Interpreting the Calibration Report for my Dial Indicator
s4000853
hi there, i know that this post is a bit outdated. but i would like to make use of this post to ask some questions.
i received a calibration report for my dial indicator.
MANUFACTURER STARRETT (709A)
RANGE 0 - 0.003 INCH
FEATURE INSPECTED ALLOWABLE ERROR (INCH) MEASURE VALUE (INCH)
REPEATABILITY 0.00005 0.00003
DISCRIMINATION 0.00015 0.00012
LIJMITS OF ERROR FOR
AN INTERVAL OF
ANY ONE DIVISION 0.0001 0.00009
ANY FIVE DIVISION 0.00025 0.00014
ANY HALF REVOLUTION 0.0005 0.00051
in any case of a vernier caliper report, it is quite straight forward to get my resultant error and decide whether tool is good to use compare with my tolerance. but in this case, i am not sure how to read the report and whether it is good to use for my application.
P
Pezikon
I see your conundrum. I've never seen that before. Never the less, I will present what it looks like to me.
Assuming; range = 0.03, resolution = 0.0005.
Test indicators (such as your Starrett 709) are usually pre-loaded and zero'd right before use. A user might pre-load the test indicator anywhere throughout the range. A user might pre-load the test indicator half way though the range, leaving only 0.015 of travel remaining. One might say, to give you a test point of "0.010 inch" would be meaningless because it's 0.010 inches relative to some arbitrary zero. Obviously, this is not a problem for a vernier caliper because it's zero is not relative; it is absolute. You cannot reset the zero on a vernier caliper.
So instead of giving you data for 0.010", 0.020", and 0.030", you might get data that tells you how much error is present when the needle moves only one division. How much error is present when the needle moves five divisions. How much error is present when the needle moves a half revolution.
Judging from the excessive precision of the data, I would bet that the standard used to calibrate your test indicator was something like a Mahr 400B-50. The technician zero'd everything and then oh so carefully turned the calibrator up until the the needle on the test indicator read one division. He then looked at the digital display which read 0.00059. That's +0.00009 of error. However, I would say the uncertainty attributed to UUT resolution is at best 0.0001". If the technician had repeated the measurement several times, I'm sure he would have seen numbers like, 0.00056, 0.00061, etc. Or maybe they're good and they reported the average.
I digress. If I were to convert the data into something you are more familiar with, it would look like so:
0.0005 = 0.00059
0.0025 = 0.00264
0.0150 = 0.01551
The last data point is at the edge of its tolerance. If I were to extrapolate the data for 0.02 or 0.03, they would be out of tolerance. How convenient that such data was not given. On the other hand, extrapolated values are merely conjecture.
SATHYABALARAMAN
hi,
Does your calibration report has a standard reference?
If so, permissible error will be mentioned in the standard, the calibrated readings can be verified against the permissible error & judgement can be made accordingly.
For Dial indicators refer IS standard IS 2092-1983.
Hope this helps..
Hershal
Metrologist-Auditor
What is the reported uncertainty by the cal lab?
Given the numbers involved, that may be more important.
B Length Measure - Interpreting Calibration Results and Measurement Uncertainty (MU) Measurement Uncertainty (MU) 3
N Interpreting Hygrometer Calibration Uncertainty - Temperature Coefficient Measurement Uncertainty (MU) 1
C Interpreting Outside Laboratory Calibration Certificate Measurement Uncertainty (MU) 3
Q Interpreting calibration result of Air Particle Counter on Counting efficiency General Measurement Device and Calibration Topics 1
L Interpreting calibration certs with MU General Measurement Device and Calibration Topics 1
Q Interpreting Tensile Charts General Measurement Device and Calibration Topics 0
Q Interpreting China Medical Device regulations/standards China Medical Device Regulations 1
P ISO 80369-7 standard - Interpreting which Parts should be in scope Other Medical Device Related Standards 7
K PACS - interpreting MDD and Borderline Guidance CE Marking (Conformité Européene) / CB Scheme 5
M List of Packaging Contents - Medical Devices - Interpreting EU Directive 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 3
D Interpreting Normal vs Weibull Capabilities Capability, Accuracy and Stability - Processes, Machines, etc. 4
P Interpreting Span Measurement - P95-P5 Six Sigma 1
B Interpreting Deviations 5 & 6 in Annex ZA in ISO 14971:2012 ISO 14971 - Medical Device Risk Management 1
B Interpreting "misuse" when assessing Hazardous Situations ISO 14971 - Medical Device Risk Management 2
S Interpreting clause 4.1.5 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 9
M Interpreting Process Controls - 21 CFR Part 820.70(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Help interpreting 21 CFR Part 806 (corrections and removals) Other US Medical Device Regulations 1
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Biocompatibility in Respiratory Products - Help interpreting whitepaper IEC 60601 - Medical Electrical Equipment Safety Standards Series 22
I Interpreting Product Realization (Clause 7) in ISO 9001:2008 for Service Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V GD&T Interpreting Datums in Two Single Segmented Position Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Interpreting X bar and R Control Charts Statistical Analysis Tools, Techniques and SPC 2
B Help with interpreting stock market terminologies Coffee Break and Water Cooler Discussions 4
V Interpreting Zinc Plating Specification GMW 3044 - 6K96/48 APQP and PPAP 2
K Interpreting and Applying 7.3.2 Design and Development Inputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Interpreting Level of Confidence - Round Robin for Tensile Testing - Help needed Statistical Analysis Tools, Techniques and SPC 4
M Interpreting AS9100 Clause 8.2.2 Internal Audit Requirements Internal Auditing 28
T Interpreting my t test in Minitab Using Minitab Software 2
S Interpreting Linear Regression Results from Minitab Using Minitab Software 15
optomist1 Interpreting LMC for Pattern of Slots (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
optomist1 Interpreting Minitab Test For Equal Variances Using Minitab Software 3
V Interpreting Minitab Gauge R&R Results Using Minitab Software 6
A ISO 2081 - Interpreting Coating Thickness Other ISO and International Standards and European Regulations 3
L Interpreting Injection Molding Tooling Documents - Cavities Manufacturing and Related Processes 3
C Interpreting Gage R&R Results - 3 operators, 3 iterations and 10 parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Interpreting Measurement Uncertainty for Temperature PRT probes Measurement Uncertainty (MU) 2
mr500 Interpreting Decimals in the mm state - Off Wall Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
J Interpreting clause 7.5.2.1 (validation of software used in production & service) ISO 13485:2016 - Medical Device Quality Management Systems 2
E Interpreting Partial Least Square Results Using Minitab Software 1
M Interpreting MIL-PRF-19500 (Performance Spec, Semicon Dev) - What is LTPD of 20 - ??? Manufacturing and Related Processes 4
T Rules for interpreting control charts Statistical Analysis Tools, Techniques and SPC 2
Q Interpreting Responsibility and Authority Clause 5.5.1 ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 18
H Interpreting 'Evaluation of compliance' in ISO 14001 Internal Auditing 4
P Micrometer Gage R&R study - Interpreting the data and suggestions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W Interpreting a Normal Probability Plot Statistical Analysis Tools, Techniques and SPC 4
Wes Bucey "Downsizing" ramifications - Evaluating and Interpreting the News World News 0
A Particle Counter Results - Interpreting Data for a Class 100,000 Cleanroom Other Medical Device Related Standards 12
M GD&T Q&A session - Interpreting FCF (Feature Control Frame) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 43
