IPC 620 updating from Class 1 to Class 3
s_haduch - 2011
My company has decided to update our production facility from a standard of IPC620 Class 1 compliance to IPC 620 Class 3. I am trying to figure out what we need to focus on to make this happen in the next 6 months and be effective. Our engineering dept and PM's have agreed that everything CAN still be done to class 1 until decemember but that is where my concern is that we will not be getting better if we are given pass to continue with Class 1. Also if anyone has any info on section 19 Testing I am wondering what we need to do such as electrical and mechanical testing.
JamesBarnhart
This is one of the most common questions we receive is, “What is the difference between IPC Class 1 vs. Class 3 assembly processes?”. How it's updated from time to time. As IPC/WHMA-A-620, as an industry consensus document, cannot address all of the possible product design combinations. The IPC/WHMA-A-620 standard prescribes practices and requirements for the manufacture of cable, wire and harness assemblies. However, the standard does provide criteria for commonly used technologies Where uncommon or specialized technologies are used, it may be necessary to develop unique acceptance criteria with its updated class. The IPC/WHMA-A-620 Revision C provides the electronics industry with the most current criteria for the performance and acceptance of cable and wire harness assemblies. This revision includes a synergy with IPC-A-610 and IPC-J-STD-001, aligning many of the requirements that are in common with IPC/WHMA-A-620.
E
engr.asadbutt
[FONT=&quot]Hi Guys,
i am new to this forum and help required and i am currently for (IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies)
If anyone has please share the same.
Best Regards,
Engr.Asad[/FONT]
Al Rosen
Best Regards,
Engr.Asad[/FONT]
If you are requesting a copy of the standard, that will not be possible. The document is copyrighted and the forum's rules do not allow it. You will have to purchase it from IPC.
If you have a specific question, you may ask it in a new thread.
JamesBarnhart
Best Regards,
Engr.Asad[/FONT]
Yes, you only have to buy it from IPC or else you can join the IPC A-620 training and certification course that helps you to get a copy of IPC/WHMA-A-620,(Requirements and Acceptance for Cable and Wire Harness Assemblies) along with IPC certificate of completion. This also helps you to be able to reference the IPC/WHMA-A-620 standard to make accept/reject decisions. In total, this course will be much beneficial to you instead of buying just a copy of IPC A-620 Standard.
P IPC/WHMA-A-620, section 19.6 - Crimp Tools - 30 Day Calibration Period Requirement Calibration Frequency (Interval) 12
S IPC 620 Standards vs. Company Engineering Drawings (Prints) Various Other Specifications, Standards, and related Requirements 3
Q AS9100 and NADCAP - Our QM was told that referencing IPC 620 was acceptable AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
K IPC-610 Section 10.4.2.2 clarification - Distance to be measured Various Other Specifications, Standards, and related Requirements 0
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
E IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies Other ISO and International Standards and European Regulations 2
Q Form IPC 1720A Assembly Qualification Profile still required? Various Other Specifications, Standards, and related Requirements 1
R IPC Counterfeit Components Identification Training DVD-166C Training - Internal, External, Online and Distance Learning 3
L Best IPC curriculum for newbee in R&D Department Training - Internal, External, Online and Distance Learning 2
D IPC WHMA-A-620A vs. UL UL468A - Pull Test or Crimp Height Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Difference between IPC and IRCA Registrars and Notified Bodies 2
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
M IPC-A-610C/D Question Inside Other ISO and International Standards and European Regulations 2
P IPC - In-Process Control - Definition Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
A Material Composition Declaration - IPC 175x RoHS, REACH, ELV, IMDS and Restricted Substances 2
M IPC-A-610 vs. Our Specification - Not Staking Wire through a Bifurcated Terminal Various Other Specifications, Standards, and related Requirements 4
J Does section 19 of IPC/WHMA-A-620A require Hi-pot testing of all cables? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P PCB (Printed Circuit Board)/Electronics Inspection Training? IPC-A-610? Career and Occupation Discussions 10
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
C The latest version of the IPC 1752 MC RoHS, REACH, ELV, IMDS and Restricted Substances 6
H How to correct typographical errors on IPC Certificates? Training - Internal, External, Online and Distance Learning 3
M Experience with IPC 1752 compliance? Manage and report ROHS information RoHS, REACH, ELV, IMDS and Restricted Substances 4
G Ball Grid Array (BGA) component Incoming Inspection IPC-7095 Various Other Specifications, Standards, and related Requirements 3
G IPC-Std-610D Component Incoming (Receiving) Visual Inspection Various Other Specifications, Standards, and related Requirements 16
A ROHS Materials Declaration Standard IPC-1752 free of charge for download RoHS, REACH, ELV, IMDS and Restricted Substances 3
C Where can I learn more about IPC-A-610D without training? Various Other Specifications, Standards, and related Requirements 9
J IPC/EIA J-STD-004 - Requirements for Soldering Fluxes Various Other Specifications, Standards, and related Requirements 3
1 IPC/EIA J-STD 001 to 004 for Solder Specification Various Other Specifications, Standards, and related Requirements 9
Q Help with ANSI/IPC-A-610 C - The acceptable position of right angle headers Various Other Specifications, Standards, and related Requirements 1
L IPC/EIA J-STD-001 (soldering) revisions (Want to replace IPC-A-610) Various Other Specifications, Standards, and related Requirements 5
M Electrical Assembly Standards - IPC-A-610 "Acceptability for Electronic Assemblies" Various Other Specifications, Standards, and related Requirements 7
L Dry Lube Application (Ever lube 620) - Manual Application vs. Automated Spray Process Manufacturing and Related Processes 1
S API 620 - Do ALL "T" Joints Require RT? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S API Std 620 vs. API 650 standard? Which is the least restrictive in designing a tank? Manufacturing and Related Processes 1
M Druck DPI 620 Advanced Modular Calibration System General Measurement Device and Calibration Topics 1
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 10
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
N Updating the website of the manufacturer EU Medical Device Regulations 1
A Technical File - Updating Applied Standards EU Medical Device Regulations 4
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
N Updating QM to 13485:2016 - We do not make medical devices ISO 13485:2016 - Medical Device Quality Management Systems 1
B Site Move - Question about Updating Product Labels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
O Updating "opportunities" resulting from Corrective Actions Nonconformance and Corrective Action 2
N Updating class I device IFU with instructions to use class II cleared device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V Periodic review criteria for reviewing/updating SOPs US Food and Drug Administration (FDA) 1
T Design Changes - Updating the Design and Development File EU Medical Device Regulations 5
L Clinical Evaluation Report Updating Procedure Other Medical Device Related Standards 5
A Changing a Form Template & Updating Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
