IRIS audit - Discussion about Special Processes
During our current external audit in ISO 9001 and IRIS we ended up having a rather weird discussion about the term "Special Process".
We're in the cable industry and has pointed out specific processes in a list which we review yearly with solusions considering special processes as we has interpreted the standards. This list considers processes where we can't guarantee or control the end-result without breaking the product.
During the audit in our production the auditor was absolutely 100% sure all of our different "lines" (machines) are all special processes, so he wrote a non-conformaty regarding our handling of special processes.
Could anybody explain this to me (cause the auditor just pointed at IRIS segment 6 but I can't get a hold of it atm) and if I'm wrong; how do I solve this? We have separate worksheets with all testing included for each product in each individual machine.
outdoorsNW
We do some cable work, and I doubt 100% of your machines are special processes. For instance, if a part needs to be able to withstand 10 pounds of pulling force, you can put it in a tester and see if it passes. We have some customers who ask us to 100% test at the rated max force. Your customers may have different requirements.
Special processes are things that can not be adequately inspected. So anything you could inspect but choose not to (perhaps because you had no failures in a 5 year period) is not a special process.
How can you expect to comply with a requirement if you don't have access to it?
The following comes from ISO/TS 22163:2017
Thank you for this. We do have the IRIS-standard at site but I don't hold the main responsibility in this, I was just curious since we haven't gotten a NC about this since like 15 years back, which we solved by creating this list of our special processes and do yearly internal audits regarding this list.
We have some of those testings aswell, like HOT-SET and aging tests, which are made in our labratory, but still in relation to the current order.
I don't know, we will have a discussion and most likely refuse the NC, just wanted som input from others.
somashekar
It is not the auditor who decides what are your special processes.... That said, the note in the post #3 display are most typical special processes. I have seen that crimping for example is not a special process in some cable industries, and has been justified based on the process control, tool maintenance and monitoring, and the batch release system based on batch starting and ending records of inspection (FAI and LAI) The same has also been well documented in the risk management.
Your records of risk management and process must support your NC refusal, as well as your internal complaints or customer complaints.
John Broomfield
Also, consider the cost benefits of treating processes as if they are special.
Such processes are designed to result in products that reliably conform to specifications without any need for further testing or inspection.
IRIS goes way above and beyond 9001, so I sympathize there. I dont have the current IRIS standard, so without knowing what it states, I can't help much, we decided to avoid IRIS entirely after researching it in depth, its another case of a large customer setting the requirements, sort of like Boeing in the AS9100 world. If you could post segment 6 wording, or what the auditor said exactly, that would help.
Sidney Vianna
Post Responsibly
ISO/TS 22163 is the global standard for quality management systems in the rail industry. It is based on the ISO 9001 quality management standard, with the addition of rail-specific requirements. Released in May 2017, it replaced the previous quality standard IRIS Rev. 02
I have it on my computer at work now so I'll share it tomorrow when I'm stationed. The segment on special processes was a full 6 pages addition and explanation about what a special process is. We kind of solved this today tho after an hour of intense studying of this segment. We cover all of The requirements, but we were a document short showing how we deal with this standard. So I just collected and put together a few different documents and the auditor was very pleased again.
For you who are interested, this is the full explanation according to IRIS what a special process is, moderators hopefully will post my link (since I'm not trusted YET).
This was changed in 2014, but the former auditor never pointed this out. Hard to keep up if the auditor doens't mention this is not fullfilled.
E AS9100 similarity to IRIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
E International Railway Industry Standard (IRIS) Auditor Training Requirements Other ISO and International Standards and European Regulations 13
J Meaning of Business Management System in IRIS (International Rail Industry Standard)? Various Other Specifications, Standards, and related Requirements 4
M International Rail Industry Standard (IRIS) GM/RT2450 Other ISO and International Standards and European Regulations 3
hogheavenfarm ISO then International Railway Industry Standard (IRIS) Or straight to IRIS? Other ISO and International Standards and European Regulations 3
J How to get the International Railway Industry Standard (IRIS) Various Other Specifications, Standards, and related Requirements 5
T International Railway Industry Standard (IRIS) Other ISO and International Standards and European Regulations 4
J 9001 Internal Audit of Client Onboarding process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
H Streamlining audit response and corrective action processes ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Corrective Action Notification - Registration Audit ISO 13485:2016 - Medical Device Quality Management Systems 12
chris1price Irradiation site for dose audit Other Medical Device Related Standards 2
PQ Systems 5 Ways to Reduce Stress on Your Next Audit Using GAGEpack Software 0
PQ Systems Audit Prep – Time for a System Health Check Using GAGEpack Software 0
N API Q1 Audit Surveillance - Questions Oil and Gas Industry Standards and Regulations 2
A Alternative to on site audit in China EU Medical Device Regulations 2
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
B Internal audit checklist Internal Auditing 5
V Internal Audit Software IATF 16949 - Automotive Quality Systems Standard 5
J Internal Audit Schedule IATF Internal Auditing 3
Mikey324 External calibration - Finding in our 3rd party audit General Measurement Device and Calibration Topics 58
C ISO 14001 Internal Audit - Opportunity for Improvement ISO 14001:2015 Specific Discussions 2
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
J Stage 2 audit initial cert, few data points ISO 13485:2016 - Medical Device Quality Management Systems 4
S Corrections not allowed during audit ISO 13485:2016 - Medical Device Quality Management Systems 7
P Looking to outsource Internal Audit - MDSAP competent auditor needed Other Medical Device Regulations World-Wide 9
R GFE Audit - Violation? GFE Location Controls AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Help Me. Non conformitty in External Audit IATF 16949 - Automotive Quality Systems Standard 13
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
B UKRP to what level should you audit Class I Technical Documentation? UK Medical Device Regulations 0
I Audit is tomorrow but I refused to participate Misc. Quality Assurance and Business Systems Related Topics 16
I ISO 17025:2017 / ANAB 3125 - Articulating / Communicating Risks vis-a-vis Audit Findings ISO 17025 related Discussions 2
D Verify Audit Trail of SaaS system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
D Re-labeler - audit the supplier EU Medical Device Regulations 2
J Outsourced Internal Audit requirements for Aerospace Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
A PPAP question for audit APQP and PPAP 17
D Number of people to be interviewed during an internal audit? Internal Auditing 10
B Gamma Quarterly Audit Medical Device and FDA Regulations and Standards News 1
A Anxiety - ISO Re-registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 69
Ed Panek Auditor MDR (Presub audit) finding EU Medical Device Regulations 2
Q Easy CARs for Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D Question and advice for a supplier self audit questionnaire ISO 13485:2016 - Medical Device Quality Management Systems 6
S Quarterly Dose Audit Medical Device and FDA Regulations and Standards News 5
H When is a SOC 2 audit necessary? IEC 27001 - Information Security Management Systems (ISMS) 5
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Special IATF audit of sub-supplier IATF 16949 - Automotive Quality Systems Standard 18
armani Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
C API Q1 internal audit report Internal Auditing 3
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 2
J Internal audit random sampling methodology Internal Auditing 2
