Introduction of EN 62304 - Life Cycle Requirements for Medical Device Software.
W
Watchwait
#21
After stumbling on this thread by accident, I came across a PP presentation from FDA regarding Global Hatrmonization, specifically EN 60601-1 recognition, more specifically EN 62304 compliance. Bottom line - although FDA does not yet recognize 60601-1, they clearly intend to do so. However, if one is selling to Europe and is ISO 13485 certified AND voluntarily claiming compliance to 60601-1 (as are we), compliance with EN 62304 is mandatory (see slide #11 of the attached FDA presentation).
Marcelo
#22
Hwlloe Watchwait
Sorry to disagree, but any standard in Europe is voluntary (as you yourself know by our discussion in the thread http://elsmar.com/Forums/showthread.php?p=237965#post237965). Even if IEC 62304 was a collateral IEC 60601-1-X standard - which it´s not - and IEC 60601-1 now make all collateral standards normative for compliance with the general one, still the ultimate mandatory requirement of CE MArking is compliance with the essential requirements, not with standards, so it would not be mandatory in any way.
This said, i do hope that everyone begin to use IEC 62304 (and it´s "sister" TR 80002 Medical device software – Guidance on the application of ISO 14971 to medical device software, which is a twin of the AAMI TIR standard mentioned in the presentation) as they clarify what is expected as software development lifecycle processes. In fact, one of the reasons IEC 62304 was developed was that, although development lifecycle processes was an old requirement (it comes from the software engineering field), a lot of companies didn´t have any idea what was expected (for example, a lot of companies don´t have software engineers developing software, so they do not have a formal training in software engineeringmethodologies).
W
Watchwait
#23
No disagreement here at all. Your points are spot on. Consider, however, this fact: on our recent Notified Body audit, I was told to reference IEC 62304 in our Technical File for a Class IIa product as this was the current standard to demonstrate compliance with the ER.
Also your point about voluntary compliance with harmonized standards, while, again, is technically correct, the path to successfully demonstrate compliance with the essential requirements WITHOUT referencing a harmonized standard is typically far more difficult that compliance with the HS. So while voluntary compliance is technically the correct term, it is typically the less burdensome approach to demonstrating compliance to the ERs.
P
pheuvelmans
#24
Hi Alexander and others,
Can anyone of you indicate whether the EN 62304 standard is mandatory to be used within ISO 13483? We're currently runnign an ISO 13485 recertification audit and the auditor announced that he was going to our software development processes, using 62304 as reference.
A quick reply would be very helpfull, as the audit takes place now.
Thanks.
Pierre.
Marcelo
#25
As i said in previous posts, no standards are mandatory; as pointed, they´re the easiest way to show compliance. There´s no mandatory standards to use with ISo 13485. In fact, even ISO 13485 is not mandatory.
However, harminized stadards are used as the "golden standard!, so, if you do not use them, you have to show that what you do is similar to them. If you show your auditor that what you do has the same level of safety and compliance with the essential requirements as would be the case if you used EN 62304, the auditor would have to accept that.
Keep in mind, however, that EN 62304 was harmonized due to the revised MDD which clarified the software requirements.
alexander73
#26
You are lucky 'cause I've just looked into my email. If you produce software - yes, 62304 is mandatory since July 1, 2007.
P
pheuvelmans
#27
thanks for the quick reply Alexander.
However, your answer seems to conflict with marcelo's.
can you explain this?
Pierre
alexander73
#28
Marcelo is right when he states the need of provement that your actions about medical software satisfies to the requirements of 62304. Anyway, it would be easy to implement this standard comparing to a "homemade" system.
danpa
#29
13485 does not call out 62304. The 62304 'requirements' are stricter and more detailed than what 13485 requires. 62304 should not hold up certification to 13485.
That said, some countries are moving toward require 62304 compliance so at some point it will likely be required.
W
Watchwait
#30
I'll jump in w/my :2cents:
RE: Standards. Once again Marcelo is right on the target. No standard is mandatory. However, I will indicate that in my experience it is always easier to show compliance with a standard than to conceive, implement and document an alternative to the standard. Is this always the case? No, but I would say 9 times out of 10 it is the case. Auditors, not surprisingly, are more comfortable with standards, particularly harmonized standards.
RE: EN 62304. Our Notified Body has indicated that we need to reference compliance to EN 62304 in the Essential Requirements section of our Technical File. Yes, we produce software as part of our medical device. And yes, I know we have the option of developing our own approach the the REQUIREMENTS of the MDD. But as noted above, we will no doubt detail the requirements in 62304 and reference compliance with the standard.
G Question about Non-conformances during New Product Introduction Nonconformance and Corrective Action 14
S MDR & IVDR Introduction in late May 2017 EU Medical Device Regulations 1
S New Product Introduction Procedure - NPI Document Control Systems, Procedures, Forms and Templates 1
V Design Transfer to production = New product introduction ?? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
E Does introduction of a new brochure require a 510K? US Food and Drug Administration (FDA) 7
K Auditing New Product Introduction Process General Auditing Discussions 21
K NPI (New Product Introduction) Quality Plan Outsourced Manufacturer/Supplier APQP and PPAP 3
A What should be the contents of the New Gage Introduction Form ? General Measurement Device and Calibration Topics 3
T Raw Parts Inspections for NPI (New Product Introduction) Phase Supplier Quality Assurance and other Supplier Issues 1
A Food Warehouse ISO 9001 Audit and Newbie Introduction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Changes required to procedures after introduction of SAP Document Control Systems, Procedures, Forms and Templates 3
J EC Certificate and European Market Introduction CE Marking (Conformité Européene) / CB Scheme 8
AnaMariaVR2 Pharma ?Quality by Design? (QbD): An Introduction, Process Development & Applications Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Introduction to the Medical IT, Medical software and Health Informatics forum Medical Information Technology, Medical Software and Health Informatics 4
P Introduction of SPC to the Supply Chain Statistical Analysis Tools, Techniques and SPC 18
M NPDI (New Product Development & Introduction) Examples needed Excel .xls Spreadsheet Templates and Tools 3
S Monozukuri Rules for NPI (New product Introduction) - Help to get Lean in Manufacturing and Service Industries 3
D Introduction Coffee Break and Water Cooler Discussions 4
V Introduction Imported Legacy Blogs 6
E FDA New Product Introduction Regulations help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M TPM Announcement Letter for TPM introduction in a organisation Lean in Manufacturing and Service Industries 3
U Introduction of SPC - Embarking on my first implementation for precision machining Statistical Analysis Tools, Techniques and SPC 11
A QMS Introduction - I have been asked to give a brief introduction of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B New Product Development and Introduction Manual Manufacturing and Related Processes 5
P Introduction & Latest version of AIAG Control Plan request IATF 16949 - Automotive Quality Systems Standard 3
Hershal Introduction to ANS/ISO/IEC 17025 and Z540 ISO 17025 related Discussions 2
Q Procedure for New Product Introduction (NPI) - Build to print shop Various Other Specifications, Standards, and related Requirements 6
S NPI (New Product Introduction) in Electronics Industries Document Control Systems, Procedures, Forms and Templates 10
L Introduction of Compulsory Bar Coding of Medical Devices in the US? ISO 13485:2016 - Medical Device Quality Management Systems 19
Y NPI (New Product Introduction) Process Qualification System Required Document Control Systems, Procedures, Forms and Templates 8
G Introduction to TS 16949 - Excel Partnership Course Training - Internal, External, Online and Distance Learning 4
Manix TS16949 Training Requirements - Basic introduction to the standard vs. Lead Auditor Training - Internal, External, Online and Distance Learning 8
J Free Introduction Course - VBA (Visual Basic for Application) in Excel to make forms Excel .xls Spreadsheet Templates and Tools 10
C Definition NPI (New Product Introduction) Readiness - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
B Educating Employees - Introduction to what quality is all about ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Six Sigma .ppt or .doc Presentations - Awareness session or introduction wanted Training - Internal, External, Online and Distance Learning 17
A Design document - Seeking "New Product Introduction" manual example Design and Development of Products and Processes 7
K Games for training - Introduction to ISO 9001 for Upper Management Quality Manager and Management Related Issues 9
R Where can I get ISO 13485:2003 Introduction Training Videos Training - Internal, External, Online and Distance Learning 3
G Introduction of ISO/IEC17024:2003 in Australia General Auditing Discussions 3
D ISO 9001 Introduction and Training for Employees Training - Internal, External, Online and Distance Learning 36
D Fresh Coffee - An Introduction Coffee Break and Water Cooler Discussions 65
G When Do I Start FMEA? During project introduction? FMEA and Control Plans 5
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
A IEC 62304 safety classification, External Controls and off-label use related risks IEC 62304 - Medical Device Software Life Cycle Processes 5
S IEC 62304 software costs and time Medical Device and FDA Regulations and Standards News 3
S IEC 62304 - Software verification cost IEC 62304 - Medical Device Software Life Cycle Processes 3
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
