Is a new 510k needed if modifying to add bluetooth for data transmission?
P
PL.
We have a cleared blood pressure monitor, and we intend to add a Bluetooth function to it (for data transmission) and we also develop a iOS APP for it (as to manage the data from the monitor).
(1) I?m not sure whether should we submit a new 510k or not (after referring to the guidance: Deciding When to Submit a 510(k) for a Change to an Existing Device)?
(2) And, if a new 510k is needed, should it be a traditional or a special?
Can anyone give me a piece of advice?
I
isoalchemist
I believe a new 510k would be required at first glance based on Chart B. You have an operating principal change, you are now transmitting the data. You have a SW/FW change that may depending on your system affect the indication for use. Additionally You will need to verify and validate the Bluetooth signal for Safety & Effeteness.
A better understanding of your product might change my thought process, but right now you have some paperwork ahead of you IMHO.
snowball852
I agree that a new 510(k) would be required. I also think FDA would consider it a traditional as I think they would consider the bluetooth new technology added to the current device. HOwever, if you are into taking risks, you could submit as a special and plan to have the reports ready when/if they come back with a conversion to a traditional. You would probably only lose a couple of weeks if they convert it. But, the upside is that if they accept it as a special, then you get a quicker approval.
RansomEli
I agree with the previous posts - you need a new 510(k).
A couple bits of advice: make sure you produce a detailed risk assessment that shows you have seriously analyzed all the potential hazards of your devices. Then, make sure you have a very well-written (and executed) software test plan. The extra preparation time you spend in these areas will be well rewarded.
P
PL.
Thanks for the advice!! It helps!
But, I found out that we have a cleared device that has a bluetooth fuction, and the modification to the device is:
deleting data managing fuction (like averaging results) of the cleared device itself and creating a iOS APP for it to manage the data. (please note that the modified device can work without the APP)
In this case, is a new 510k needed?
sagai
My opinion is that this Bluetooth stuff explodes a bunch of safety questions and looks obvious at least for me a new 510k.
Nevertheless there is another apps for iphone, so it is really drifting this to a new 510k.
Let's make it simple ...
Is this modification changes the intended use of your original 510k?
In doubts, I would not hesitate to pick up and call FDA's small manufacturer's hot line for free of charge.
Regards
P
PL.
Hi, sagai
thanks for the response!
The APP is actually developed to replace the original data management function (the original data management function is deleted and the APP is employed). In this regard, the intended use is not changed.
And, I've tried to consult DSMICA, but they refer me to the guidance: when to submit a new 510k anyway...
Ronen E
Problem Solver
Moderator
The new app might be considered a new medical device in its own right >>> look at the new FDA guidance applicable to apps.
The fact that you have another cleared device with Blue Tooth functionality is less relevant for the decision whether or not the monitor's change requires a new submission. However, if this monitor we're discussing already has it, then it may not require a 510(k) after all - depending on whether or not the change would raise new questions regarding safety and effectiveness (be careful when answering). If it does require a 510(k) I'd say it'd be a special 510(k).
Cheers,
Ronen.
P
PL.
Hi, Ronen
Do you mean that,
when it comes to making decision of whether or not to submit a new 510k of the monitor, we do not have to take the APP into consideration, because the APP should be another medical device itself?
And, you mentioned there is a new FDA guidance on apps, could you kindly tell which one is that? (as I can only find the draft released in 2011: Draft Guidance for Industry and Foodand Drug Administration Staff: MobileMedical Applications)
Ronen E
Problem Solver
Moderator
Do you mean that,
I mean that you first have to consider the bigger picture. My gut feeling is that the app might be a separate device. I didn't check it in detail. If, after reviewing the details and the applicable guidance, you come to the same conclusion, it might bear on how you handle the change in the monitor.
Perhaps I shouldn't have used the word "new". Everything is relative... :)
P Deciding whether or not a new 510k is needed Other US Medical Device Regulations 2
D Info needed for a 510k of a high-pressure line? Especially Design Controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
C CMO for class 2, 510k exempt device Manufacturing and Related Processes 4
A Where 60601-1 represented in the 510k submission? US Medical Device Regulations 6
S Is it possible to obtain FDA clearance (510k) without meeting QSR? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Shipped Products Liability After 510k Ownership Transfer US Food and Drug Administration (FDA) 0
R US FDA 510k Australia TGA US Food and Drug Administration (FDA) 0
S Adding new product code/Catalogue number to existing 510K US Medical Device Regulations 0
N Importing into US without 510K/FDA Clearance US Medical Device Regulations 1
B Is 14971 Annex C checklist now in ISO/TR 24971 required to complete prior to 510k filing? ISO 14971 - Medical Device Risk Management 3
V FDA 510K - Pre Submission Query US Food and Drug Administration (FDA) 6
C FDA 510k documentation requirements US Food and Drug Administration (FDA) 1
E 510k reference devices US Food and Drug Administration (FDA) 4
S Submit under a new product code in a 510k? US Medical Device Regulations 5
G Declare interoperability in a 510K Medical Device and FDA Regulations and Standards News 1
S Looking to find a pharmaceutical manufacturer that would be interested in buying or licensing a USDA 510k clearance General Information Resources 4
E Do I need test reports for all standards mentioned in my 510k application? Other Medical Device Related Standards 8
T Including a class 1 camera in the 510k application of class 2 therapeutic technology? US Food and Drug Administration (FDA) 18
N Traditional 510K Submission-Financial Certification or Disclosure Statement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
P Letter to file or special 510k or traditional 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
H 510k with Contract Manufacturer Other US Medical Device Regulations 2
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
K 510K new manufacturer but same components Other US Medical Device Regulations 6
S Two or more predicates suitable? 510K submission US Food and Drug Administration (FDA) 5
S 510k: What to include if your own device is the predicate US Food and Drug Administration (FDA) 5
L 510K - Trade Name Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
R Countries that accept 510k approvals - Class II nonsterile medical device Other Medical Device Regulations World-Wide 2
M Timing of 510k submission Other US Medical Device Regulations 9
S Examples of software changes that required a 510k US Food and Drug Administration (FDA) 2
D 510K and Changes to Verification and Validation US Food and Drug Administration (FDA) 2
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
H New 510K VS Documents about design change. Other US Medical Device Regulations 2
P Medical Device not on commercial distribution but installed in the establishment. 510k? Other US Medical Device Regulations 10
V Presubmission FDA for 510k US Food and Drug Administration (FDA) 4
A How to deal with changed shared components in 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Can we take a part from 510k cleared medical device and use it in class I device? Other US Medical Device Regulations 6
D Contents of a 510k Q submission Other US Medical Device Regulations 1
L Class IIa Medical Device, CE Mark & 510k - Labeling Content CE Marking (Conformité Européene) / CB Scheme 4
Ed Panek Other company wants to use our FDA 510K bundled with their product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L 510k exemption process - Do you still need to submit technical dossier? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S IEC 62133 - CB Scheme Required by FDA 510k Other Medical Device Related Standards 3
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
P V&V for Special 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Clarity on requirements for a 510k exempt Class I device - Suture removal kit US Food and Drug Administration (FDA) 9
T Is 510k Anesthesia group particularly picky/difficult to work with during 510k? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
