Is 100% Inspection a Control or does a Process need another type of control?
G
Ghemzie
Hello Experts!
This is my first time to post here, and I appreciate any little information that you could impart for my query.
We have several 100% in-process inspections in the line to capture visual defects and items that are out of electrical specification. Our company required the implementation of FMEA and Control Plan to document our quality process, but we are confused whether a 100% Inspection (Visual or Electrical) is considered as Control or Process.
Is the 100% Inspection considered as a Control or a Process that need another method of control (like sampling inspection from the output of 100% inspection)?
Ghemzie :confused:
achorste
Every inspection activity is a control if it's related to the process - however we have to remember that 100% inspection is not 100% effective. To completely (or near as possible) eliminate defects you would have to "error proof" your process to some degree.
The need to extra controls could be identified by your FMEA risk analysis - if the risk of non-conforming product is too high you could justify using other controls on the process.
bobdoering
Stop X-bar/R Madness!!
There are people that like to consider 100% anything part of the process because it occurs to every product. But, anything done to the product to make a decision on the process or product output would be a control. :cool:
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove! :bigwave:
Inspection, either by sampling or 100%, is not a form of process control. Process control is the activity or set of activities that prevents your items from failing inspection.
Tom W
Welcome to the Cove!
Like the others have stated 100% inspection for visuals is rarely 100% effective. Is there some other type of defect prevention that could be used? How about concentrating on defect prevention rather than defect detection... can you make the process robust enough to eliminate defects?
bobdoering
Ghemzie :confused:
I guess we should ignore the semantics, which sounds like a good idea at this point, and look at this point of the posting. There is no need to sample a process that already has 100% inspection. When you seeking a failure at a very low frequency, and the the failure is random and not predictable, sampling will never see anything anyway.
It is nice to think that every cause generates clues that it is about to fail. If you can, then great - it is a very rote answer to the issue. But, similar to catching a murderer before he kills, it is not always possible. A random flaw in raw material, for instance, may not be predictable. Sometimes your best bet is to improve your 100% inspection to increase your 80% odds - which is generally attributed to 100% visual inspection. For example, automated inspection has been known to improve those odds. :cool:
achorste
That is a good point, but in the case of documenting a control plan it would be considered a control wouldn't it as it is preventing defects from being passed on to the next process / customer?
From what I've seen in the discussion so far I would point the OP towards using the risk assessment to identify potential non-conformances and put the controls in to prevent to occurence & once verified, use an appropriate sample plan to verify the product is conforming. However it is not always that easy and sometimes 100% inspection is the only thing the business will allow ("it's what we've always done" or "it costs too much for the additional equipment") despite the inherent time, quality and cost improvements associated with defect prevention as opposed to detection - I've been there unfortunately.:mad:
G
gooofii
Ghemzie , welcome to the cove family:agree:
I agree with Jennifer inspection should not be considered a process control. I believe that the new concept for quality is to eliminate inspection as possible ''Inspect the process not the product''. And as the fellows said to apply mistake proofing , preventive action to eliminate defect . I am just wondering is your product that critical that you do 100% inspection , is the time and money consumed worth doing it...
Hello Experts!
Ghemzie :confused:
On the AIAG FMEA form, the "Current Process Controls" column is bifurcated into "Prevention" and "Detection" controls, so those who have opined that 100% inspection isn't a process control are not exactly correct. It is a process control from the viewpoint of filling out the form, but as a practical matter it shouldn't be considered process control. Process control is what you do to avoid inspection.
G
Ghemzie
Thank you all for the response and viewpoints
Most of our process is done manually, and greatly depending on the skill of the workers that is why it is opted to do 100% visual inspection after critical processes and 100% electrical test to satisfy functional specification.
From the viewpoint of documentation 100% inspection will be considered as Control, but it still necessary to check whether this 100% inspection possibly will create potential failure ( handling that may cause damage or improper setting of the machine) and in this case preventive control should be in placed.
S 100% Inspection Control Chart By Dr. Feigenbaum - SMT (Surface Mounting Technology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S 100% Final Inspection Requirements of Active Medical Devices (MDD or IEC Standards?) EU Medical Device Regulations 4
E Is there a specific regulatory requirement for 100% inspection of IFUs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Switch to 100% inspection when lot fails sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Is Controlled Shipping requirement Sampling Based or 100% Inspection? Misc. Quality Assurance and Business Systems Related Topics 3
N 100% Inspection in Retail Warehouse which Ships Products to Customers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K 100% Inspection or do the usual IQ, OQ, PQ Validation - Medical Molding Design and Development of Products and Processes 3
G Am I silly to do a 100% inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M 100% Inspection - 85% Effective Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Vision System - Camera vs. Sensor to perform 100% EOL Inspection Quality Tools, Improvement and Analysis 2
S AQL .65 Level III - Take a particular component off 100% Inspection AQL - Acceptable Quality Level 4
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
M SPC vs. 100% Inspection - Is SPC still value-added when 100% inspection is in place? FMEA and Control Plans 40
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
S Is there an Accept/Reject Criteria for 100% Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
E 100% continuous inspection question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
R Transfering Cpk specification to 100% inspection specifications Capability, Accuracy and Stability - Processes, Machines, etc. 24
S Condition of 100% inspection in organization. Capability, Accuracy and Stability - Processes, Machines, etc. 7
Q Who is responsible for 100% Inspection (QC) activities? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
1 U Charts, Defects and 100% Inspection Statistical Analysis Tools, Techniques and SPC 8
C Acceptance Sampling is Better Than 100% Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
J Visual Inspection Not 100% Effective - How to Improve Visual Inspection Quality Tools, Improvement and Analysis 51
J Customer Complaint Corrective Action Response - 100% Vision Inspection Customer Complaints 9
M 100% Measurement Shift to Sample Inspection? PCB Substrates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L Customer Requires Cpk 1.33 with 100% Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
R 100% Visual Inspection - Would you Remove or Reduce the Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Inspection 100% - Process continuos (Continuous Process) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Tips for convincing general labour that 100% inspection not required Various Other Specifications, Standards, and related Requirements 18
S P-Chart Question - Need Guidance - 100% inspection of all product parts required? Statistical Analysis Tools, Techniques and SPC 11
T Prototype Inspection - 100% Inspection on All Parts or just a Sample? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A How effective is 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
R 8.2.3.1 Monitoring and measurement - Containment of product and 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Final Inspections - Does 100% inspection really work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R 100% Inspection - 80% Accurate - Quote from Juran (?) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 94
CarolX Accuracy of 100% Visual Inspection - Proofs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 33
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
A What to do when 100 % verification is not 100 % Manufacturing and Related Processes 5
Nicole Desouza ISO / AS Certification - Small business with less than 100 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M EU – Chemical Safety Report – CSR – REACH Authorisation decisions – Triton X-100 – Ortho-clinical-Use1 REACH and RoHS Conversations 0
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
Marc Anniversary of the First Trans-Atlantic Flight 100 years ago - June 2019 Coffee Break and Water Cooler Discussions 2
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
BHobbs_Busche All Measurements taken with a Variable Gage have to be Recorded 100% IATF 16949 - Automotive Quality Systems Standard 14
Pmarszal Clarification for 21 CFR Part 11.100 - General Requirements Other US Medical Device Regulations 14
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K IEC 61010-2-100 Labeling question - IVD equipment Other ISO and International Standards and European Regulations 1
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
