IQ/OQ for Process Monitoring System - Sensors and HMI System
N
nadavreu
We manufacture a Class II medical device,we are currently in planing to install a process monitoring sensors (pH,Ec and Temp') and HMI system.:mg:
What are the parameters or procedures that we need to have in IQ/OQ for this particular monitoring system?
Is there a reference standard ?
:thanx:
Nadav
Stijloor
:thanx:
Nadav
Any Medical Device experts who can help?
Thank you!
Stijloor.
G
gholland
Hello
Here are my thoughts:
IQ - make sure you have the correct power and any other requirements for the sensors (brackets, installed correctly, etc). This would include verification of the calibration of the sensors. You are validating that the sensors have what they need to work correctly, this means everything they need to do the job in your process. This also includes Preventative Maintenance, Calibration frequencies, etc... all this should be documented and the proof of this documented in the IQ.
What I would then do is have the accuracy of the sensors documented and a statement supporting that the sensor is sensitive enough for your needs. In my company we have a general 4 to 1 rule where the accuracy of the sensors needs to be 4x the tolerance that is allowable. In other words if I have to have the temperature accurate to +/- 1C then I would need a sensor accurate to at least 0.25C for the sensor to be acceptable. I would prove this by the calibration and manufacturer specification of the sensor. What you are trying to avoid is the situation where your process range is, say, +/- 1C and your sensor only accurate to +/- 1C so your process is not sensitive enough to detect when you're out of your process window.
I cannot comment on pH, I have not had to measure this but I can envision it being handled the same way. If you need +/- 0.2 pH then your sensor must be accurate enough to detect to this level.
I would OQ the sensors by inserting faults into the system. I am assuming your process alarms when there are hi/low temperatures or pH readings. I would insert cases where the sensor detects a high and low value (out of your acceptable process window) and validate that the process acts as it is supposed to when it encounters a fault. I would run multiple iterations of this for each, depending on your company statistical guidelines. You are testing not only that the sensor is detecting the fault condition but that the sensor communicates to the process and the process will handle it correctly.
I would then PQ the process to validate the whole thing is working correctly.
For the HMI - this is potentially more complicated - are you making quality decisions based on the HMI or are you just using it for informational purposes? If you are making quality decisions of the product based on the HMI then you are in for much fault insertion and proof that the HMI is reading your sensors correctly. If the HMI information is just for informational purposes I would document this and move on.
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
E IATF 16949 Cl. 9.1.2 - Monitoring Process Performance IATF 16949 - Automotive Quality Systems Standard 1
T IATF 16949 Control Plan and Process Monitoring Requirement(s) IATF 16949 - Automotive Quality Systems Standard 1
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 8
J Appropriate In-Process Monitoring Frequency for 2X per day Change Set-Up. Statistical Analysis Tools, Techniques and SPC 3
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Medical Device Manufacturing Process Monitoring Best Practice ISO 13485:2016 - Medical Device Quality Management Systems 2
I Critical Variables Monitoring during Process Validation Qualification and Validation (including 21 CFR Part 11) 4
C Tool Monitoring - Controlling a Process with Better Tool Monitoring Manufacturing and Related Processes 4
H Monitoring the Calibration Process General Measurement Device and Calibration Topics 13
R Minitab for I-MR - Monitoring Process on Temporary Basis & Temporary Limits Using Minitab Software 6
C Process Monitoring Instrument Quality Levels or Categorizations General Measurement Device and Calibration Topics 3
F Process Monitoring Gage Calibration Requirements - 7.6.3.2 External laboratory IATF 16949 - Automotive Quality Systems Standard 1
M Temperature/humidity monitoring process procedure Manufacturing and Related Processes 2
T ETO Sterilization - Process monitoring and out-inspection ISO 13485:2016 - Medical Device Quality Management Systems 3
T Monitoring the monitoring process - Customer complaint process isn't being monitored IATF 16949 - Automotive Quality Systems Standard 7
K Process monitoring, measuring and analyzing, does this means all company processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Process Auditing - Identifying/Monitoring "Key" Processes Sufficient? Process Audits and Layered Process Audits 5
H How to understand "Monitoring the Process"? "Measurement" of the Process? IATF 16949 - Automotive Quality Systems Standard 14
D Corrective and preventive action, process monitoring ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Sharing best practices in customer satisfaction monitoring process Customer and Company Specific Requirements 17
T Process Internal Audit - Requirement on Monitoring Objectives & Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Looking for Process Monitoring /SPC Package - Molded pharma packaging Statistical Analysis Tools, Techniques and SPC 4
S MSA (Attribute Gage R&R) on our process monitoring points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Monitoring,measuring... realization process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Sample Size and Frequency - In-process monitoring in a mass production shop Statistical Analysis Tools, Techniques and SPC 2
R Gage R&R Studies for Process Monitoring Instruments? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Element 4.9.1 Process Monitoring QS-9000 - American Automotive Manufacturers Standard 3
G Process monitoring of portable & stationary oxygen units: Can we use Cpk, Ppk, SPC ? Capability, Accuracy and Stability - Processes, Machines, etc. 3
G Process monitoring - Stationary and portable oxygen units ISO 13485:2016 - Medical Device Quality Management Systems 1
L 4.9.1 Process Monitoring & Operator Instructions QS-9000 - American Automotive Manufacturers Standard 1
A When someone refuses to follow a process.... Misc. Quality Assurance and Business Systems Related Topics 21
R MDEL Process Canada Medical Device Regulations 4
optomist1 Rates Daily or Hourly Process Improvement Training Consultants and Consulting 2
B Toyota PPAP Process - Three Questions APQP and PPAP 3
R Changes vs CMO - How can we simplify this process? Supplier Quality Assurance and other Supplier Issues 3
A Ethics Committee Review Process for IVD Products EU Medical Device Regulations 2
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
