Introducing a new Product Variant - ECO Process?
jhambkalash
Hi All,
I need some guidance for controlling and introducing a process for creation of new part numbers. My company manufactures- flow switches, flow meters and controllers for semi-conductor industry and some for oil and gas
We have new part number created when a customer requires a flow switch (existing catalog product) variant being sold with a parameter attribute change( set point change/factory preset) within the published product spec for that particular product or product series. In a scenario a flow switch X can be sold with multiple set points- 50 different set points and each set points results in a new part number. Now to introduce these new part numbers ( BOM is same) do we need to write an ECO/ECN to release them to manufacturing ?
Regards
Kalash
somashekar
Welcome to the Cove jhambkalash
I do not think an ECO/ECN is the route to release a product varient.
As you say these are new parts in there own right, the BOM is all but same, but just one factory setting governs the part identity.
Be it 50 or 500, release it as a new part and highlight the setting aspect. Relate it to the new part number. A good and simple matrix can be a tool for introducing as many as the market demands.
I see an ECO/ECN as a change in something to an existing part, keeping the part identity the same.
jhambkalash
Thanks Somashekar!
Do we need to keep a record to show that a review of customer request was done – engineering review. Our ECO process not only allows us to introduce changes to the existing products/components , but also introduce new product variants. The only problem with this method is – paper work/approvals. Our company does lot of customization to accommodate customer request ( set points, connectors, added fittings..) and all this results in part numbers …..
What if the customer is requesting to add a special connector to the end of flow switch cable . For us we need to create a new part number to capture this new sale ( new product variant) and in this scenario a connector will be added to the exiting BOM. So what checks/records do we need to capture before introducing this to the manufacturing? Cant this be introduced through the ECO system ?
Regards
Kalash
somashekar
These are design inputs coming from customer (This gets recorded) and when it reflects in your design output (BOM, Drawings, Specifications, ...) and as these outputs are reviewed to see if design inputs are met, your cycle gets completed.
I will be very happy to use it effectively if the ECO process is so built. The process you establish must work for you. My comments on ECO/ECN are from my understanding of an engineering change process. In your case an engineering change is resulting in a new product. Again it is the way you formulate your input >> activity >> output.
When done smartly, your paper work / approval can be much simpler process as you are always building over an existing product and adding specific customer requirement. Avoid repetitions, and link to references of product specification over which the new variant is built.
You can as I mentioned above.
Look at it as Design inputs >> Processed to required design outputs >> Reviewed that the outputs meets input requirements >> Firm up the outputs >> Validate in actual build that customer requirement is met >> Release for use.
D Introducing an existing product into automotive context - DFMEA needed? IATF 16949 - Automotive Quality Systems Standard 8
J Rules associated with introducing new QMS processes IATF 16949 - Automotive Quality Systems Standard 1
S Introducing a new peripheral for cleared device - Is Validation required? US Food and Drug Administration (FDA) 3
I Introducing Titanium into Aerospace manufacturing Service Industry Specific Topics 4
P Introducing MSA in a Biomedical Company Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Marc Ford is introducing an Aluminum F-150 Pick 'em Up Truck World News 1
Q Introducing Process based approach on Production Floor Manufacturing and Related Processes 6
M Introducing ISO 9001:2008 in a Concrete and Construction Material Laboratory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Introducing New Employees Coffee Break and Water Cooler Discussions 10
8 Introducing a Balance Line - Identifying potential future pitfalls etc. Lean in Manufacturing and Service Industries 2
A Introducing New Employees to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Introducing Individual Chart to Accountants Statistical Analysis Tools, Techniques and SPC 23
J Introducing a risk/impact assessment to nonconformity procedure ISO 13485:2016 - Medical Device Quality Management Systems 12
C Examples of successful 5S projects - Introducing 5S on the shopfloor and the offices Lean in Manufacturing and Service Industries 8
T Introduce Statistical Thinking before introducing the equations Training - Internal, External, Online and Distance Learning 17
E French Intro to Quality - Introducing ISO 9001 to New Employees Book, Video, Blog and Web Site Reviews and Recommendations 1
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Extension to shelf life of new product under MDR EU Medical Device Regulations 1
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
R Compatibility studies - combination product CE Marking (Conformité Européene) / CB Scheme 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
dinaroxentool Selling a product in Both UK and EU after Brexit UK Medical Device Regulations 8
P EU MDR Translation of Product Name EU Medical Device Regulations 0
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
V New Product Model CE Mark Certification under MDR EU Medical Device Regulations 0
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
D Classification of product for clinical trials EU Medical Device Regulations 14
N Adding unclassified product to the medical device registration US Food and Drug Administration (FDA) 1
B Internal Auditor Competency - Product Auditors Internal Auditing 9
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
S AS9120B - 8.5.2 Delivering Split Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Classification of a product according to MDR EU Medical Device Regulations 3
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
Felony Melony New Product Launch - Safe Launch Customer and Company Specific Requirements 1
Marcel DS How do I know if my product is required be RoHS certified? REACH and RoHS Conversations 6
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
