourcing) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Interpretation of significant change - material change Canada Medical Device Regulations 3
R MDR Software Rule 11 Formal Interpretation EU Medical Device Regulations 7
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
F Interpretation of MDR 2017/745 Article 23 - CE Mark Requirements EU Medical Device Regulations 8
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
G Medical Device "Immediate Container" Interpretation of Definition US Food and Drug Administration (FDA) 2
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
D EU MDR Corrigendum Interpretation EU Medical Device Regulations 3
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
G EU MDR 2017/745 Rule 11 interpretation - Re-classification of a Software as Medical Device Other Medical Device Related Standards 0
JoshuaFroud Interpretation of Clause 5.5.2 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod P x I = Value interpretation for residual risk? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T CSA Z299.3-85 Nuclear interpretation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D VDA Trigger Matrix in the VDA 6.2 Manual - Interpretation and Use VDA Standards - Germany's Automotive Standards 3
B Interpretation of Customer Specific Requirements of Continental - Records Retention Customer and Company Specific Requirements 6
S Interpretation or Definition of ‘Once Every 5 Days’ ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N What is the interpretation I-MR-R chart in this question? Statistical Analysis Tools, Techniques and SPC 1
E ME (Medical Equipment) Systems - IEC 60601-1 Clause 16.1 Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
P IATF 16949 Cl. 7.1.5.2.1 "Calibration/Verification Records" Interpretation IATF 16949 - Automotive Quality Systems Standard 13
B Clarification on interpretation of some EN ISO 14971:2012 & IEC 62304:2006 req's ISO 14971 - Medical Device Risk Management 46
M IATF 16949 - 7.1.3.1 Plant, Facility, and Equipment Planning - Interpretation IATF 16949 - Automotive Quality Systems Standard 8
R Location Interpretation on Drawing - Hole to Hole? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T TS 16949 Clause 7.4.1.2 and Sanctioned Interpretation IATF 16949 - Automotive Quality Systems Standard 12
D Interpretation of new IAQG ruling - Audit duration for nonconformance verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Interpretation of IEC 60601-1-2 Electromagnetic Compatibility – Requirements & tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
D Interpretation of DOE interaction plot Using Minitab Software 8
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L Interpretation of "Any or All"'? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
