IQ/OQ/PQ in a Tool Shop with a Small Injection Molding Plant
E
Ellie May
I work for a tool shop with a small injection molding plant included. We make electronic connectors and some of them may be used for medical applications. We may have to start an IQ/OQ/PQ protocol, and I do not know how to include this into the quoting of the tool, or the molding sampling. If you have any suggestions please let me know. We may or may not end up running the production, most of what we do is just sample and measure the final product. How much of the IQ/OQ/PQ will we be responsible for.:confused:
Thank you for any help you may be able to give!
Kevin Mader
One of THE Original Covers!
Re: IQ/OQ/PQ help!
Ellie May,
You may want to enquire as to who will be responsible for developing the requirements and the associated validation documents. If your customer recognizes that you are a smaller organization, then they may elect to support this activity internally. For instance, I will utilize a Process Control Engineer of mine to support this type of activity for a smaller supplier of our provided they are a strategic supplier. In addition, my colleague in Operations would need to loan resources as well, generally in the capacity of Test and Process Engineers. Validation is generally a costly activity, but the advantage here is that inspection requirements generally are reduced (essentially, the upfront investment offsets the downstream inspection activities). Additionally, it is a regulatory requirement for your customer, so dependent on where they achieve the assessment, it may in fact have to be done at your location. You may also look into the cost of a temp resource to perform these activities. Expect to pay somewhere between $75-150 an hour for a good validation engineer with project management skills. There is a ton to consider here, so unless you have expertise in this area, outsourcing is the way to go. You can, however, offset costs by providing your internal support under their/the hired resources guidance.
Regards,
Kevin
ScottK
Not out of the crisis
Kevin gives some excellent advice about utilizing the customer's resources if they have them. In my experience most fair sized companies do have people that can help. I did blow molding and injection molding with a large consumer goods company and they had someone to hold my hand all the way through their IQ/OQ/PQ process the first time around. As did other companies I worked with.
That would be my first choice.
Second would be - does the business warrant a QA Engineer full time? Will there be more business along the same lines to help justify this?
Third would be the outsourcing option.
It's been a while but here's what I remember in a nutshell of our IQ/OQ/PQ process for amentiy size bottles:
IQ - Initial mold and tooling check out. Checklists of parts, fittings, etc. Do they all fit together in the machine. Heat it up and shoot some plastic until you have parts. Check parts for all cavities - full dimensionals.
OQ - 8 hour run in production once the process is brought to stability with all settings locked in. Pull samples one from each cavity every 30 minutes. After sitting for 24 hours do critical dimensions on the 1st, middle, last samples and crunch stats. Do physical testing on samples between 1st and middle, middle and last.
PQ - this was based on 3 production runs of SPC data and how the parts ran at the filler.
Keep in mind this isn't a medical device. It was for hair care products, but it was in molding so it might give you a general idea.
I've also done the process for filling drug product. The data was different and included cleaning/sanitizing validation, but the core process was the same.
E
Ellie May
Thank you very much guys. You did simplify the process a lot Scott. We are still in the phase of learning what all is involved in this IQ OQ PQ and are not even sure if it would be cost effective for us to move forward. It does seem that a lot more of our potential customers are requesting this in our quotes. We have no clue how to quote the cost for new tools if we need to use IQ OQ PQ. Most of the tools we build we only sample, this makes it difficult to determine the necessity of such a program. We do have a full time Quality Engineer who is working with me and researching more information. I have a sample IQ and OQ for another injection molding company so the process of validation has been explained. Our dilemma is whether it would be cost effective for us being such a small company. We do run production for some customers, and implementing this may bring our molding department more jobs, but how do we determine if we should mover forward.::bigwave:
ScottK
What do you mean as a sample? Like a prototype?
You shouldn't have to validate a prototype tool. Only the actual production tool that's going to produce finished goods should be validated.
Also - are you selling the tooling or are you going to mold the parts too?
If you're selling the tooling your part really ends after the molder's IQ phase. And even then - you're only responsible for the tooling itself, not the press.
E
Ellie May
Good point, some of the work we do is prototype. But wouldn't we still be responsible for the IQ part, since we run the samples in house? We are responsible for all the measurement data at the time of the sample also. Some of the molds we build we do run production and some we don't. This is something we clarify with our customers prior to the build. And how do we determine the cost of implementing IQ OQ PQ in the initial tooling quote.
yodon
Sounds to me like you're a contract manufacturing shop. If that's the case, the impetus to validate the processes and equipment is not yours, it's the company contracting you to do the work. Further, it sounds like you're only supplying components, not finished goods. The 'manufacturer of record' would need to determine how they accept your parts. This could be 100% test / inspection - in which case the processes / equipment creating the component would not require validation.
If I'm close, I don't think you would be responsible for any of the validation UNLESS you are commissioned to do just that; i.e., not on your dime. I would agree with Kevin that if you want to quote the service as part of the tooling, then you should probably get a consultant to help.
Kevin Mader
Good input folks!
In my experience, few smaller contract manufacturers/suppliers have the understanding and the resources to execute an IQ/OQ/PQ. However, I recognize that if one were to have the capability, it would get my attention.
While driving home tonight, I was thinking about something an ex-FDA agent told me. It was his belief that Process Control at a supplier did more for a manufacturer than a Process Validation. Although the requirement is to periodically revisit validation, the reality is that it isn’t often done (except when the process changes significantly). Process Control is real time there for a better solution in his mind. He may have a point. Nonetheless, if the item you’re producing is a final product, Process Validation or Qualification might be mandatory. Look into your options.
As noted above, take a look at what FDA has to say on Process Validation. Also, read the Global Harmonization Task Forces Guidance on the Principles of Process Validation. You should find all you need to understand the concept well enough, however, the combination of good theory and experience (perhaps provided by a hired resource) yields the best results. Because this is generally an expensive process, going cheap usually results in poor results that aren’t worth much. For validations I have been a part of, costs ranged between $40K and $2M+. Recognizing the kind of investments possible, going short on a resource might prove to be a costly error. On a few occasions, costly validations had to be repeated because of poor preparation and inexperience. Luckily I worked with a company with deep pockets. Without that luxury, it is possible to sink a smaller organization.
It looks like you have some capable colleagues to glean information from. This looks like it might be a very productive thread.
Good input everyone!
Kevin
J Competence Assessments in a Small Tool Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Machine Shop Tool Crib Procedure - Tooling for CNC mills Quality Tools, Improvement and Analysis 1
L Changes to a Tool Drawing/Print in a Tool Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
L Work Instructions for a Tool Shop - What do we have to have? Document Control Systems, Procedures, Forms and Templates 5
L Traveler or Route Card in ISO 9001:2008 - Tool Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Control of Nonconforming Product in a Tool Shop - Scrap Dies Nonconformance and Corrective Action 5
L Work Instructions for One Time Tool Build - Tool and Die Shop Manufacturing and Related Processes 6
T How does a tool-shop validate molds? Verification vs. Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
J Need a contract monitoring Tool General Information Resources 0
_robinsingh Security Risk Assessment Tool IEC 27001 - Information Security Management Systems (ISMS) 0
M SemaTech SSQA Standardized Supplier Quality Assessment - my favorite tool ever Manufacturing and Related Processes 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G APQP Scope and scale tool APQP and PPAP 2
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
O Dimension Measurement Tool Recommendation General Measurement Device and Calibration Topics 21
Y Commanded life cycle management tool IEC 62304 - Medical Device Software Life Cycle Processes 1
GreatNate Excel PPAP Tracking templates or tool wanted APQP and PPAP 1
E Standards Management Tool Quality Tools, Improvement and Analysis 1
E ISO 9001:2015 - Record requirements for out of calibration tool ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
M PDCA as a project tool Quality Tools, Improvement and Analysis 5
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
John Broomfield Workplace by Facebook - Any other organizations using this collaborative tool? Misc. Quality Assurance and Business Systems Related Topics 0
A Overkill? Using the 3L5W tool on non-conformities Nonconformance and Corrective Action 3
I Tool Control Marking Voiding Warranty AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
F Quality Tool box talks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D VDA 6.4 Audit checklist - Production tool suppliers VDA Standards - Germany's Automotive Standards 1
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
G Design and development of user centric audit report visualisation tool Design and Development of Products and Processes 5
G Web based tool for benchmarking audit findings Benchmarking 6
J AS9100D Clause Brain Fade - Tool was past due for Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
R New Tool from Omnex - IATF Gap Assessment IATF 16949 - Automotive Quality Systems Standard 0
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
I Veeva installation and the Loader Tool Document Control Systems, Procedures, Forms and Templates 3
M IATF Tool for Leadership and Planning - 2017 IATF 16949 - Automotive Quality Systems Standard 0
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
K Looking for Calibrated Tool Shadowboard Substrate Ideas AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Marc SAS vs. R vs. Python: Which Tool Do Analytics Pros Prefer? Statistical Analysis Tools, Techniques and SPC 6
P Tool for Measuring - Do I have to do more than one Gage R&R for the PPAP? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Pneumatic & Electrical Torque Tool - Calibration/Verification of 'Power Tools' General Measurement Device and Calibration Topics 2
M Excel Leadtime Analysis Graphic Tool with Macros Enabled Lean in Manufacturing and Service Industries 0
D Medical Device Software Tool Validation - Compilers! IEC 62304 - Medical Device Software Life Cycle Processes 7
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
J CNC Machine Tool Calibration - 6 dof Calibration Interferometers General Measurement Device and Calibration Topics 1
P Using Bugzilla as a Quality Reporting Tool Quality Assurance and Compliance Software Tools and Solutions 11
Marc Hackers unleash smart Twitter phishing tool that snags two in three users IEC 27001 - Information Security Management Systems (ISMS) 7
