Is a Maintenance Program Required by ISO9001:2000 requirements?
chascoffin
We operate a small shop, 85 employees, fabrication and machining work. We have a lean staff, our maintenance area comprises of two people who are kept quite busy with day-to-day activities related to keeping our equipment running. We have no PM, seems our system is 'run it until it breaks, then repair or replace'. Operators are asked to do routine maintenance (oil, lube, clean, etc.), but no records are kept. I'm looking for opinions for minimum requirements to satisfy ISO9001:2000 requirements. Any thoughts greatly appreciated. Thanks
Chas
silly girl
Well, 6.3 seems to talk about maintaining equipment. This is of course using the language 'the organization shall determine' which allows you some flexibility in determining what your program is. The text is:
'The organization shall determine, provide and maintain the infrastructure needed to achieve conformity to product requirements. Infrastructure includes, as applicable:
  • A - buildings, workspace and associated utilities
  • B - process equipment (both hardware and software), and
  • C - supporting services (such as transport or communication).'
Are you having a problem convincing management that a PM program would be beneficial? Or are you looking for minimum compliance? The answers to these questions might lead to different ideas.
At the very least, if operators are performing some maintenance, get them recording the information. Personally, a preventive maintenance program makes a lot more sense than waiting until it breaks.
Silly Girl
E
Ederie - 2007
I would have them (operators / maintainence) record it when they do the oil / lube / cleaning of the machines. (it is preventative)
Keep a simple record /form at each machine for them write it down.
Maybe you'll see a pattern as to breakdowns on machines that are not being
oiled / lubed / cleaned.
We all have machine parts that we have no way of knowing when they'll break
Its a start.
Ed
chascoffin
Silly Girl
Top management has heard 'say what you do, do what you say' so many times I think they believe we can document what we do (or in this case what we don't do) and be compliant without making any changes. I guess I am looking for the minimum requirements at this time, thinking the system, when in place, will drive improvement. Too much change initially could kill the whole effort. Thanks for the input.
Chas
db
In addition to what was already posted...
There is no explicit requirement for maintenance, but also look at 7.5 .1 c) “the use of suitable equipment” It is hard to argue that equipment that is not working is “suitable”.
Helmut Jilling
Auditor / Consultant
Chas
From what you describe, it would appear pretty clear why two people out of 85 are kept quite busy doing repairs...
There may be a way to calculate the cost of not having a PM program:
  • Ask accounting to tell you what you spent on repair parts,
  • add in the wages paid the two guys,
  • track the unscheduled downtime related to repairs and breakdowns as lost machine time,
  • factor missed deliveries due to breakdowns,
Add these all up, adjust a bit if needed, and you get a general idea of what your current method is costing you. I expect it will be a pretty significant number.
samer
Involved - Posts
Chas
You should have PM schedule chas,and records for it , you should ,with or without referring to standard , this is a mininmum requirment,
you should have planning for every process ,remember PDCA?
SAMER
harry
Chas,
After reading your post, especially the sentence '....seems our system is 'run it until it breaks, then repair or replace'.......'. It makes me wonder if you had purposely choosen your user name to convey a subtle message. :biglaugh:
Rgds
Joe Cruse
I agree with hjilling; you need to crunch numbers and see what the lack of preventive maintenance is costing your company. Take suggestions from the machine operators and the 2 maintenance workers about what could be done to extend machine life/dependability and measure the costs of those suggestions vs cost of machine replacement/downtime/product nonconformity.
If machine breakdown is affecting product quality, don't forget to include cost of rework and scrap from this.
The standard doesn't give you a bunch of "shalls" for implementing a PM program of any kind, only that infrastructure is to be provided and maintained to achieve product which conforms to specs. A good PM program, tailored to your company's situation would do this, and may save your company $$$ and headaches with production schedules and customers.
JohnCTB
Chas,
I am at a 35 employee moldbuilding shop. We also run it till it breaks and then repair it. I tried having a list of maintenance items with a check-off list on each piece of CNC equipment. This caused more problems with ISO than it solved. The forms always had too many gaps in them. Either the operator did not check-off on the form, or that piece of equipment was not operated that day. A form on the shop floor that is not properly filled in is worse than no form. We determined the minimum maintenance we are comfortable with for each piece of CNC equipment. At the beginning of each month I output a maintenance request form for each machine on my list for that month. I give the forms to the production manager and he delivers them to the operators. They then perform the listed maintenance item and sign the form. A few days later I get the signed forms back and file them in the maintenance folder for that job. All other maintenance is handled with a generic maintenance request form by the production manager.
JCTB
  • Jan-April-July-Oct.xls
R FAR 145.205 - Maintenance Program Flow Down Requirements Federal Aviation Administration (FAA) Standards and Requirements 3
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
P NC Program Rev Control and Tool Control & Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
AnaMariaVR2 Need Laboratory Equipment Maintenance Program Training Material US Food and Drug Administration (FDA) 3
R Who runs your Preventive Maintenance Program? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
B Preventive Maintenance Program in a non-production facility Misc. Quality Assurance and Business Systems Related Topics 4
A FAA 8130-3 Release After Maintenance Federal Aviation Administration (FAA) Standards and Requirements 1
S Netsuite Preventive Maintenance and Calibration Manufacturing and Related Processes 0
N Yearly maintenance fee increased from$400 to $1500 USD - Did yours? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Part 145 Maintenance Data Review EASA and JAA Aviation Standards and Requirements 1
G Why do you guys think ISO 9001 doesn't ask specifically for preventive maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
W Total Productive Maintenance - Any resources? IATF 16949 - Automotive Quality Systems Standard 6
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
C Determining if Maintenance Contractor is an External Service subject to ISO 9001 Clause 8.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
B Total Productive Maintenance - Company Transport IATF 16949 - Automotive Quality Systems Standard 2
P Minor Non-Conformance - Maintenance Records Not Fully Completed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
L 21CRF820.70(g)(2) Maintenance Inspection Interval 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K IATF16949 8.5.1.5 Total Productive Maintenance IATF 16949 - Automotive Quality Systems Standard 9
J FAA Maintenance Requirements - DER Repair to a PMA Part Federal Aviation Administration (FAA) Standards and Requirements 1
K Maintenance requirements for Production Equipment in AS9100D General Auditing Discussions 8
T Part 145 Maintenance Station S/N ESN Character Requirements EASA and JAA Aviation Standards and Requirements 3
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 42
D Does AS9100 certified OEM need AS9110 if no maintenance is provided? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N Laboratory Audit Nonconformance - Maintenance of Standards ISO 17025 related Discussions 10
A Technical File Maintenance - Old generation product EU Medical Device Regulations 4
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
S Preparing a Turtle Diagram for Maintenance Department Misc. Quality Assurance and Business Systems Related Topics 2
U Relating maintenance to product quality Manufacturing and Related Processes 5
S ISO 9001 Audit requirement for maintenance department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Service and maintenance in an initial importer facility USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
