Is a MSA (Measurement System Analysis) needed on these two tests
optomist1
A Sea of Statistics
Hi To All,
I could use some guidance regarding whether or not to perform an MSA in the following situation, the process I am investigating involves two separate inspections or tests, in the manufacture of non-production electrical harnesses:
1) a destructive tensile strength pull-test of a wire/terminal crimped connection; the test is performed with a digital force gauge with +/-0.5% accuracy, 0-100 lbs range and resolution to 0.1 lbs. The device comes with certificate of calibration traceable to NIST. Currently within calibration; annual re-calibration is required.
This device is being used to perform the above test; minimum spec. = 13 lbs
2) a simple point to point continuity test with a micro-processor based test set. This comes with a self-calibration/set of standards traceable to NIST, to perform annual in-house annual (minimum) re-calibration. Currently within calibration; the standard must be re-calibrated every two-years.
This device merely performs point-to-point continuity checks.
In both cases the tests are performed on "non-production" electrical harnesses.
Your input will be welcomed...thank you.
Regards,
Marty
Re: Is a MSA needed
Hi To All,
Regards,
Marty
How is it possible to manufacture (as you put it in the first sentence) "non-production" items? Can you clarify what's being made, and why?
optomist1
A Sea of Statistics
Re: Is a MSA needed
Hi Jim,
Thank you for the response...this may be semantics, I define non-production in this case as electrical cables/harnesses that a Tier 1 automotive supplier uses "to support" (test function) production. The cables/harnesses are not part of the finished consumer product.
Thanks for your response...great site....
Regards,
Marty
Re: Is a MSA needed
Hi Jim,
Regards,
Marty
Assuming that you have to provide PPAP submissions for these things, your customer(s) will decide what the PPAPs must include. In general, the PPAP requirements are applied only to production parts (which is why the first "P" in "PPAP" stands for "Production"), but your customers might have other ideas.
optomist1
A Sea of Statistics
Hi Jim,
No we have no PPAP requirement; I am looking at this from an internal perspective; as to whether it makes "good sense" to perform an MSA even if there is no requirement.
Thanks again for your input....
Regards,
Marty
Hi Jim,
Regards,
Marty
Whether or not you do it depends on your confidence in your measurement system(s) and the risk involved, if any--the likelihood that something bad will happen because of measurement error.
optomist1
A Sea of Statistics
Thanks Jim,
In this case it comes down to a judgement call based upon my process knowledge and that of the production manager.
Your input was a great help..
Regards,
Marty:thanks:
N
NumberCruncher
Hi Optomist1
I won't be so presumptuous as to tell you whether you should or should not carry out an MSA (I'm not going to be responsible for your judgement call!). But here are some things to consider.
Which of these tests are used in production? Whichever is used, that is the one to concentrate on regarding a potential MSA. That is the one which is actually being used to check goods before they go out of the door. I assume it isn't the pulloff test as this is destructive and you wouldn't have any test harnesses for use!
Regarding the pulloff test.
Given the specification of the gauge, if it is correctly calibrated, it should be more than adequate for the job. With a resolution of 0.1 lb and a data range of about 16 to 36 lb, you can make measurements to less than 1% of reading.
This is a destructive test. As you can't measure the same terminal twice, an MSA study has to make an approximation.
"Analysis of these systems [ie non replicable or destructive] will depend on whether a homogeneous set of parts (small part to part variation) can be found to represent a single part"
See page 153 of the MSA manual (4th edition)
Where are you going to find your homogeneous sample of crimped connections? You would need to be able to confidently say that "All of these connections will fail at about 25 lb force, all of those will fail at about 30 lb force.." and so on.
If you intend to use pulloff force as a measure of
I think that the most that you could determine with MSA would be reproducibility. Do all of your staff carry out the test to the same level. Is the reproducibility of this test important to know?
Regarding the continuity test.
I will guess that this is the actual test that is used in production as it is non destructive.
You said in a previous post that one of your staff was not carrying out the crimping correctly (paraphrasing wildly, but I think the gist of the statement is there). Possibly your testing method was not good enough to pick up the bad crimps. There was electrical continuity, but a weak mechanical connection.
An MSA study is certainly a possibility.
A final, probably fruitless thought
Does your continuity tester just give a pass/fail or does it give you an actual reading in ohms?
If it gives you a reading in ohms, do the weakest connections give the highest resistance? I doubt that you will find any difference in most crimps. But you got one crimp in your last set of data that was very low. Did this have a significantly higher electrical resistance?
I suspect a connection would have to be very bad before it shows up as a high resistance joint, so bad that it would be obvious without testing. But who knows?
NC
optomist1
A Sea of Statistics
Good Day NC,
Thanks for the thoughtful, thorough response......
Tensile Test
It seems as though the general de facto guide for "test resolution" is 10:1, so if I am measuring (or the specification) to 1 pound then the test device or instrument must measure or resolve to 0.1 lbs. Makes sense.
Great point regarding attempting to conduct a MSA on a destructive test....the instrument is properly calibrated and traced to NIST....I'll leave this dog for another day.
Continuity Test
The typical resistance threshold for a "pure cable assembly", no components is 5 ohms; although the device can be programmed to output the actual resistance reading, it typically reads out a pass/fail based on the user programmed 5 ohm threshold. Regarding a possible difference in resistance readings.....the visually "bad crimp" aside, I doubt it. Although this may be worth further investigation.
In both cases the devices are properly calibrated and traced to NIST; no MSA for me. But the "Must An MSA Performed" exercise or question must be asked and answered.
Thanks again for the thorough thought provoking response.....
Regards,
Marty
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M How to Stack for MSA (Measurement System Analysis) in Minitab? Using Minitab Software 1
V Is MSA (Measurement System Analysis) required for Weighing Scale? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Linearity Problem (MSA - Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Gage R&R/MSA for In Process Measurement System in a Turning Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Weighing Scale MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q MSA Studies on each Equipment, each Measurement System or Family in Control Plan? IATF 16949 - Automotive Quality Systems Standard 35
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Measurement System Assessment (MSA) - Water Crackle Test General Measurement Device and Calibration Topics 2
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
S MSA (Measurement System Analysis) for Medical Device Manufacturers Other US Medical Device Regulations 3
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MSA (Measurement System Analysis) on Multi-Phase Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A Width and location errors in MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Measurement System Analysis (MSA) Procedure template Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R Imported Legacy Blogs 14
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5a: R&R Imported Legacy Blogs 11
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 4: Stability Imported Legacy Blogs 2
