IQ, OQ & PQ (Installation, Operation, and Performance Qualifications) on a CMM
BradM
Hello there! We are sure glad you dropped by!
well, the first thing that came to mind was the below thread:
Validation documentation
In it, Ajit and some others provide steps/guidelines to developing the program.
1. Do you already have a validation plan for your facility?
2. Is this your first validation to perform?
3. Are you going to have to validate other equipment?
4. Have you already written the operating procedure?
Also, I know we have several attachments relating to validation. You might want to view those and see if there is something of interest.
The instruction manual/ mfg. information is a great start for the IQ/OQ. Hopefully your management has some plan/functional specification for the equipment. That will also be a great start.
The mfg. of the equipment may have something (usually for sale:)) that you might can use. Also, if you are so inclined, it might be worth it to find a contractor that is qualified for this project to help you out.
Just some thoughts.
G
Gert Sorensen
I am not quite certain as to why you want to validate a CMM machine? But assuming that you have good reason to do it here is my ideas:
1. Use a dedicated computer - subject to change management.
2. Make sure that the computer is accepted by your IT department
3. The computer should be a standard of the shelf machine
4. Only the minimal software should be installed on the computer.
5. Evaluate it for Part 11 compliance - if applicable
6. Make sure that it is being set up with users, passwords and restricted network access.
As far as IQ goes it is fairly simple:
Verify that the CMM is installed according to specs. Is it level? Controlled lighting? Temperature of the room? Humidity? Some of this you will need to define depending on your products.
That cabling is done in an orderly manner.
That the software is installed correctly
OQ:
SOP's need to be in place
Calibration need to be done
Test all relevant functionalities of the program
PQ:
I wouldn't go there, I would make sure that OQ testing were comprehensive.
Hope this helps:bigwave:
JoCam Rental, service & installation - regulatory requirements EU Medical Device Regulations 2
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Veeva installation and the Loader Tool Document Control Systems, Procedures, Forms and Templates 3
GURU SDI Leak Testing - O-ring installation in the groove of Bore ID Problem Solving, Root Cause Fault and Failure Analysis 4
A Best Method of Auditing an Installation Process at a client job-site ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Do you test the download and installation of a mobile medical device app? Software Quality Assurance 6
Q UDI and Standalone Software - UDI per installation? Other Medical Device Related Standards 6
A What is the definition of Installation that requires Record Keeping vs Set-up 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L Medical Device Installation Records from Third Party Installer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J FDA Microscope IQ (Installation Qualification) Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S ISO 13485 Installation Activities 7.5.1.2.2 ISO 13485:2016 - Medical Device Quality Management Systems 4
G Nonconformity Reporting at Installation Sites Service Industry Specific Topics 8
K Supplier or outsourced? Medical Device installation, sales, training Other ISO and International Standards and European Regulations 7
N Definition of Large-Scale Fixed Installation per the RoHS2 Directive EU Medical Device Regulations 3
E IEC 62304 5.2.2 f - Installation and acceptance of device software IEC 62304 - Medical Device Software Life Cycle Processes 1
S Barcode Scanner IOPQ (Installation/Operational/Performance Qualification) Requirement Qualification and Validation (including 21 CFR Part 11) 9
S Time & Motion Study - Dish TV Installation Quality Tools, Improvement and Analysis 4
J ISO 9001 Audit Questions relating to Installation of Lifts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Office Relocation Installation Inspection Sheet Document Control Systems, Procedures, Forms and Templates 5
S ETSO, TSO and EASA Form 1 - Do I need the ETSO approval for the installation? EASA and JAA Aviation Standards and Requirements 3
S SW (Software) - Customer vs. Company Installation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Site Installation Inspection and Testing for a HVAC Contractor Service Industry Specific Topics 2
W Packaging / Heat Sealer Validation - IOQ (Installation/Operational Qualification) Qualification and Validation (including 21 CFR Part 11) 15
A Installation and Validation Procedure for IT Laboratory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Starrett RGC4040-24 CMM User and Installation Manual General Measurement Device and Calibration Topics 2
W IQ, OQ, PQ (installation, operational & performance qualification) compared to PPAP ISO 13485:2016 - Medical Device Quality Management Systems 5
H Basic questions about Installation, Operational & Performance Qualification - PCBA Qualification and Validation (including 21 CFR Part 11) 11
R Is there a Specification for safety wire installation - Aerospace, SAE or otherwise AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
D Tips/Documentation samples required for X-ray Film Processor Installation needed. ISO 13485:2016 - Medical Device Quality Management Systems 1
T Installation Requirements for Bench Top Device ISO 13485:2016 - Medical Device Quality Management Systems 1
MarilynJ6354 Service & Installation Parts Identification - Install equipment at a customer's site Service Industry Specific Topics 6
C Installation Document that meet NFPA 70 & 72 Various Other Specifications, Standards, and related Requirements 3
C NFPA 72 and NFPA 72 Standards - Electrical Installation and Fire Alarm Systems Various Other Specifications, Standards, and related Requirements 3
C ISO 13485 and IQ (Installation Qualification), OQ (Operational Qualification) ISO 13485:2016 - Medical Device Quality Management Systems 30
C Generate IQ, OQ & PQ (installation/operational/performance qualification) Report Document Control Systems, Procedures, Forms and Templates 11
Q Software installation issues After Work and Weekend Discussion Topics 3
I Medical Gases Installation - Can be classified as MD and ISO 13485 certificated? ISO 13485:2016 - Medical Device Quality Management Systems 5
S Quality Standards on Refrigeration (Installation) field IATF 16949 - Automotive Quality Systems Standard 3
C Auditing of Installation of Product at Customers Sites General Auditing Discussions 6
M Seeking: Good process definition (map or whatever) for an installation business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to Calibrate Software - Microcontroller software installation General Measurement Device and Calibration Topics 1
F 4.9 Installation & Servicing Processes QS-9000 - American Automotive Manufacturers Standard 1
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G Need resources / tutorials about OPS (Operation) for ISO IT (Information Technology) Service Management 8
F MEDDEV 2.7/1 rev 4 and MDR - Definition of Description of Principles of operation EU Medical Device Regulations 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
B Machine process sheet requirements for pill bottling operation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
G Infrastructure and Environment for the operation of processes (ISO 9001 7.1.3 & 7.1.4) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Hot dogs and process operation and control effectiveness? 4.1.3 a) ISO 13485:2016 - Medical Device Quality Management Systems 2
