Intro to MSA of Continuous Data - Part 10: Creating gauge families
This is the tenth in a series of articles about MSA. The focus of this article will be on minimizing the number of MSA studies by creating families of gauges.
A frequent question in the Cove is: “Must I perform an MSA on every gauge/part combination?” The answer is: “No. You may create families of gauges, and perform MSA studies by family.”
Wait! Not so fast! What constitutes a family of gauges? Well, there are certain criteria that must be met:
  • Same gauges
  • Same product characteristics
  • Same tolerances or process variation depending on use of gauge
Another, less restrictive approach that could be used:
  • Similar gauges
  • Similar product characteristics
  • State the smallest tolerance or process variation (standard deviation) that the gage family may be used to measure and still achieve an acceptable R&R result
Let’s cover each of these in more depth:
Same/similar gauges:
Conservative approach: Same brand and model of gauge
Alternate approach: Similar gauges (brand or model not relevant)
  • Same type (e.g., calipers, micrometers, 3 – point bore gage, etc.);
  • Same range (e.g., 0 – 6 inch, 0 – 12 inch, etc);
  • Same display (e.g., digital, dial, vernier, etc.);
  • Same resolution (e.g., 0.0001, 0.05, etc.)
  • Same technology, if relevant (e.g., scaled, rack and pinion gear, electrostatic capacitance technologies for calipers)
  • Same anvils, if relevant (e.g., outside, inside, step anvils for calipers)
Same/similar product characteristics:
Conservative approach: Same features
Alternate approach: Similar features (e.g., diameter, width, step etc.) within a specified range. Be cautious when establishing the range. You may need to perform a series of MSAs to establish how large this range may be. The impact of size will usually manifest itself through changes in the within-part variation, or by affecting the ease with which an operator can handle the part and gauge together.
Same tolerances or process variation:
  • Same tolerance if gauges are used for inspection
  • Same process variation if gauges are used for SPC
Alternate approach:
  • If gauges are used for inspection, state the smallest tolerance at which an acceptable % Tolerance may still be achieved
  • If gauges are used for SPC, state the smallest process variation standard deviation at which an acceptable % Study Variation may still be achieved
Once you have created a gauge family, document it. Create a record for each gauge family that clearly describes the gauges, characteristic and size range. The gauges could be identified by listing all serial numbers, gauge calibration ID numbers, or by clearly specifying the type, range, display, resolution and anvils.
Perform the MSA and associate it with the gauge family record.
Marc
I hope you have read the whole series of Miner's blog entries. They are excellent!
Dean Frederickson
Could I please get some help trying to understand our customer needs. they asked for a gage R and R. We gave it to them. they are o.k. with the 16.16 %R&R but not the 89.27 % apprasier variation.
% process var. % tolerance var.
% Equipmeny variation 32.82 5.58
% Appraiser variation 89.27 15.17
% R & R 95.11 16.16
% Part variation 30.88 5.25
I will be the 1st to admit I do not know how to read these results can anyone enlighten me?
G
Guest
I have been using families of gages in the past and never was questioned about it but now I'm wondering if there is a note on MSA or any other AIAG document that specifically mentions and allows this, is there any?
G
Guest
thank you for sharing your knowledge with us. one question will be , is there any document or rule that says we can do this Family groups because during the audits I am sure the auditor is gong to question this procedure and I would like to have probe that this is permitted.
thank you
Gage families are not specifically called out, but throughout the AIAG MSA manual, chapter 1, particularly section C, it states to use COMMON SENSE during planning. This is no guarantee, but will work with most auditors.
Miner Intro to MSA of Continuous Data - Part 9: %Tolerance for One-sided Specs Imported Legacy Blogs 3
Miner Intro to MSA of Continuous Data – Part 8: Comparison of Two Gages Imported Legacy Blogs 3
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
Miner Intro to MSA of Continuous Data – Part 6: R&R for Non-Replicable Measurements Imported Legacy Blogs 18
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R Imported Legacy Blogs 14
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5a: R&R Imported Legacy Blogs 5
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 4: Stability Imported Legacy Blogs 2
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 3: Linearity Imported Legacy Blogs 15
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 2: Bias Imported Legacy Blogs 4
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 1: What and Why? Imported Legacy Blogs 22
T Intro & ISO 9001:2006 Question - Is ISO 9001:2006 Released? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E French Intro to Quality - Introducing ISO 9001 to New Employees Book, Video, Blog and Web Site Reviews and Recommendations 1
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 2
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
