IPC-Std-610D Component Incoming (Receiving) Visual Inspection
CliffK
#11
What Jim Wynne said in post #10 is correct.
Also the sheer volume of bits is going to make it hard to do any meaningful inspections.
The only exception I can think of is high-dollar SMT/BGA parts that are being bought in the broker's market and are not available in the original packaging. Often these are obsolescent parts encountered for whatever reason.
With SMT parts you can visually inspect the leads for co-planarity. You can look at the solder balls on BGA parts.
If you suspect problems with lead tinning, there are tests for solder adhesion. Unfortunately I can't remember the standard that calls it out. Also there are test labs that can do adhesion/solderability tests for you. I will tell you, though, that these labs were completely puzzled by adhesion problems that surfaced at the start of the no-lead days.
G
guru1000000
#12
Thanks for the feedback guys :).
But still find it funny that not even sampling of visual inspection of incoming components is done.
If this batch of incomponent packages are cracked, there isnt any inspection to check on it? But instead just verify the quantity that all? I saw both Mil-Std-883 and Jedec has external visual guideline for it.
#13
The extent of any receiving inspection that's done (or any other inspection, for that matter) should be based on risk and practicality. If you receive a batch of any type of nonconforming material, the likelihood of it happening again and the potential loss as a result of it should figure into what you decide to do about it. The existence of standards for visual inspection doesn't mean that you should consider visual inspection necessary in every case. You need to evaluate the (a) the costs associated with receiving inspection of components and (b) the risks associated with not inspecting them.
Al Rosen
#14
The less you handle these components the less likely you will damage them due to ESD. ESD damage may be latent and not discovered until some time after operating in the product.
Raffy
#15
Several years ago, our company which was a Telephone manufacturing and certified to BABT. What we used as reference is the Quality Control Workmanship Standard from Intertel. I don’t know if this one is available in the amazons.com.
Raffy:cool:
Q
quality1
#16
Depends on the component where testing/inspection is possible for damages. 610D gives you some criterias to check for but not practical for certain components due to size.
Ask for certification from suppliers, RI of these components are very hard to do. We do not do any component receiving inspection since some are MSL 3-4 and should not be opened until usage. Verify PN, QTY and type per your purchase order.
Sometime we ask for additonal sample to keep for each lot received incase we have to do investigation.
sfkevin
#17
Guru1000000
I have work for circuit board assembly houses and the receiving inspection is just sampling and external visual verification of marking and values with some testing as applicable. All this needs to be done in a controlled ESD area. I now do detailed inspection on components for telecommunication satellites so there are several procedures to reference.
IC’s reference MIL-PRD-38535, which calls out the MIL-STD-883, for transistors’, and diodes you can reference MIL-PRF-19500, which states use of MIL-STD-750 test methods 2068 & 2071 for external inspection requirements.
If you need some details on the Destructive Physical Analysis you can reference MIL-STD-1580 it shows what companies do and what they look for on the external inspection of various parts.
Hope that helps :D
J IPC/EIA J-STD-004 - Requirements for Soldering Fluxes Various Other Specifications, Standards, and related Requirements 3
1 IPC/EIA J-STD 001 to 004 for Solder Specification Various Other Specifications, Standards, and related Requirements 9
L IPC/EIA J-STD-001 (soldering) revisions (Want to replace IPC-A-610) Various Other Specifications, Standards, and related Requirements 5
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
K IPC-610 Section 10.4.2.2 clarification - Distance to be measured Various Other Specifications, Standards, and related Requirements 0
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
E IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies Other ISO and International Standards and European Regulations 2
Q Form IPC 1720A Assembly Qualification Profile still required? Various Other Specifications, Standards, and related Requirements 1
R IPC Counterfeit Components Identification Training DVD-166C Training - Internal, External, Online and Distance Learning 3
L Best IPC curriculum for newbee in R&D Department Training - Internal, External, Online and Distance Learning 2
D IPC WHMA-A-620A vs. UL UL468A - Pull Test or Crimp Height Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P IPC/WHMA-A-620, section 19.6 - Crimp Tools - 30 Day Calibration Period Requirement Calibration Frequency (Interval) 12
R Difference between IPC and IRCA Registrars and Notified Bodies 2
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
M IPC-A-610C/D Question Inside Other ISO and International Standards and European Regulations 2
S IPC 620 Standards vs. Company Engineering Drawings (Prints) Various Other Specifications, Standards, and related Requirements 3
S IPC 620 updating from Class 1 to Class 3 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P IPC - In-Process Control - Definition Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q AS9100 and NADCAP - Our QM was told that referencing IPC 620 was acceptable AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Material Composition Declaration - IPC 175x RoHS, REACH, ELV, IMDS and Restricted Substances 2
M IPC-A-610 vs. Our Specification - Not Staking Wire through a Bifurcated Terminal Various Other Specifications, Standards, and related Requirements 4
J Does section 19 of IPC/WHMA-A-620A require Hi-pot testing of all cables? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P PCB (Printed Circuit Board)/Electronics Inspection Training? IPC-A-610? Career and Occupation Discussions 10
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
C The latest version of the IPC 1752 MC RoHS, REACH, ELV, IMDS and Restricted Substances 6
H How to correct typographical errors on IPC Certificates? Training - Internal, External, Online and Distance Learning 3
M Experience with IPC 1752 compliance? Manage and report ROHS information RoHS, REACH, ELV, IMDS and Restricted Substances 4
G Ball Grid Array (BGA) component Incoming Inspection IPC-7095 Various Other Specifications, Standards, and related Requirements 3
A ROHS Materials Declaration Standard IPC-1752 free of charge for download RoHS, REACH, ELV, IMDS and Restricted Substances 3
C Where can I learn more about IPC-A-610D without training? Various Other Specifications, Standards, and related Requirements 9
Q Help with ANSI/IPC-A-610 C - The acceptable position of right angle headers Various Other Specifications, Standards, and related Requirements 1
M Electrical Assembly Standards - IPC-A-610 "Acceptability for Electronic Assemblies" Various Other Specifications, Standards, and related Requirements 7
P What ASTM std is EC 93/42 MDD EQUIVALENT TO CE Marking (Conformité Européene) / CB Scheme 1
Marc MIL-STD-810H - 31 January 2019 Various Other Specifications, Standards, and related Requirements 0
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
K MIL-STD-2000 Certification Requirements Manufacturing and Related Processes 9
G Mil-Std-130N, can calibration be a nationally traceable standard? Various Other Specifications, Standards, and related Requirements 0
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
V Is MHLW Std No.169 - 2004 being Revised in Nov 2014? Other ISO and International Standards and European Regulations 5
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A MIL STD 105 D or ISO 2859-2? Receiving Metal Sheets Quality Tools, Improvement and Analysis 6
D I need the advice/opinion from a J-STD expert Manufacturing and Related Processes 1
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
J Mil Std 810 G test 516 vs IEC 60068-2-27 - Classic Waveform Shock Various Other Specifications, Standards, and related Requirements 1
S Calibration conducted to 3 steps only of the std instead of complete 5 steps General Measurement Device and Calibration Topics 4
V IEC 62304 Requirements Analysis and IEEE Std 830-1998 IEC 62304 - Medical Device Software Life Cycle Processes 3
A JEDEC Std to use as reference for a package of size of 29x29mm with 0.8mm ball pitch Design and Development of Products and Processes 6
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
alonFAI Fungus Testing per MIL-STD-810F Reliability Analysis - Predictions, Testing and Standards 6
M IEC 60601-2-24 Ed 2.0 (Infusion Pumps Particular Std.) - Redlines IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
