IPC-Std-610D Component Incoming (Receiving) Visual Inspection
G
guru1000000
Hi ppl,
I just started my job on component incoming QA department in my company. I have to revised the work instruction as the previous one is only 2 pages with basically nothing in it. However, for component incoming visual inspection, i could only find the IPC-Std-610D to be a relevant standard in chapter 9 (Component Damage). Is there any other document i should refer to for component incoming inspection?
I have checked Mil-std-883G (External Visual) which only covers hermetically sealed package. IDEA-STD-1010A basically is too raw with no definite criteria to accept or reject and currently still not followed by many manufacturer.
Please advise on it.
Thank you :)
G
guru1000000
Re: IPC-Std-610D Incoming Visual Inspection
I will like to add on somemore questions regarding IPC standard document.
If we are only going to accept class 3 components, when ipc classified it as class 3 process indicator, we will use the component as it is and cannot reject it right?
For the chip component in this document 610D, in chapter 9, i hav a few questions to ask
1) For the loss of metallization, is it loss of metallization for component by itself before soldering?
2) For the chip resistor and chip component mention here, does it only refer to passive component like resistor and capacitor?Ceramic type material?
3) For section 9.3~the leadled and leadless device, it become quite blur between plastic and ceramic package. Under the target and acceptable section, does it only refer to plastic packages only?
4) Is it correct to assume that unless stated for plastic or ceramic, we can presume the acceptable or defect criteria applicable for both kind of packages?
5) For the defect criteria portion, it seem to talk about ceramic or glass packages only. Will it be applicable for plastic packages too?
Sorry for this much of questions....
If you ask for Class 3 per the IPC standard, and that's what you get, then you got what you asked for, and you might have problems rejecting something. I'm not sure if that's what you were asking, though.
It would apply prior to soldering, I would think, as the manufacturer has no control over your soldering process.
I can't help with any of these without seeing the standard. I've been away from electronics manufacturing for quite a while, and my memory is dim. I think there are others here who might chime in and provide some direction, though.
That's what we're here for. :D
Ajit Basrur
Hi guru1000000,
Being weekend, the attendance at the cove is bit sluggish and hence the responses may not be as quick as you would have expected. But be rest assured that you would get responses ;)
If your doubts have not been cleared, pl feel free to add on the queries :cool:
G
guru1000000
Thanks for the help people. :)...u two have been a great help.
Actually what i mean is whether in IPC, there are 3 classification
1)Acceptable
2)Defect
3)Process indicator
if it is class 3 process indicator , can we accept it or reject it?
Also, actually im using IPC-Std-610D Chapter 9 Component Damage as criterion to reject components during incoming inspection. I could not find any standard around for component visual inspection(before assembly), is there any standard around to dedicate for it? Please advise if there is and let me know if im wrong. Thank you :)
P.S:I have studied the IDEA-Std-1010A but it is very brief for its component rejection criterion. Also, it is still not widely followed in the industry.
CliffK
IPC 610-D is a standard for electronic assemblies, such as completed printed circuit boards (PCBs).
What do you mean by "component?" Do you mean a completed PCB with all the IC's, etc. soldered on, or do you mean the IC's, resistors, and other little bits?
If the former, 610-D is the one you want. If the latter, it ain't gonna help.
G
guru1000000
Its the IC's, resistors, and other little bits. Basically electronic components before soldering. Do you know of any industrial standard to follow for incoming visual inspection?
Reason, im using 610D because it is the standard which i can find that quantify failure criteria. Like how badly is the crack extend that will be reasonable for us to reject it, example: we will reject the component only if the crack expose the internal functional element.
I only used Chapter 9 component damage from this specs and i believe that if
lets say: IPC-610 are going to reject the component if after soldering it has crack and its internal circuitry are exposed. I could use the same rejection criteria to reject component before solderng since before soldering its already achieved the rejection criteria of 610.
Is this reasoning correct? Anyone know what standard is the industrial using for incoming visual inspection? Thanks alot for providing JESD-101A info to me. It is of a great help.
Thank you :)
Thank you :)
In most electronics manufacturing companies there isn't a lot of inspection of incoming components beyond simple identification--verifying that the thing received is the thing ordered. Because so much of electronics manufacturing is automated these days, components are often supplied on reels where it's not practical to randomly inspect a received lot. If you're having problems related to the quality of incoming components, you have a problem that inspection isn't going to solve.
J IPC/EIA J-STD-004 - Requirements for Soldering Fluxes Various Other Specifications, Standards, and related Requirements 3
1 IPC/EIA J-STD 001 to 004 for Solder Specification Various Other Specifications, Standards, and related Requirements 9
L IPC/EIA J-STD-001 (soldering) revisions (Want to replace IPC-A-610) Various Other Specifications, Standards, and related Requirements 5
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
K IPC-610 Section 10.4.2.2 clarification - Distance to be measured Various Other Specifications, Standards, and related Requirements 0
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
E IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies Other ISO and International Standards and European Regulations 2
Q Form IPC 1720A Assembly Qualification Profile still required? Various Other Specifications, Standards, and related Requirements 1
R IPC Counterfeit Components Identification Training DVD-166C Training - Internal, External, Online and Distance Learning 3
L Best IPC curriculum for newbee in R&D Department Training - Internal, External, Online and Distance Learning 2
D IPC WHMA-A-620A vs. UL UL468A - Pull Test or Crimp Height Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P IPC/WHMA-A-620, section 19.6 - Crimp Tools - 30 Day Calibration Period Requirement Calibration Frequency (Interval) 12
R Difference between IPC and IRCA Registrars and Notified Bodies 2
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
M IPC-A-610C/D Question Inside Other ISO and International Standards and European Regulations 2
S IPC 620 Standards vs. Company Engineering Drawings (Prints) Various Other Specifications, Standards, and related Requirements 3
S IPC 620 updating from Class 1 to Class 3 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P IPC - In-Process Control - Definition Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q AS9100 and NADCAP - Our QM was told that referencing IPC 620 was acceptable AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Material Composition Declaration - IPC 175x RoHS, REACH, ELV, IMDS and Restricted Substances 2
M IPC-A-610 vs. Our Specification - Not Staking Wire through a Bifurcated Terminal Various Other Specifications, Standards, and related Requirements 4
J Does section 19 of IPC/WHMA-A-620A require Hi-pot testing of all cables? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P PCB (Printed Circuit Board)/Electronics Inspection Training? IPC-A-610? Career and Occupation Discussions 10
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
C The latest version of the IPC 1752 MC RoHS, REACH, ELV, IMDS and Restricted Substances 6
H How to correct typographical errors on IPC Certificates? Training - Internal, External, Online and Distance Learning 3
M Experience with IPC 1752 compliance? Manage and report ROHS information RoHS, REACH, ELV, IMDS and Restricted Substances 4
G Ball Grid Array (BGA) component Incoming Inspection IPC-7095 Various Other Specifications, Standards, and related Requirements 3
A ROHS Materials Declaration Standard IPC-1752 free of charge for download RoHS, REACH, ELV, IMDS and Restricted Substances 3
C Where can I learn more about IPC-A-610D without training? Various Other Specifications, Standards, and related Requirements 9
Q Help with ANSI/IPC-A-610 C - The acceptable position of right angle headers Various Other Specifications, Standards, and related Requirements 1
M Electrical Assembly Standards - IPC-A-610 "Acceptability for Electronic Assemblies" Various Other Specifications, Standards, and related Requirements 7
P What ASTM std is EC 93/42 MDD EQUIVALENT TO CE Marking (Conformité Européene) / CB Scheme 1
Marc MIL-STD-810H - 31 January 2019 Various Other Specifications, Standards, and related Requirements 0
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
K MIL-STD-2000 Certification Requirements Manufacturing and Related Processes 9
G Mil-Std-130N, can calibration be a nationally traceable standard? Various Other Specifications, Standards, and related Requirements 0
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
V Is MHLW Std No.169 - 2004 being Revised in Nov 2014? Other ISO and International Standards and European Regulations 5
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A MIL STD 105 D or ISO 2859-2? Receiving Metal Sheets Quality Tools, Improvement and Analysis 6
D I need the advice/opinion from a J-STD expert Manufacturing and Related Processes 1
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
J Mil Std 810 G test 516 vs IEC 60068-2-27 - Classic Waveform Shock Various Other Specifications, Standards, and related Requirements 1
S Calibration conducted to 3 steps only of the std instead of complete 5 steps General Measurement Device and Calibration Topics 4
V IEC 62304 Requirements Analysis and IEEE Std 830-1998 IEC 62304 - Medical Device Software Life Cycle Processes 3
A JEDEC Std to use as reference for a package of size of 29x29mm with 0.8mm ball pitch Design and Development of Products and Processes 6
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
alonFAI Fungus Testing per MIL-STD-810F Reliability Analysis - Predictions, Testing and Standards 6
M IEC 60601-2-24 Ed 2.0 (Infusion Pumps Particular Std.) - Redlines IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
